first input window disappears
Go to solution Solved by Angelblue05,
I'm not sure if this is a limitation in kodi, in the emby plugin or even in the trakt plugin.
When you have enabled the feature that you can choose to delete the movie/tv show when finished, you get a prompt where you can select to delete it or not, and that works well.
However, if you also have the trakt plugin enabled where you have enabled the feature to rate the movie/show after finished, you will see the emby prompt for a couple of seconds, and after that the trakt rating prompt pops up and the emby prompt disappear.
The optimal functionality would be that you get the prompts one after another. Not sure if it is a limitation in kodi or if you could queue the prompts?
Edited by joggs
  • Solution
Angelblue05
Sounds like the trakt addon is closing all dialogs, rather than just displaying their own... It can only be fixed on their side.
See line 88 needs to be removed. You could navigate to the addon folder in Kodi and update the rating.py file in notepad: https://github.com/trakt/script.trakt/blob/master/rating.py
Sent from my iPhone using Tapatalk
Edited by Angelblue05
  • Like 1
Great answer!
I'll try to contact the trakt devs.
  • Like 1
Guest
