solabc16 379 Posted July 4, 2016 Posted July 4, 2016 Evening In the Web UI, these are no longer being displayed after updating to v3.0.5984, but the data does still appear to exist in Metadata Manager. Best - James
ebr 16340 Posted July 5, 2016 Posted July 5, 2016 Has your "Clean Database" task run entirely to completion since the upgrade?
solabc16 379 Posted July 5, 2016 Author Posted July 5, 2016 (edited) Morning Looking at the last run time, I can see that it has run. I've also ran it manually and restarted the server, but to no avail. I've also tried changing the settings, saving, then changing them back and saving again to see if this has any impact. The manual 'refresh box sets' does not change the behaviour either. Clean set of logs that contain this and the Auto Box Sets issue attached. - James UPDATE: This appears to work OK in iOS appications and Theatre, the Web UI appears to be the problem. sendlogs_JFK_synology_avoton_1815+_20160705T081637UTC.tgz Edited July 5, 2016 by solabc16
solabc16 379 Posted July 5, 2016 Author Posted July 5, 2016 Afternoon After a little bit more digging, this appears to be a browser issue - Chrome - OK Firefox - Broken IE - OK Safari - Web UI Doesn't Load At All (same on mobile devices) - James
Solution solabc16 379 Posted July 18, 2016 Author Solution Posted July 18, 2016 Confirmed fixed with version 3.0.5985 or later, considered closed. 2
