mentasm 43 Posted September 6, 2016 Author Posted September 6, 2016 Works fine in tv.emby.media. Still won't load in ET client
mentasm 43 Posted September 6, 2016 Author Posted September 6, 2016 Anyway to change skin outside the UI. currently stuck in a situation where I can't even get to settings to select the default skin.
mentasm 43 Posted September 7, 2016 Author Posted September 7, 2016 (edited) I seem to be stuck now. HAve even tried an uninstall (delete all traces) and a re-install of ET. Still have the same issue. When I start ET it loads to a black screen with just the emby logo, back button, minimize, maximise and close buttons and nothing else. esc or backspace or clicking the back arrow up the top just quit out to windows. Can't get into settings to change anyting I'm not sure what else to try. Currently stuck not able to use ET at all. @@Luke or someone got any ideas? Would just like to be able to run ET with default skin Edited September 7, 2016 by mentasm
mentasm 43 Posted September 7, 2016 Author Posted September 7, 2016 let it sit a few minutes and it fially prompted me to select my user and now it is loading
chef 3811 Posted September 7, 2016 Posted September 7, 2016 Will the themes that get forked and submitted to GIthub go through any selection process before they appear in the GUI for use? Just wondering
