ytzelf 2 Posted June 28, 2016 Posted June 28, 2016 (edited) Hello everyone, I seem to have 2 emby processes running, one is running as root (dont want) with the correct MONO_THREADS_PER_CPU and MONO_GC_PARAMS arguments, and one running as emby user (all good) without these arguments. ps auxZ | grep emby root 784 0.0 0.0 46360 3224 ? Ss 12:59 0:00 su -s /bin/sh -c exec "$0" "$@" emby -- env MONO_THREADS_PER_CPU=250 MONO_GC_PARAMS=nursery-size=128m /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh emby 894 2.5 4.5 1452236 370664 ? Ssl 12:59 1:43 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Is having 2 processes normal? why is one running as root? And lastly, how do I fix this if it is indeed abnormal? How do I get 1 process with the cirrect arguments running as emby user? nano /etc/systemd/system/multi-user.target.wants/emby-server.service [Unit]Description=Emby Media Server After=network.target [Service] EnvironmentFile=/etc/emby-server.conf ExecStart=/usr/bin/emby-server start Restart=on-abort TimeoutSec=20 ExecStopPost=/usr/bin/emby-server clear [Install] WantedBy=multi-user.target nano /etc/init.d/emby-server !/bin/sh### BEGIN INIT INFO # Provides: emby-server # Required-Start: $remote_fs $local_fs $network # Required-Stop: $remote_fs $local_fs $network # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: starts instance of Emby # Description: starts instance of Emby ### END INIT INFO # chkconfig: 2345 20 80 #The above indicates that the script should be started in levels 2, 3, 4, and 5, #that its start priority should be $ # Load the VERBOSE setting and other rcS variables . /lib/init/vars.sh # Define LSB log_* functions. # Depend on lsb-base (>= 3.0-6) to ensure that this file is present. . /lib/lsb/init-functions NAME=emby-server CONF_FILE=/etc/${NAME}.conf DEFAULT_FILE=/etc/default/${NAME} # Source Emby server default configuration . $DEFAULT_FILE # Source Emby server user configuration overrides if [ -f $CONF_FILE ]; then . $CONF_FILE else echo "${CONF_FILE} not found using default settings."; fi # Path of emby binary EMBYSERVER=/usr/bin/emby-server PIDFILE=${EMBY_PIDFILE-/var/run/emby-server.pid} case "$1" in start) log_daemon_msg "Starting $NAME daemon" if [ -s $PIDFILE ] && kill -0 $(cat $PIDFILE) >/dev/null 2>&1; then log_daemon_msg "apparently already running" log_end_msg 0 exit 0 fi exec $EMBYSERVER start & sleep 2 if [ -s $PIDFILE ] && kill -0 $(cat $PIDFILE) >/dev/null 2>&1; then log_end_msg 0 else log_end_msg 1 fi stop) log_daemon_msg "Stopping $NAME daemon" if [ ! -s $PIDFILE ] || ! kill -0 $(cat $PIDFILE) >/dev/null 2>&1; then [ -e $PIDFILE ] && rm -rf $PIDFILE log_success_msg "apparently already stopped" log_end_msg 0 exit 0 fi PID=`cat $PIDFILE` CPIDS=$(pgrep -P $PID) sleep 2 && kill -KILL $CPIDS kill -TERM $CPIDS > /dev/null 2>&1 sleep 2 if ! kill -0 $PID > /dev/null 2>&1; then rm -rf $PIDFILE log_end_msg 0 else log_end_msg 1 fi ;; status) status_of_proc -p $PIDFILE "$EMBYSERVER" "$NAME" exit $? # notreached due to set -e ;; restart|force-reload) $0 stop || exit $? $0 start || exit $? ;; *) echo "Usage: /etc/init.d/emby-server {start|stop|status|restart|force-reload}" >&2 exit 3 ;; esac Thanks Edited June 28, 2016 by ytzelf
Luke 42243 Posted June 28, 2016 Posted June 28, 2016 Hi, great investigation although unforuntatley I'm not sure. i haven't heard of this happening before. there should never be one running as root. i would just shut that one down.
