feerlessleadr 173 Posted June 26, 2016 Posted June 26, 2016 Hi all, I'm trying to install the emby for FireTV app into my parent's firetv,and when I search on the FireTV the app doesn't show up. When I search online, it states that neither of my parents' FireTV boxes are compatible. They have a gen 1 FireTV updated to the latest version. Is there anything I am missing?
Solution ebr 16337 Posted June 27, 2016 Solution Posted June 27, 2016 No, it is definitely compatible with the Gen 1. Try re-starting the device. 1
feerlessleadr 173 Posted June 27, 2016 Author Posted June 27, 2016 So I restarted the device to no avail. I did a factory reset and it is not showing up, even after that.
feerlessleadr 173 Posted June 27, 2016 Author Posted June 27, 2016 OK,not sure what I did or what changed,but I just restarted again, and it is showing up. Thanks!
