Emby Tower 34 Posted March 24, 2020 Posted March 24, 2020 And now I don't know what to say, I just pasted your code and it works like a charm. Thanks a lot!
Diedrich 380 Posted March 24, 2020 Posted March 24, 2020 And now I don't know what to say, I just pasted your code and it works like a charm. Thanks a lot!Could have been browser caching not being refreshed 1
Emby Tower 34 Posted March 25, 2020 Posted March 25, 2020 This will fix the "square" appearance of Season Posters if they no artwork and are using the Series Poster. /* Resize Season Posters */ body > div.mainAnimatedPages.skinBody.skinBody-withWindowScroll > div:nth-child(n) > div > div.verticalSection.childrenSection-x > div > div.scrollSlider.focuscontainer-x.itemsContainer.padded-left.padded-right.focusable.scrollX.hiddenScrollX > div > div > div.cardScalable > div.cardPadder-square {padding-bottom: 147%;} Before: After: What is the correct one for the actual stable version? Thanks a lot!
Happy2Play 9811 Posted March 25, 2020 Posted March 25, 2020 @@Luke is there a reason inherited Season images present in square instead of portrait still, as shown above?
Happy2Play 9811 Posted March 25, 2020 Posted March 25, 2020 What is the correct one for the actual stable version? Thanks a lot! Something like this. [data-type="Season"] div.cardScalable.cardPadder-square {padding-bottom: 147%;} 1
daedalus 434 Posted March 25, 2020 Posted March 25, 2020 (edited) the circles seem to be rendered differently on different browsers Firefox || Edge (Chorme) || and on both, the circle is still there and broader than the banner but on the season view, both look the same: Firefox || Edge (Chorme) || Edited March 25, 2020 by daedalus
Happy2Play 9811 Posted March 25, 2020 Posted March 25, 2020 the circles seem to be rendered differently on different browsers Firefox || Edge (Chorme) ff.png || edge(chorme).png and on both, the circle is still there and broader than the banner but on the season view, both look the same: Firefox || Edge (Chorme) ff.png || edge(chorme).png Because FireFox does there own thing. Add this. div.countIndicator, i.playedIndicator { background: transparent; box-shadow: none; } I personally can't tell what the difference in the 16:9 image compare. 1
Emby Tower 34 Posted March 26, 2020 Posted March 26, 2020 How can I switch to another font? I've installed Nexa Bold on all PCs, but don't find the correct css code. Thanks a lot!
daedalus 434 Posted March 26, 2020 Posted March 26, 2020 I personally can't tell what the difference in the 16:9 image compare. because there is no difference, the indicator on the season view is just "different", what leads to the same apperence in both browsers but on the season view, both look the same: Firefox || Edge (Chorme) ff.png || edge(chorme).png
Happy2Play 9811 Posted March 27, 2020 Posted March 27, 2020 How can I switch to another font? I've installed Nexa Bold on all PCs, but don't find the correct css code. Thanks a lot! Have you seen this topic? https://emby.media/community/index.php?/topic/70905-change-font-size/page-1 May have to add additional elements, like "button". All depends on what area you what to change.
Emby Tower 34 Posted April 2, 2020 Posted April 2, 2020 Have you seen this topic? https://emby.media/community/index.php?/topic/70905-change-font-size/page-1 May have to add additional elements, like "button". All depends on what area you what to change. I want to use "Nexa Bold" for the whole Emby Server...
