cachaca 6 Posted April 24, 2017 Posted April 24, 2017 (edited) side note: even in tests outside Emby.. I see that the console output is different. the OMX version has no summary while the non-OMX version displays some sort of activity summary at the end of the Encoding process. No idea how that affects your code...if at all. You can see the "broken" process call stops at the stream mappings... then quits. While the "valid" run on the same file has the encoding progress log. OMX Output: [h264_omx @ 0x3321740] Using OMX.broadcom.video_encode Output #0, mp4, to 'test-omx.mp4': Metadata: encoder : Lavf57.72.101 Stream #0:0: Video: h264 (h264_omx) ([33][0][0][0] / 0x0021), yuv420p, 704x480 [SAR 10:11 DAR 4:3], q=2-31, 1500 kb/s, 29.97 fps, 30k tbn, 29.97 tbc (default) Metadata: BPS : 979595 BPS-eng : 979595 DURATION : 00:00:41.708000000 DURATION-eng : 00:00:41.708000000 NUMBER_OF_FRAMES: 1250 NUMBER_OF_FRAMES-eng: 1250 NUMBER_OF_BYTES : 5107120 NUMBER_OF_BYTES-eng: 5107120 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-09 17:45:19 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-09 17:45:19 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES encoder : Lavc57.93.100 h264_omx Stream #0:1(eng): Audio: aac (LC) ([64][0][0][0] / 0x0040), 48000 Hz, stereo, fltp (default) Metadata: BPS : 86457 BPS-eng : 86457 DURATION : 00:00:41.706000000 DURATION-eng : 00:00:41.706000000 NUMBER_OF_FRAMES: 1955 NUMBER_OF_FRAMES-eng: 1955 NUMBER_OF_BYTES : 450726 NUMBER_OF_BYTES-eng: 450726 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-09 17:45:19 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-09 17:45:19 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES frame= 1250 fps= 61 q=-0.0 Lsize= 8390kB time=00:00:41.70 bitrate=1648.1kbits/s speed=2.02x video:7906kB audio:440kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.527222% non-OMX output: ffmpeg version N-85641-gdd49eff Copyright (c) 2000-2017 the FFmpeg developers built with gcc 4.9.2 (Raspbian 4.9.2-10) configuration: --enable-gpl --enable-nonfree --enable-mmal --enable-omx --enable-omx-rpi --enable-libmp3lame --enable-libx264 --enable-libvorbis libavutil 55. 61.100 / 55. 61.100 libavcodec 57. 93.100 / 57. 93.100 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 86.100 / 6. 86.100 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Input #0, matroska,webm, from '../Sample.mkv': Metadata: encoder : libebml v1.3.1 + libmatroska v1.4.2 creation_time : 2016-02-09T17:45:19.000000Z Duration: 00:00:41.73, start: 0.000000, bitrate: 1069 kb/s Stream #0:0: Video: hevc (Main), yuv420p(tv), 704x480 [SAR 38052:3505 DAR 279048:17525], SAR 10:11 DAR 4:3, 29.97 fps, 29.97 tbr, 1k tbn, 29.97 tbc (default) Metadata: BPS : 979595 BPS-eng : 979595 DURATION : 00:00:41.708000000 DURATION-eng : 00:00:41.708000000 NUMBER_OF_FRAMES: 1250 NUMBER_OF_FRAMES-eng: 1250 NUMBER_OF_BYTES : 5107120 NUMBER_OF_BYTES-eng: 5107120 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-09 17:45:19 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-09 17:45:19 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default) Metadata: BPS : 86457 BPS-eng : 86457 DURATION : 00:00:41.706000000 DURATION-eng : 00:00:41.706000000 NUMBER_OF_FRAMES: 1955 NUMBER_OF_FRAMES-eng: 1955 NUMBER_OF_BYTES : 450726 NUMBER_OF_BYTES-eng: 450726 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-09 17:45:19 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-09 17:45:19 