ryrush22 2 Posted June 25, 2016 Posted June 25, 2016 Hello - I received the notice that version 3.0.5972 of the Emby Windows Server was available. I downloaded the Stable Release setup.exe file and executed it. The setup process starts, it does the "verifying application requirements" step window and then pops up an error message/box titled "Cannot Start Application" and a message that the "Application cannot be started. Contact the application vendor." Clicking the Details... button opens a log file which I've attached. I've copied the ERROR SUMMARY section from the log file below: ERROR SUMMARY Below is a summary of the errors, details of these errors are listed later in the log. * Activation of http://emby.media/emby/server/release/MediaBrowser.Server.Installer.application resulted in exception. Following failure messages were detected: + Activation failed. + The system cannot find the file specified. (Exception from HRESULT: 0x80070002) Anyone have suggestions of what's going on here? Thanks for everyone's help. I've always appreciated the Emby developers and the user community. EmbyServer_InstallLogResults.txt
Solution Luke 42202 Posted June 25, 2016 Solution Posted June 25, 2016 Hi, try this: http://emby.media/community/index.php?/topic/10553-cannot-install-server-or-mbtemc/&do=findComment&comment=132315 1
ryrush22 2 Posted June 25, 2016 Author Posted June 25, 2016 Thanks, so much ... that did the trick. Sorry I missed this in my initial searches, but thanks for pointing me to it!
wizbowes 4 Posted July 3, 2017 Posted July 3, 2017 Hi, try this: http://emby.media/community/index.php?/topic/10553-cannot-install-server-or-mbtemc/&do=findComment&comment=132315 I have the same problem. I've tried clearing the cache - no dice. I'm on Windows7 - I'm assuming that the second step is only for windows server users? In which case I'm out of luck?
Luke 42202 Posted July 3, 2017 Posted July 3, 2017 Hi @@wizbowes, this is an old topic. Can you please describe your issue in your own words? thanks !
