gvega 0 Posted June 28, 2016 Posted June 28, 2016 Hi, i unlock a licence of android TV emby, everything that i play is on PCM stereo, but i tried several formats (DTS, DD) can you please point me how do i have to configure the server and the client in order to get DD5.1 and DTS passthrough, i buy the app because i thought it was supported, i'm usin a SONY KDL 50w805C Android TV 5.1.1
ebr 16337 Posted June 28, 2016 Posted June 28, 2016 I don't think any of the TVs support DTS. Do you have the "Bitstream Audio" Checkbox selected in the app settings?
gvega 0 Posted June 29, 2016 Author Posted June 29, 2016 I don't think any of the TVs support DTS. Do you have the "Bitstream Audio" Checkbox selected in the app settings? My TV has optical spdif output as ussual and from there to my audio receiver that is DD and DTS capable, i need to know how to configure to passthrough the signal... this works OK on Kodi, i want the same for Emby. That's why i choose to buy the app
mmb 5 Posted June 29, 2016 Posted June 29, 2016 The native Android Player and VLC doesn't support DTS bitstream on Android 5.(1.1). Android 6 should do this, so you have to wait for an update
mmb 5 Posted June 29, 2016 Posted June 29, 2016 PS: DD should work, but i heard about some optical issues on the Sony TVs. I use the ARC connection, which works fine with DD 1
