ThermoDust 12 Posted July 10, 2016 Posted July 10, 2016 (edited) Where can I find the path options for the logs, localization, root, ssl, and data folders? Edited July 10, 2016 by ThermoDust
Happy2Play 9814 Posted July 11, 2016 Posted July 11, 2016 I believe this only applies to a new install. They are created in whatever location you put the system folder. Of the ones you listed only ssl path has an option.
ThermoDust 12 Posted July 11, 2016 Author Posted July 11, 2016 (edited) It seems like the config files are being ignored. As every time Emby starts it makes folders in the root of my hard drive and from what I can tell in the log it is remaking and downloading things it has done once before, into the wrong location. Windows Home Server 2011 (Just installed and updated last night) Emby Edition: 3.0.5985.0 - Emby is extracted to this location and ran using windows service. - Emby root folder - Where I have configured everything I can to store data. - What emby reports its paths as server-63603785243.txt - latest server log Edited July 11, 2016 by ThermoDust
Luke 42288 Posted July 11, 2016 Posted July 11, 2016 No, it actually makes the config files next to the system folder, so you should treat the root of the extract as the emby root and not the system folder itself.
ThermoDust 12 Posted July 11, 2016 Author Posted July 11, 2016 Could you explain that a little differently. Granted, I might understand... if I extract Emby to C:\Emby\Core then upon launch it would use C:\Emby as root and things like C:\Emby\logs, localization, ect.. would be made there?
Luke 42288 Posted July 11, 2016 Posted July 11, 2016 In your second screenshot, it looks like you tampered with the System folder that was extracted out of the zip, when you should have just left it as-is.
Happy2Play 9814 Posted July 11, 2016 Posted July 11, 2016 (edited) I put the system folder in a folder called Portable Server on my desktop. Then open system folder and start the server. Edited July 11, 2016 by Happy2Play
ThermoDust 12 Posted July 11, 2016 Author Posted July 11, 2016 Oh! I get it now. When I extracted the zip there was a folder called system, which I renamed to Emby and moved. Your intention was people would extract the folder and leave everything alone. The newly created folder for the extraction is the root and the folder inside called System is the primary application.
