topcine 0 Posted July 10, 2016 Posted July 10, 2016 (edited) Emby Server 3.0.5985.0 is not adding the season. What can I do to fix? http://topcine.ddns.net Edited July 10, 2016 by topcine
Luke 42186 Posted July 10, 2016 Posted July 10, 2016 Hi, welcome. Yes, we can help. Can you show us what the folder structure looks like? Thanks!
Happy2Play 9800 Posted July 10, 2016 Posted July 10, 2016 This issues has been resolved in the Dev and Beta branch. If you would like you can update to beta 3.1.61.
Happy2Play 9800 Posted July 10, 2016 Posted July 10, 2016 From your first screenshot it would appear your season does not have a season number in the metadata. That might resolve your issue also.
Happy2Play 9800 Posted July 10, 2016 Posted July 10, 2016 (edited) On the website download page or change update options on server. Dashboard-Settings-Automatic Updates-Update Level Edited July 10, 2016 by Happy2Play
Happy2Play 9800 Posted July 10, 2016 Posted July 10, 2016 (edited) What issue do you mean? The screenshot in first post. No episodes showing in said Season folder, but I suspect it is a season number issue because there is not one presented in screenshot. Looks like the same issue as thefranklin and theshanman have here, but fixed in beta/dev. Edited July 10, 2016 by Happy2Play
