Hottoty 0 Posted July 14, 2016 Posted July 14, 2016 On my android devices the live tv guide stops at channel 135. But my channel list is right with all 424 channels and the shows that are on. Any suggestions?
Gripweed107 4 Posted July 22, 2016 Posted July 22, 2016 Just wanted to let you know that I am (and have for a long time) seeing the same thing. With my stations the Guide only goes up to channel 114 and I can't get it to display any more. That matches the first grouping of channels shown when you display Channels. Says "1-100 of 357" and the last channel displayed is 114. The next bunch after you hit the right arrow is 115 thru 422. Then 423 thru 849. Then 850 thru 1998. There is no right arrow offered to display the next grouping of channels in Guide. ***Request*** - In both Guide and Channels I would prefer if it displayed all 357 of my channels all at once and not have them not broken into groups of 100 channels at a time. Thanks. Sent from my Venue 10 7040 using Tapatalk
Gripweed107 4 Posted July 27, 2016 Posted July 27, 2016 The latest update of the app, 2.7.29, seems to have fixed the problem. In fact it lists all the channels in the Guide at once as requested. I'm very happy. Thank you so much. Sent from my Venue 10 7040 using Tapatalk 1
Hottoty 0 Posted July 31, 2016 Author Posted July 31, 2016 Thanks for the progress. Now it seems to stick at 1606. I do have channels up to 1991. Also the load time seems long is there anything I can do about that?
revengineer 142 Posted July 31, 2016 Posted July 31, 2016 I just checked the latest beta and I am still limited in the number of channels loading. Nothing has changed as far as I can tell.
ddurdle 75 Posted August 20, 2018 Posted August 20, 2018 Hi guys, was this ever fixed? I have a user on formuler z7+ suffering the same issue. I've asked him to try favourite some channels to push them up in the list but it hasn't helped.
ddurdle 75 Posted August 20, 2018 Posted August 20, 2018 The user sees this issue only on the formuler z7+ as shown. It's running AndroidTV and the Emby app is 1.6.15g. They've tried the same account on a MiBox3 (Android TV and Emby app 1.6.16g). I'm thinking there might be a setting somewhere introducing the issue