Happy2Play 9811 Posted April 2, 2020 Posted April 2, 2020 (edited) I want to use "Nexa Bold" for the whole Emby Server... So something like this, I haven't looked at all areas so there may be more elements. /*Change Font*/ html, h1, h2, h3, button {font-family: "Nexa Bold"; } Edited April 2, 2020 by Happy2Play typo in button 1
drashna 47 Posted April 7, 2020 Posted April 7, 2020 So something like this, I haven't looked at all areas so there may be more elements. /*Change Font*/ html, h1, h2, h3, button {font-family: "Nexa Bold"; } I want to use "Nexa Bold" for the whole Emby Server... I use this, and it works well: @font-face { font-family: 'Ubuntu'; font-style: normal; font-weight: normal; src: local('Ubuntu Regular'), local('Ubuntu-Regular'), url(https://fonts.gstatic.com/s/ubuntu/v11/4iCs6KVjbNBYlgoKfw72.woff2) format('woff2'); } * { font-family: 'Ubuntu'; } body * { font-family: 'Ubuntu'; } ::cue { font-family: 'Ubuntu'!important; font: 'Ubuntu'!important; } It is a fairly brute forcing of it, but it works well, and doesn't break icons/symbols. I don't know what to say as this is what I get with the code posted in post 95 and 96, no other code. LHS/RHS On 4.4.1.0, that doesn't appear to be the case anymore? At least, not for me. Series and episodes (and folders) work, but it's still a circle for movies. 1
muppet4k 10 Posted June 13, 2020 Posted June 13, 2020 Hi, how can i get the ribbon? Must i activate some plugin first?
daedalus 434 Posted June 13, 2020 Posted June 13, 2020 2 hours ago, muppet4k said: how can i get the ribbon? Must i activate some plugin first? no, just add the corresponding css code in this section in the server dashboard and be aware this only works in the webclient not in any app
daedalus 434 Posted June 13, 2020 Posted June 13, 2020 On 4/7/2020 at 3:24 PM, drashna said: On 4.4.1.0, that doesn't appear to be the case anymore? At least, not for me. Series and episodes (and folders) work, but it's still a circle for movies. still woking on latest beta 4.5.0.12 just list view is broken
muppet4k 10 Posted June 14, 2020 Posted June 14, 2020 yes i put the css in the custom css, but doesnt work. Only on the beta working?
Carlo 4561 Posted September 6, 2020 Posted September 6, 2020 @Happy2Play got a question for you. Is it possible to provide a right hand ribbon for MOVIES without a check mark or number inside it to be used only when the movie has NOT been watched (opposite of current functionality)? This to me would make more sense as any time you see the ribbon (show or movie) it means there is unwatched content. Any time there is not a ribbon everything has been watched. Possible to do that code?
PenkethBoy 2068 Posted September 6, 2020 Posted September 6, 2020 java script would be able to do that - but would need replacing on each server upgrade etc 1
BiTeTHeBiGG 13 Posted October 11, 2020 Posted October 11, 2020 (edited) Hi, may be not 100% safe, but simpler css modification for RHS without adding pseudo elements. It works with series and episodes. It does not break movies view or search view. Those I will try later. For Version 4.5.2.0 /* Episode Counter */ .countIndicator { transform: rotate(45deg); width: 75px; height: 25px; } .cardCountIndicator { right: -1.725em; } /* Episode Watched Status Vertical List */ .listItemIndicators { right: -1.4em; border-radius: 100em; box-shadow: 0 2px 2px 0 rgba(0,0,0,.14), 0 1px 5px 0 rgba(0,0,0,.12), 0 3px 1px -2px rgba(0,0,0,.2); transform: rotate(45deg); background: var(--theme-primary-color); } .listItemImageContainer { overflow: hidden; } .listItemIndicators .playedIndicator { width: 75px; box-shadow: none; transform: rotate(-45deg); background: none !important; } /* Movie Watched Status AND Episode Watched Status Within Search AND Episode Watched Status Horizontal List */ button.cardContent-button > i::before{ width: 75px; height: 25px; transform: rotate(45deg); content: ' '; background: var(--theme-primary-color); position: absolute; top: 1.3em; z-index: -1; border-radius: 100em; box-shadow: 0 2px 2px 0 rgba(0,0,0,.14), 0 1px 5px 0 rgba(0,0,0,.12), 0 3px 1px -2px rgba(0,0,0,.2); } button.cardContent-button > i{ width: 75px; height: 75px; top: -1.2em; right: -1.2em; position: absolute; } .cardContent-button .playedIndicator { background: none !important; box-shadow: none !important; } EDIT: Done, I hope it helps someone Edited October 11, 2020 by BiTeTHeBiGG 2
