NephilimDM 0 Posted October 19, 2016 Posted October 19, 2016 (edited) Hi solabc16, First of all, good job! I only have one small remark about the quality of conversion with VAAPI acceleration enabled. There are a lot of blocks (big blocks!) in scene changes with quality setting 720p 1Mbps or 480p 720kbps (yes I know very bad internet connection). Any suggestion? Bye, Nephilim Edited October 19, 2016 by NephilimDM
Vlaves 2 Posted October 19, 2016 Posted October 19, 2016 Hello All Release 3.0.8200.0-1 has been published today for Synology/XPEnology, which includes experimental support for VA API h/w transcoding on 'braswell' based machines. Many thanks to @@stratumorien, @@moulin and @@newb for working through this with us. Please let us know how you get on and post any comments or queries here. This is a new feature, hence comes with the tag 'experimental' and I'm sure we'll need to work through and refine a few things along the way. - James Wow awsome so this should work with a braswell CPU like the Intel Celeron N3150 with XPEnology? Regarding settings, I leave VAAPI device like "/dev/dri/card0" and ffmpeg is left to use the own version. Then I should get hardware transcoding, right?
solabc16 379 Posted October 19, 2016 Posted October 19, 2016 Hello @@Vlaves Unfortunately, it's not as straight forward as that. XPEnology is derived from the version of DSM used on the DS3615xs, which did not support h/w transcoding. For that reason, it's unlikely that the necessary support will be in the kernel. Do you currently have XPEnology running on an N3150? If so, can you run the diagnostics and send logs utilities mentioned here and I can take a closer look: https://emby.media/community/index.php?/topic/40411-xpenology-users-read-me/?p=377703 - James
stratumorien 10 Posted October 19, 2016 Posted October 19, 2016 Some media is failing to transcode with vaapi enabled. Log attached Media Info VideoCodecMPEG4Codec tagDX50Level-99Resolution720x400Aspect ratio16:9AnamorphicNoInterlacedNoFramerate30Bitrate766 kbpsPixel formatyuv420pRef frames1 AudioCodecMP3LayoutstereoChannels2 chBitrate128 kbpsSample rate44100 HzDefaultNoTitleMP3 stereo Containeravi Path/volume1/TV/Peppa Pig/Season 1/01 - Muddy Puddles.avi transcode_issue_vaapi.txt
Luke 42241 Posted October 20, 2016 Posted October 20, 2016 Some media is failing to transcode with vaapi enabled. Log attached Media Info Video CodecMPEG4Codec tagDX50 Level-99 Resolution720x400 Aspect ratio16:9 AnamorphicNo InterlacedNo Framerate30 Bitrate766 kbps Pixel formatyuv420p Ref frames1 Audio CodecMP3Layoutstereo Channels2 ch Bitrate128 kbps Sample rate44100 Hz DefaultNo TitleMP3 stereo Containeravi Path/volume1/TV/Peppa Pig/Season 1/01 - Muddy Puddles.avi No VAAPI support for codec mpeg4 profile -99. Looks like we will have to disable it for certain media.
Vlaves 2 Posted October 20, 2016 Posted October 20, 2016 Hello @@Vlaves Unfortunately, it's not as straight forward as that. XPEnology is derived from the version of DSM used on the DS3615xs, which did not support h/w transcoding. For that reason, it's unlikely that the necessary support will be in the kernel. Do you currently have XPEnology running on an N3150? If so, can you run the diagnostics and send logs utilities mentioned here and I can take a closer look: https://emby.media/community/index.php?/topic/40411-xpenology-users-read-me/?p=377703 - James Hi James, thanks for the support. Yes I run currently XPEnology on a ASROCK N3150 mini-ITX Board with 8GB of RAM. Hope the logs will help. they just got send. Filename is "sendlogs_Heimserver_synology_bromolow_3615xs_20161020T092925UTC.tgz" Hope the name is enough as it seems I can't upload the log file itself here. Thanks again for the support Hope this can be done on XPEnology too Vlaves
solabc16 379 Posted October 20, 2016 Posted October 20, 2016 Hello @@Vlaves Thanks for the logs, I have them. - James
Vlaves 2 Posted October 20, 2016 Posted October 20, 2016 (edited) Hello @@Vlaves Thanks for the logs, I have them. - James Hello James @@solabc16 No problem, just hope something can be worked out for XPEnology users too Edited October 20, 2016 by Vlaves
solabc16 379 Posted October 20, 2016 Posted October 20, 2016 No VAAPI support for codec mpeg4 profile -99. Looks like we will have to disable it for certain media. Hello Indeed, we will need to be selective here. A couple of resources I keep an eye on - https://trac.ffmpeg.org/wiki/HWAccelIntro and https://en.wikipedia.org/wiki/Intel_HD_and_Iris_Graphics ('braswell' section). - James 2
xxJonoxx 4 Posted October 22, 2016 Posted October 22, 2016 Hello, Sorry, dont want to be high jacking a thread here, did a few searches but couldnt find anything. But with this latest update, are we able to enable hardware transcoding on the DS214play model? or is that still buggy? Sorry, I tried to follow the thread, but a lot of it was over my head.
