KMBanana 116 Posted May 19, 2021 Posted May 19, 2021 I am upgrading from the previous stable with a docker based install. Tried each RH you posted individually without any other custom CS and none but the "Normal view indicator Ribbons" made any change at all in any view/page. Tested in Chrome and Edge, tried "Empty Cache and Hard Refresh" option in both. For the Normal View option it works for on TV Series/Seasons but not for movies.
Happy2Play 9811 Posted May 19, 2021 Posted May 19, 2021 1 minute ago, KMBanana said: I am upgrading from the previous stable with a docker based install. Tried each RH you posted individually without any other custom CS and none but the "Normal view indicator Ribbons" made any change at all in any view/page. Tested in Chrome and Edge, tried "Empty Cache and Hard Refresh" option in both. For the Normal View option it works for on TV Series/Seasons but not for movies. But you are not going to have a indicator on a movie unless it is played, and then depending on what your settings are if it remains in Latest section. So I am still confused of what the issue is.
KMBanana 116 Posted May 19, 2021 Posted May 19, 2021 Ah OK I think I was expecting a ribbon even on unplayed media. Thanks for fast response
Happy2Play 9811 Posted May 19, 2021 Posted May 19, 2021 Just now, KMBanana said: Ah OK I think I was expecting a ribbon even on unplayed media. Thanks for fast response Yes there is some confusion on this as TV shows total unwatched episodes, then no indicator when completely watched. Where Movies shows a played indicator when watched. 1
