FordGT90Concept 103 Posted July 5, 2016 Posted July 5, 2016 I have a Leelbox with Amlogic S905 chip and it came with a remote that isn't satisfactory (doesn't even have a play button!). It has Emby Android TV installed and works great. Any recommendations for a third party remote to use? Specifically, I would like play, record, jump forward, jump backward, fast forward, and fast backward working. I was thinking a Logitech Harmony 650 for my main home theater then something cheaper for the other TVs (open to suggestions).
ebr 16337 Posted July 5, 2016 Posted July 5, 2016 I use the Harmony Home Hub with the small remote that used to come with it (I think the newer ones are larger). Works well. One note, there is no fast forward or rewind on the device. Just jump forward and back.
FordGT90Concept 103 Posted July 5, 2016 Author Posted July 5, 2016 (edited) It doesn't look like it has a remote with it: https://www.amazon.com/Logitech-915-000238-Smartphone-Entertainment-Automation/dp/B00N3RFC4Q • Harmony Home Hub • IR mini-blaster • USB cable • AC adapter • User documentation The app appears to only be available on Android and iOS--all my phones are Windows. But the hand held remote should have the same compatibilities, no? Edit: This one stands out (Inteset INT-422): https://www.amazon.com/gp/product/B00M4JYTWA/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A284XEE8MWZJWL It mentions NVIDIA Shield Android TV. Edited July 5, 2016 by FordGT90Concept
