squirrellydw 9 Posted June 24, 2016 Posted June 24, 2016 Is there an ideal size for channel icons in the guide? I use schedules direct and would like to modify and make some new icons that looks better but want to know the correct size before I do. Thanks
Luke 42243 Posted June 24, 2016 Posted June 24, 2016 Not really, the apps will scale as needed so it doesn't really matter.
ebr 16337 Posted June 24, 2016 Posted June 24, 2016 Size, no but as for shape I wouldn't get to radical of an aspect ratio. Stick to no more than about 1.5:1. Otherwise, if they are scaled into a squareish box, they may not be readable or look good.
squirrellydw 9 Posted June 24, 2016 Author Posted June 24, 2016 Thanks, plan on making them as square as possible
squirrellydw 9 Posted June 24, 2016 Author Posted June 24, 2016 (edited) So after I upload a new one, how long till it shows up on the FireTV guide? Shows up in the web player but not FireTV. Also how can I get the original icon back Edited June 24, 2016 by squirrellydw
Luke 42243 Posted June 25, 2016 Posted June 25, 2016 To get the original back you'd just have to delete your custom one and then let the guide refresh bring it back later.
ebr 16337 Posted June 25, 2016 Posted June 25, 2016 So after I upload a new one, how long till it shows up on the FireTV guide? Shows up in the web player but not FireTV. Not sure how they could be different actually. Have you re-started the app?
squirrellydw 9 Posted June 25, 2016 Author Posted June 25, 2016 yeah I had to restart the app on the FireTV and its all good now. Just can't stand how some of the icons are black letters, makes it hard to see.