solabc16 379 Posted October 22, 2016 Posted October 22, 2016 Hello @@xxJonoxx No problem, it's all related. We've only tested on the 'braswell' based machines so far and I was about to put a message out asking if anybody with an 'evansport' (DS214play, DS415play) based machine would like to test. If possible, could you run the diagnostics and send logs utilities, details below? >> Diagnostics: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Run-Diagnostics >> Send Logs : https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs No need to post the output here, just the file reference the send logs utility will give you. If you're not running 3.0.8300, then I would recommend upgrading to that version first. - James
xxJonoxx 4 Posted October 22, 2016 Posted October 22, 2016 Wow, thanks for the quick reply James. Its a bit late where I am right now, but I will be more than happy to give it a go for you tomorrow.
solabc16 379 Posted October 22, 2016 Posted October 22, 2016 No problem, will pick it up with you tomorrow. - James
xxJonoxx 4 Posted October 22, 2016 Posted October 22, 2016 (edited) Hi James, Sorry, I didn't realise it was such a painless process or I would have done it last night. I have sent the logs as requested. I can also do it on a different DS214play (my sisters, if required)? Thanks for your time Cheers Jono Edit: PM'd the log name as per instructions. Edited October 22, 2016 by xxJonoxx
solabc16 379 Posted October 23, 2016 Posted October 23, 2016 Hi @@xxJonoxx Thanks for the logs, I've just taken a look at them. It looks like we'll have to take a slightly different approach for the 'evansport' based machines. I'll give it some consideration in the coming days. Best - James
Darkjeje 11 Posted October 23, 2016 Posted October 23, 2016 Hello James, Yesterday I have tested to see a movie with the option "Intel Quick Sync" and after with "Video acceleration API (VA API) and for this 2 option, I had an error when I lunched the movie. I had seen my movie only with the option "no acceleration". My movie is an h.264 .m2ts. For your help : Diagnostic script run completed, the log can be viewed at the location below... /var/packages/EmbyServer/scripts/utilities/logs/rundiags_20161023T142002UTC.log Upload completed successfully, please include this filename with your ticket... sendlogs_DiskStationJR_synology_evansport_214play_20161023T142141UTC.tgz Have a good day James
solabc16 379 Posted October 23, 2016 Posted October 23, 2016 Hello @@Darkjeje I've just published an updated beta for your platform, you should see it in Package Center now. (if not, try a manual refresh) Once you have it installed, let me know and I'll run through the next steps for testing. - James
solabc16 379 Posted October 23, 2016 Posted October 23, 2016 Hello @@xxJonoxx I've just published an updated stable for your platform, you should see it in Package Center now. (if not, try a manual refresh) Once you have it installed, let me know and I'll run through the next steps for testing. - James
Darkjeje 11 Posted October 23, 2016 Posted October 23, 2016 @@solabc16 It's up to date Thank you James
xxJonoxx 4 Posted October 23, 2016 Posted October 23, 2016 Hello @@xxJonoxx I've just published an updated stable for your platform, you should see it in Package Center now. (if not, try a manual refresh) Once you have it installed, let me know and I'll run through the next steps for testing. - James Hi James, I can see 3.0.8300.0-1 in package centre and updated to that. Cheers Jono
solabc16 379 Posted October 23, 2016 Posted October 23, 2016 (edited) Hi Jono You should have 3.0.8300.0-2 available, do you see it? - James Edited October 23, 2016 by solabc16
xxJonoxx 4 Posted October 23, 2016 Posted October 23, 2016 (edited) @@solabc16 James, yep. Looks like its updated to 0-2 now. Cheers Jono Edited October 23, 2016 by xxJonoxx
solabc16 379 Posted October 23, 2016 Posted October 23, 2016 Hi @@xxJonoxx Ok, great... I've just added you to a PM. - James