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream mapping: Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [libx264 @ 0x329c740] using SAR=10/11 [libx264 @ 0x329c740] using cpu capabilities: ARMv6 NEON [libx264 @ 0x329c740] profile High, level 3.0 [libx264 @ 0x329c740] 264 - core 142 r2431 a5831aa - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=abr mbtree=1 bitrate=1500 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00 Output #0, mp4, to 'test-264.mp4': Metadata: encoder : Lavf57.72.101 Stream #0:0: Video: h264 (libx264) ([33][0][0][0] / 0x0021), yuv420p, 704x480 [SAR 10:11 DAR 4:3], q=-1--1, 1500 kb/s, 29.97 fps, 30k tbn, 29.97 tbc (default) Metadata: BPS : 979595 BPS-eng : 979595 DURATION : 00:00:41.708000000 DURATION-eng : 00:00:41.708000000 NUMBER_OF_FRAMES: 1250 NUMBER_OF_FRAMES-eng: 1250 NUMBER_OF_BYTES : 5107120 NUMBER_OF_BYTES-eng: 5107120 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-09 17:45:19 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-09 17:45:19 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES encoder : Lavc57.93.100 libx264 Side data: cpb: bitrate max/min/avg: 0/0/1500000 buffer size: 0 vbv_delay: -1 Stream #0:1(eng): Audio: aac (LC) ([64][0][0][0] / 0x0040), 48000 Hz, stereo, fltp (default) Metadata: BPS : 86457 BPS-eng : 86457 DURATION : 00:00:41.706000000 DURATION-eng : 00:00:41.706000000 NUMBER_OF_FRAMES: 1955 NUMBER_OF_FRAMES-eng: 1955 NUMBER_OF_BYTES : 450726 NUMBER_OF_BYTES-eng: 450726 _STATISTICS_WRITING_APP: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_APP-eng: mkvmerge v8.2.0 ('World of Adventure') 64bit _STATISTICS_WRITING_DATE_UTC: 2016-02-09 17:45:19 _STATISTICS_WRITING_DATE_UTC-eng: 2016-02-09 17:45:19 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES frame= 1250 fps= 11 q=-1.0 Lsize= 9303kB time=00:00:41.70 bitrate=1827.5kbits/s speed=0.355x video:8813kB audio:440kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.544319% [libx264 @ 0x329c740] frame I:23 Avg QP:14.82 size: 44723 [libx264 @ 0x329c740] frame P:737 Avg QP:21.93 size: 9476 [libx264 @ 0x329c740] frame B:490 Avg QP:21.17 size: 2063 [libx264 @ 0x329c740] consecutive B-frames: 42.0% 15.4% 5.5% 37.1% [libx264 @ 0x329c740] mb I I16..4: 14.7% 46.1% 39.3% [libx264 @ 0x329c740] mb P I16..4: 1.8% 10.4% 4.5% P16..4: 31.9% 9.6% 5.1% 0.0% 0.0% skip:36.6% [libx264 @ 0x329c740] mb B I16..4: 0.2% 0.6% 0.7% B16..8: 24.3% 2.3% 0.7% direct: 0.9% skip:70.2% L0:39.5% L1:57.0% BI: 3.5% [libx264 @ 0x329c740] final ratefactor: 20.22 [libx264 @ 0x329c740] 8x8 transform intra:58.9% inter:64.6% [libx264 @ 0x329c740] coded y,uvDC,uvAC intra: 67.6% 78.5% 54.1% inter: 14.1% 19.2% 4.5% [libx264 @ 0x329c740] i16 v,h,dc,p: 37% 35% 13% 14% [libx264 @ 0x329c740] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 24% 19% 5% 8% 5% 11% 5% 8% [libx264 @ 0x329c740] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 24% 16% 5% 8% 6% 9% 4% 5% [libx264 @ 0x329c740] i8c dc,h,v,p: 43% 30% 20% 7% [libx264 @ 0x329c740] Weighted P-Frames: Y:1.5% UV:1.2% [libx264 @ 0x329c740] ref P L0: 77.2% 14.1% 6.3% 2.4% 0.0% [libx264 @ 0x329c740] ref B L0: 91.9% 7.5% 0.6% [libx264 @ 0x329c740] ref B L1: 96.2% 3.8% [libx264 @ 0x329c740] kb/s:1730.79 real 1m58.259s user 5m15.740s sys 0m3.210s Edited April 24, 2017 by cachaca
Luke 42246 Posted April 24, 2017 Posted April 24, 2017 Yea we'll have to learn what aspect of our command line OMX doesn't like or is having trouble with.
