hotrod_hemi 1 Posted July 13, 2016 Posted July 13, 2016 Greetings, My apologies if this is not the correct thread to post this question: Looking for an understanding - When I play Live TV (mpeg 2 stream) through the web interface (any platform) via HDHomeRun Extend HW (No Transcoding), Live TV is smooth, very low CPU utilization. When I then record the same video stream (without Emby transcoding), the resulting mpeg 2 file pegs the CPU at 95-100%. Yet... when I use the same HDHomeRun HW with Myth TV instead, it records the same mpeg file (again, no transcoding), but playback does not result in a CPU spike to ~100%. I am looking to better understand why the Live TV stream requires no transcoding (and little CPU overhead), but a recorded file requires transcoding and High CPU utilization - where when I use Myth TV to record and watch back (via Apple TV), there is little CPU overhead. TIA.
Luke 42242 Posted July 13, 2016 Posted July 13, 2016 When there record without the conversion feature there is little to no important l impact. It was probably something else causing the spike. Next time it happens please provide an emby server log from the same timeframe. http://emby.media/community/index.php?/topic/790-how-to-report-a-problem/?view=getnewpost
