egandt 3 Posted July 11, 2016 Posted July 11, 2016 I had a Library: /Videos/Archived/TV Shows /Videos/Current/TV shows Containing these folders. I added: /Videos/Burned/TV Shows while shows from the first 2 continue to update, those in the new directory are simply never processed, i forced a scan twice, removed the directory, scanned, added back and scanned again, no matter what I do the new folder is not processed. I tried moving a folder (AKA Show) from : /Videos/Current/TV shows to /Videos/Burned/TV Shows It disappeared. I have no idea what to do, but recreating the library is not a valid option, since it contains far to much data i had to manually update. Any idea why this folder is never read or processed? I do see something like: server-63603846001.txt:2016-07-11 17:28:53.4112 Info HttpServer: HTTP Response 204 to 10.120.25.XXXXX. Time: 13ms. https://10.120.25.YYYYYYY:ZZZZZZ/emby/Library/VirtualFolders/Paths?refreshLibrary=true&path=/Videos/Burned/TV Shows&name=TV_Shows So the log shows it is found, but I do not see anything processing shows from it. Upon the latest scan it is still not picking up anything present in it, while if I move them back to say "/Videos/Current/TV shows" they are processed. The logs contain no references to either series I placed in this directory either, after rescanning. Thanks, ERIC
Logos302 86 Posted July 11, 2016 Posted July 11, 2016 Can we get the full log when it does a library scan. With out it no one is going to be able to figure out what's going on.
egandt 3 Posted July 11, 2016 Author Posted July 11, 2016 (edited) Got it to work, by changing the name from TV Shows to TV_Shows, still looking into the logs to see if I can work out why. However there does not seem to be any reason, however given the contents of the logs, I'd prefer not to upload. Edited July 11, 2016 by egandt
Luke 42301 Posted July 12, 2016 Posted July 12, 2016 There is probably a file system related error, but unfortunately without a log file we cannot really offer much opinion about what it might be. Thanks for the info.