ytzelf 2 Posted June 28, 2016 Author Posted June 28, 2016 Thanks but I can't be bothered to shut it down everytime i reboot the server. Is it normal to have both an init.d script and a .service file? thought the error might come from me having both.. Is there a way to check what launched the root user process at startup?
gsnerf 26 Posted June 29, 2016 Posted June 29, 2016 Hi, having scripts for different init systems installed at the same time shouldn't be a problem as long as there is only one init system active. I'd say this is the usual case (I'm not even sure if multiple init systems CAN be active at the same time). What output does ps auxf give you? This should print a tree for child processes of the actual process. On a quick glimpse I see a restart script incorporated, maybe a restart is tried and somehow doesn't finish the original process while doing so? I'll have a deeper look when I get home but it would help to know which script is actually started. Additionally: which linux distribution do you have this running on and how have you installed it? (premade package or setup manually?)
ytzelf 2 Posted June 29, 2016 Author Posted June 29, 2016 (edited) hello and thanks for your help! ps auxf root 18702 0.0 0.0 46360 3028 ? Ss 10:28 0:00 su -s /bin/sh -c exec "$0" "$@" emby -- env MONO_THREADS_PER_CPU=250 MONO_GC_PARAMS=nursery-size=128m /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowse emby 18713 3.6 5.7 1552548 467064 ? Ssl 10:28 9:39 \_ /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg YADA YADA The non root process is child to the root process I don' think restart script is in cause as number of processes never exceed 2 May also be useful service emby-server status -l ● emby-server.service - Emby Media Server Loaded: loaded (/lib/systemd/system/emby-server.service; disabled) Active: active (running) since Wed 2016-06-29 10:28:58 CEST; 4h 29min ago Process: 18603 ExecStopPost=/usr/bin/emby-server clear (code=exited, status=0/SUCCESS) Main PID: 18702 (su) CGroup: /system.slice/emby-server.service ├─18702 su -s /bin/sh -c exec "$0" "$@" emby -- env MONO_THREADS_PER_CPU=250 MONO_GC_PARAMS=nursery-size=128m /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emb... └─18713 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /usr/lib/emby-server/restart.s... Jun 29 10:28:58 ytzelf su[18702]: Successful su for emby by root Jun 29 10:28:58 ytzelf su[18702]: + ??? root:emby Jun 29 10:28:58 ytzelf su[18702]: pam_unix(su:session): session opened for user emby by (uid=0) I'm running emby-server-beta on debian 8 and installed following the process here : https://software.opensuse.org/download.html?project=home%3Aemby&package=emby-server-beta Edited June 29, 2016 by ytzelf
Solution gsnerf 26 Posted June 29, 2016 Solution Posted June 29, 2016 As far as I can see the first process is the start script (/usr/bin/emby-server) propably running as root as it is started by the systemd init script. That process is using su to change the user to emby and start the actual emby process. So emby-server is actually running as user emby, only the spawning process (which does nothing but wait that emby is stopping) is running as root. There propably is a way to change how the process is started, but I don't think you have to worry about emby itself running as the wrong user. 2
ytzelf 2 Posted June 30, 2016 Author Posted June 30, 2016 Thanks, that's kind of the answer I was hoping for
fc7 123 Posted June 30, 2016 Posted June 30, 2016 As far as I can see the first process is the start script (/usr/bin/emby-server) propably running as root as it is started by the systemd init script. That process is using su to change the user to emby and start the actual emby process. So emby-server is actually running as user emby, only the spawning process (which does nothing but wait that emby is stopping) is running as root. There propably is a way to change how the process is started, but I don't think you have to worry about emby itself running as the wrong user. This is correct. Nothing to worry about. Emby process is only spawn once. Sent from my iPhone using Tapatalk
