solabc16 379 Posted July 4, 2016 Posted July 4, 2016 (edited) Evening The Web UI still shows that there are trailers available (i.e. displays 1-100 of 1583), however they are no longer being displayed after the update to v3.0.5984. I've tried uninstalling and re-installing the plugin, but it won't uninstall - it disappears from the UI after the uninstall, but it re-appears after the restart; this behaviour isn't specific to v3.0.5984. Best - James Edited July 4, 2016 by solabc16
ebr 16340 Posted July 5, 2016 Posted July 5, 2016 Has your "Clean Database" task run entirely to completion since the upgrade?
solabc16 379 Posted July 5, 2016 Author Posted July 5, 2016 (edited) Morning Looking at the last run time, I can see that it has run. I've also run it manually and restarted the server, but to no avail. I've also tried changing the settings, saving, then changing them back and saving again to see if this has any impact. Clean set of logs that contain this and the Auto Box Sets issue attached. - James UPDATE: This appears to work OK in iOS appications and Theatre, the Web UI appears to be the problem. sendlogs_JFK_synology_avoton_1815+_20160705T081637UTC.tgz Edited July 5, 2016 by solabc16
solabc16 379 Posted July 5, 2016 Author Posted July 5, 2016 Afternoon After a little bit more digging, this appears to be a browser issue - Chrome - OK Firefox - Broken IE - OK Safari - Web UI Doesn't Load At All (same on mobile devices) - James
Solution solabc16 379 Posted July 18, 2016 Author Solution Posted July 18, 2016 Confirmed fixed with version 3.0.5985 or later, considered closed. 1
