carlos515 0 Posted June 28, 2016 Posted June 28, 2016 Hi, I have an audio sync issue with Emby Theatre. I have tried a few 1080p mkv movies. Kodi plays them with no problems and plex played them also. Any help would be appreciated . server log.txt
Guest asrequested Posted June 29, 2016 Posted June 29, 2016 Hi, I have an audio sync issue with Emby Theatre. I have tried a few 1080p mkv movies. Kodi plays them with no problems and plex played them also. Any help would be appreciated . How do you have your settings configured?
carlos515 0 Posted June 29, 2016 Author Posted June 29, 2016 Hi, I have tried your settings and the same sync error happens. I put the MADVR on with your settings and the video was jerky and slow. I now have the same settings except EVR+ and filter stable. Do I need to install codec's with EMBY ?
carlos515 0 Posted June 30, 2016 Author Posted June 30, 2016 It's ok now. I uninstalled everything. Then installed lav filter. Then installed server and theater. Now it all works great.
Guest asrequested Posted June 30, 2016 Posted June 30, 2016 It's ok now. I uninstalled everything. Then installed lav filter. Then installed server and theater. Now it all works great. I'm glad it's working now, but for future reference: ET has its own LAV codecs/filters. The external version you have installed, won't have any involvement. It's most likely that the re-installation corrected the issue
