Marcelo 3 Posted June 26, 2016 Posted June 26, 2016 (edited) Hello, I've being having some problems with marshmallow. What is happening is that on a galaxy Note 5 music plays for just around 20 seconds then stops. I started to verify why and saw that the green bar indicating the seconds of the song are never moving. Looking at the server just the red transcoding bar is being filled. The green playing bar is not. I'm attaching pictures to show that. If I downgrade my android to version 5.1.1 everything is back to normal. I don't know if it's something related to the new permissions on marshmallow. What I saw also is that when trying to sync music files it does copy to the right folder in android but emby does not show the sync symbols on the files as if they were not synced. I'm sending the logs also. My phone does not use external sd only internal storage. Thanks in advance. Marcelo. server-63602496000.txt transcode-1b849b5e-9feb-4cb9-b542-b81efa3e7e71.txt cf89b48b-73d3-42fe-b4e7-be95f6135112.log Edited June 26, 2016 by Marcelo
