heula 192 Posted July 5, 2016 Posted July 5, 2016 I have a HD homerun with 4 tuners and I have DVBlink software to have a guide available. In Emby Server I see one HDHomerun Tuner and the dvblink client that is installed to have my guide and channel order right. I figured out that when HD Homerun Tuner is enabled I have a guide with double channels and channels I don't want to see. So I disabled the tuner and deleted it and after a guide refresh my guide and channels were normal agian like I want it to. But when I restart my pc or the emby server that same HD homerun tuner is back and I have a double guide again. How can I prevent Emby from enabling that tuner constantly. The dvblink plugin only does excactly what I need to see.
Solution bluemonkey07 590 Posted July 5, 2016 Solution Posted July 5, 2016 Just disable it and don't delete it 1
Luke 42242 Posted July 5, 2016 Posted July 5, 2016 Or consider using the built-in features because they are being directly tested by the core team and probably offer the most efficient playback performance.
heula 192 Posted July 5, 2016 Author Posted July 5, 2016 Or consider using the built-in features because they are being directly tested by the core team and probably offer the most efficient playback performance. I don't know what you mean by that. How do I do this? I tried earlier to remove the dvblink plugin and added a xml file for my guide but that didnt give me the guide it gives me with dvblink. Dvblink uses that same xml file to get my guide info with webgrab.
Luke 42242 Posted July 5, 2016 Posted July 5, 2016 Then check out how to report a problem and we can look into that. Thanks!
