willemavjc 0 Posted March 3, 2017 Posted March 3, 2017 Just checked. Yep! It plays wonderfully. Both with and without h/w acceleration.
Luke 42241 Posted March 4, 2017 Posted March 4, 2017 @@willemavjc are you on the Xbox Insider preview program by any chance?
Luke 42241 Posted March 4, 2017 Posted March 4, 2017 Ok, I think that is the issue, because there is another topic where numerous playback issues are being reported against the insider preview builds. But on Xbox stable version these issues are not reproducible.
willemavjc 0 Posted March 4, 2017 Posted March 4, 2017 (edited) Sorry but this is not related. Insider program has 2 sides: one for reporting issues, answering surveys, etc and one for testing M$ updates (OS, apps, etc). I am on the first one, which means I do not have access to unstable releases nor any "plus" things than any other XBO common player. Edit: Just made my brother check on his XBO, no insider. Same issues. Edited March 4, 2017 by willemavjc
Luke 42241 Posted March 4, 2017 Posted March 4, 2017 Can you provide a sample video for testing? i am not able to reproduce the issue. Thanks !
willemavjc 0 Posted March 6, 2017 Posted March 6, 2017 I'm out for a week or two. I'll send you a link asap!
barat 27 Posted May 5, 2017 Posted May 5, 2017 So I'll add something ... I have VA API enabled in DS916+, but when transcoding mpeg4 (avi, mkv, DVD iso) to iPad, Synology CPU shows 98% usage ... should it be like this?
Luke 42241 Posted May 5, 2017 Posted May 5, 2017 So I'll add something ... I have VA API enabled in DS916+, but when transcoding mpeg4 (avi, mkv, DVD iso) to iPad, Synology CPU shows 98% usage ... should it be like this? VA API is not used with mpeg4 due to it not supporting it.
barat 27 Posted May 5, 2017 Posted May 5, 2017 In Synology, or overall? Since Wikipedia says it's supported o_0 https://en.wikipedia.org/wiki/Video_Acceleration_API
Luke 42241 Posted May 5, 2017 Posted May 5, 2017 I think some mpeg4 is supported but what was happening is it we started seeing it raising errors about some levels not supported. It became more practical just to not use it at all for mpeg4: https://github.com/MediaBrowser/Emby/issues/2285 https://github.com/MediaBrowser/Emby/issues/2485 [vaapi @ 0x7f4ee88a0240] No VAAPI support for codec mpeg4 profile 15. [vaapi @ 0x7f4ee88a0240] If you want attempt decoding anyway with a possibly-incompatible profile, add the option -hwaccel_lax_profile_check. [vaapi @ 0x7f4ee88a0240] No supported configuration for this codec.vaapi hwaccel requested for input stream #0:0, but cannot be initialized. [mpeg4 @ 0x34bbf60] decoding to AV_PIX_FMT_NONE is not supported. Error while decoding stream #0:0: Operation not permitted [mpeg4 @ 0x34bc920] Context scratch buffers could not be allocated due to unknown size. Error while decoding stream #0:0: Operation not permitted
barat 27 Posted May 5, 2017 Posted May 5, 2017 (edited) Make sense ... for mpeg4 DS916+ is strong enougth to make it via CPU (some file was displayed like 96FPS) But maybe some try {} catch {} ? If no Exception then use HW, and if there is - fallback to CPU? Edited May 5, 2017 by barat
nvader2000 12 Posted September 16, 2017 Posted September 16, 2017 I am having the same issue. I have to throttle back to 20 or 25Mbps to prevent skipping or lag and even then my Synology DS3516sx is well above 90% CPU. If I could get access to the beta I will be happy to test things out.
Luke 42241 Posted September 16, 2017 Posted September 16, 2017 I am having the same issue. I have to throttle back to 20 or 25Mbps to prevent skipping or lag and even then my Synology DS3516sx is well above 90% CPU. If I could get access to the beta I will be happy to test things out. Best thing to do is attach the information requested in how to report a media playback issue. thanks !
numkem 0 Posted September 29, 2017 Posted September 29, 2017 (edited) I've been using this script to transcode the recordings from my HDhomerun. It uses the ffmpeg shipped with Emby and uses the DS916+ hardware transcoding capabilites from both the decoding and the encoding. CPU usage stays around 50-60%. Once the script finishes it deletes the ".ts" file and calls the Emby API to refresh a particular show in the library. You'll need to change the API key before being able to use the script. #!/bin/bash APIKEY=changeme if [ "$#" -ne 1 ] then echo "A valid filename is required." >&2 fi FILENAME=$(basename "$1" .ts) FILEPATH=$(dirname "$1") /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -y -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format vaapi -i "$1" -sn -c:v h264_vaapi -c:a aac "$FILEPATH/$FILENAME.mkv" if [ $? -eq 0 ] then rm -vf "$1" else exit 1 fi tvshowPath="" if [ -e "$FILEPATH/tvshow.nfo" ] then tvshowPath="$FILEPATH/tvshow.nfo" fi if [ -e "$FILEPATH/../tvshow.nfo" ] then tvshowPath="$FILEPATH/../tvshow.nfo" fi if [ ! -z "$tvshowPath" ] then tvdbid="$(cat "$tvshowPath" | grep '<id>' | grep -o '[0-9]*')" curl -v -X POST -H "content-length: 0" -H "X-MediaBrowser-Token: $APIKEY" "http://127.0.0.1:8096/mediabrowser/Library/Series/Updated?tvdbid=$tvdbid" fi exit 0 Edited September 30, 2017 by numkem