Happy2Play 9811 Posted April 10, 2021 Posted April 10, 2021 (edited) 4.6.0.37+ Season view /*RH Season View*/ div.listItemImageContainer-large i.listItemIndicator:before { width: 100px; height: 25px; transform: rotate(45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } div.listItemImageContainer-large i.listItemPlayedIndicator { overflow: visible; z-index: 1; background: none; box-shadow: none; } /*LH Season View*/ div.listItemImageContainer-large i.listItemIndicator:before { width: 100px; height: 25px; transform: rotate(-45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } div.listItemImageContainer-large i.listItemPlayedIndicator { overflow: visible; z-index: 1; background: none; left: -275px; box-shadow: none; } List View Movies /*RH Movie List View*/ div.listItemImageContainer-portrait i.listItemIndicator:before { width: 50px; height: 20px; transform: rotate(45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } div.listItemImageContainer-portrait i.listItemPlayedIndicator { overflow: visible; z-index: 1; background: none; box-shadow: none; } /*LH Movie List View*/ div.listItemImageContainer-portrait i.listItemIndicator:before { width: 50px; height: 20px; transform: rotate(-45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } div.listItemImageContainer-portrait i.listItemPlayedIndicator { overflow: visible; z-index: 1; box-shadow: none; background: none; left: -30px; } List View TV /*RH TV List View*/ div.listItemImageContainer-portrait .listItemIndicator-mini:before { width: 50px; height: 20px; transform: rotate(45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } div.listItemImageContainer-portrait .listItemCountIndicator { overflow: visible; z-index: 1; background: none; box-shadow: none; right: -4px; top: -3px; } /*LH TV List View*/ div.listItemImageContainer-portrait .listItemIndicator-mini:before { width: 50px; height: 20px; transform: rotate(-45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } div.listItemImageContainer-portrait .listItemCountIndicator { overflow: visible; z-index: 1; box-shadow: none; background: none; left: -4px; top: -3px; } Normal view indicator Ribbons RH /*Make Indicator into Ribbon RHS*/ .cardPlayedIndicator, .cardCountIndicator { overflow: visible; } .cardPlayedIndicator:before, .cardCountIndicator:before { width: 75px; height: 25px; transform: rotate(45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } LH /*Make Indicator into Ribbon LHS*/ .cardPlayedIndicator, .cardCountIndicator { overflow: visible; left: 0; } .cardPlayedIndicator:before, .cardCountIndicator:before { width: 75px; height: 25px; transform: rotate(-45deg); content: ' '; background: #0C57D6; z-index: -1; position: absolute; border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); } Only tested in Edge/Chrome Edited April 10, 2021 by Happy2Play
Guest Posted April 10, 2021 Posted April 10, 2021 I will have to check this out... Thanks. ( I still keep thinking about Skinning Emby completely... I wanna wait though.. )
KMBanana 116 Posted May 19, 2021 Posted May 19, 2021 Updated to 4.6.0.50 stable today and some of the ribbon changes for 4.6.0.37+ don't seem to be working for me. The only one that appears to work for me is "Normal view indicator Ribbons" and only for TV shows, not movies. They working for anyone else or is it something funky on my end?
Happy2Play 9811 Posted May 19, 2021 Posted May 19, 2021 3 minutes ago, KMBanana said: Updated to 4.6.0.50 stable today and some of the ribbon changes for 4.6.0.37+ don't seem to be working for me. The only one that appears to work for me is "Normal view indicator Ribbons" and only for TV shows, not movies. They working for anyone else or is it something funky on my end? Can you elaborate as I just applied to a newly updated system without issue.
