chef 3811 Posted January 7, 2020 Posted January 7, 2020 (edited) @@PenkethBoy Have you tried looking at the 'data-type' attribute of the element. Seems they are named after the media.type Edited January 7, 2020 by chef
PenkethBoy 2068 Posted January 7, 2020 Posted January 7, 2020 Ta will have a look to see if i missed that
PenkethBoy 2068 Posted January 7, 2020 Posted January 7, 2020 @@chef - could you give me an indication where you are seeing this cant find it in the page for an episode
chef 3811 Posted January 7, 2020 Posted January 7, 2020 It would seem that movie card elements and episode listItem elements all have the 'data-type' attribute.
PenkethBoy 2068 Posted January 7, 2020 Posted January 7, 2020 Thanks but - I am trying to control the primary image size - on the index.html/item detail page so although the page html is very similar its not quite the same as image is under but although outside that tree you can see other indications of what type of page it is - not sure how to reference those and apply the image modification etc - if its possible at all
chef 3811 Posted January 7, 2020 Posted January 7, 2020 (edited) Ah, I see. You could through the magic of intersectionObserver, or maybe a mutationObserver.Or, go straight to the source in the detailPage.jsBut, all would be lost in update. EDIt: Actually, that's a really difficult one. Edited January 7, 2020 by chef
PenkethBoy 2068 Posted January 7, 2020 Posted January 7, 2020 Yeah - thought so - as CSS does not have a if/then implemented to pick a variable from a diff tree of divs etc Thanks anyway
Happy2Play 9811 Posted March 17, 2020 Posted March 17, 2020 Anyone see a way to fix ribbon indicator check rotation as of 4.4.0.27? I'm not currently seeing one.
Happy2Play 9811 Posted March 17, 2020 Posted March 17, 2020 (edited) What css is being used now to do that?Looks like you now combine .playedIndicator and .playedIndicator i, so there is only one element now.code we were using. /*Make Played Indicator into Ribbon LHS*/ .playedIndicator i, .syncIndicator i { font-size: 150%; transform: rotate(45deg); } .card .playedIndicator, .card .countIndicator {width: 75px; height: 25px; border-radius: 0%; transform: rotate(-45deg); border-style: solid; border-width: 1px; border-color: rgba(255, 255, 255, 0.5); display: flex; align-items: center; justify-content: center; left: -21px; } Edited March 17, 2020 by Happy2Play
Luke 42239 Posted March 17, 2020 Posted March 17, 2020 You can probably figure something out with a pseudo element: .cardPlayedIndicator { font-size: 150%; transform: rotate(45deg); background-color: transparent!important; overflow: visible; } .cardPlayedIndicator:before { width: 75px; height: 25px; border-radius: 0%; transform: rotate(-180deg); display: flex; align-items: center; justify-content: center; left: -21px; content: ' '; background: red; z-index: -1; position: absolute; right: 0; top: 0; }
Happy2Play 9811 Posted March 17, 2020 Posted March 17, 2020 You can probably figure something out with a pseudo element: .cardPlayedIndicator { font-size: 150%; transform: rotate(45deg); background-color: transparent!important; overflow: visible; } .cardPlayedIndicator:before { width: 75px; height: 25px; border-radius: 0%; transform: rotate(-180deg); display: flex; align-items: center; justify-content: center; left: -21px; content: ' '; background: red; z-index: -1; position: absolute; right: 0; top: 0; } But you can't rotate the icon without rotating the ribbon since they are one now.
Luke 42239 Posted March 17, 2020 Posted March 17, 2020 They both have different rotation values so you just have to play with it. Try removing the rotation from the icon and setting the rotation of the pseudo element to 45.
Happy2Play 9811 Posted March 17, 2020 Posted March 17, 2020 (edited) They both have different rotation values so you just have to play with it. Try removing the rotation from the icon and setting the rotation of the pseudo element to 45. I must be doing something wrong as it rotates both equally (ribbon and icon). Edited March 17, 2020 by Happy2Play
Luke 42239 Posted March 17, 2020 Posted March 17, 2020 Well i'm not sure what the end goal is of what you want it to look like, but based on screenshots in this thread it seems like you want the checkmark displaying straight up normally and not on an angle. So giving it a rotation of 0 plus 45 for the pseudo element does that.
daedalus 434 Posted March 17, 2020 Posted March 17, 2020 season view now has tiny watched icons the same on every change
Happy2Play 9811 Posted March 18, 2020 Posted March 18, 2020 (edited) Okay something like this. RH Ribbon /*Make Played Indicator into Ribbon RHS*/ .cardPlayedIndicator, .cardCountIndicator { overflow: visible; } .cardPlayedIndicator:before, .cardCountIndicator:before { width: 75px; height: 25px; transform: rotate(45deg); content: ' '; background: blue; z-index: -1; position: absolute; } LH Ribbon /*Make Played Indicator into Ribbon LHS*/ .cardPlayedIndicator, .cardCountIndicator { overflow: visible; left: 0; } .cardPlayedIndicator:before, .cardCountIndicator:before { width: 75px; height: 25px; transform: rotate(-45deg); content: ' '; background: blue; z-index: -1; position: absolute; } No change to Folders indicator /*Make Folder Indicator into Ribbon LHS*/ div.videoIndicator { transform: rotate(-45deg); width: 75px; left: -21px; border-radius: 0%; background: rgba(30,30,30,.7); border-style: solid; border-width: 1px;} div.videoIndicator i {transform: rotate(45deg);} Haven't looked at list views yet or season list. As of 4.4.0.28 Edited March 24, 2020 by Happy2Play fixed background issue 1
Happy2Play 9811 Posted March 18, 2020 Posted March 18, 2020 (edited) Season RH Ribbon /*Ribbon RH Season level*/ div.listItemImageContainer-large {overflow: hidden;} div.indicators.listItemIndicators .playedIndicator {z-index: 0;} div.indicators.listItemIndicators .playedIndicator:before { width: 75px; height: 25px; transform: rotate(45deg); background: blue; z-index: -1; position: absolute; content: ""; } Season LH Ribbon /*Ribbon LH Season level*/ div.listItemImageContainer-large {overflow: hidden;} div.listItemIndicators {left: 5px;} div.indicators.listItemIndicators .playedIndicator {z-index: 0;} div.indicators.listItemIndicators .playedIndicator:before { width: 75px; height: 25px; transform: rotate(-45deg); background: blue; z-index: -1; position: absolute; content: ""; } As of 4.4.0.28 List views will require different targeting altogether do to Season level overlap. Edited March 24, 2020 by Happy2Play fixed background issue 1
Emby Tower 34 Posted March 23, 2020 Posted March 23, 2020 @Happy2Play: I just tried your new ribbon code, but it doesn't work. There are stil the "dots"! Tested with actual stable version. 1
Happy2Play 9811 Posted March 24, 2020 Posted March 24, 2020 (edited) @Happy2Play: I just tried your new ribbon code, but it doesn't work. There are stil the "dots"! Tested with actual stable version. Hmm, not sure what happened in testing but actually apply a background color instead of "background: var(--theme-primary-color)" changed code about to apply specific color. Edited March 24, 2020 by Happy2Play
Happy2Play 9811 Posted March 24, 2020 Posted March 24, 2020 season view still has tiny watched icons I don't know what to say as this is what I get with the code posted in post 95 and 96, no other code. LHS/RHS