cachaca 6 Posted April 25, 2017 Posted April 25, 2017 so.. do you think it is a wise course of action to experiment with these 2 lines? WITHOUT OMX: /home/pi/ffmpeg/ffmpeg -f matroska -codec:0 hevc -codec:1 aac -i file:"/media/usb0/TV Shows/SpongeBob SquarePants (1999-2015) [480p] [720p] [HEVC] [x265]/Season 01/[pseudo] S01E02 Reef Blower [480p] [h.265].mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset superfast -crf 28 -maxrate 2211644 -bufsize 4423288 -profile:v high -level 4.1 -x264opts:0 subme=0:rc_lookahead=10:me_range=4:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby-server/transcoding-temp/9de4642f1c380e2f7a6d25892e737ddb.m3u8" -y "/var/lib/emby-server/transcoding-temp/9de4642f1c380e2f7a6d25892e737ddb%d.ts" WITH OMX: /home/pi/ffmpeg/ffmpeg -i file:"/media/usb0/TV Shows/SpongeBob SquarePants (1999-2015) [480p] [720p] [HEVC] [x265]/Season 01/[pseudo] S01E01 Help Wanted [480p] [h.265].mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_omx -b:v 1294648 -maxrate 1294648 -bufsize 2589296 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby-server/transcoding-temp/71a39803f8b49ed4d59c41d75afca3d1.m3u8" -y "/var/lib/emby-server/transcoding-temp/71a39803f8b49ed4d59c41d75afca3d1%d.ts" till something works? There are a few parameters I dont understand. Is there basic documentation on the parameters emby needs? (vs what is printed above)
cachaca 6 Posted April 25, 2017 Posted April 25, 2017 ok.. made a small breakthrough.. when I run it manually.. it WORKS if I quickly copy/paste and run as root in the shell so.. it appears to be a permissions issue.. likely related to the library installation. I never did install it.. I am just pointing to the path where I compiled the source. Gonna try installing (even making a .deb package) and try again
cachaca 6 Posted April 26, 2017 Posted April 26, 2017 To all those who still pursue this.. good luck...and be warned. omx Requires root privileges. I explain in a different thread: https://emby.media/community/index.php?/topic/47066-need-help-troubleshooting-permissions-for-ffmpeg-raspberry-pi-omx/ I had decided to give Ubuntu MATE a try, since it contains pre-compiled ffmpeg binaries WITH omx support. After another few hours of installation and configuration.. the Ubuntu deployed ffmpeg behaves EXACTLY the same way.I mean. exactly. Which validates the integrity of my personal Raspbian deployment (as it pertains to ffmpeg and its deplendencies)I will move on without the OMX acceleration. I wont turn this install upside down and run emby as root.. a media server connected to the Internet... all due respect to the developers of Emby.. and the many plugins I could use.. but I think the focus is on features.. not security. Running it as "emby" limits the amount of damage a potential hacker may do.Anyway. thank you for the help ... and let this be a warning to others.. it requires root. ... and I suspect it is an undocumented requirement of the omx library subsection of the ffmpeg binary.************side note.. ubuntu 16LTS Mate is GARBAGE. Absolute Garbage. I have used beta distributions from smaller teams that installed and self configured with far less problems than this garbage distro.I just turned it off.. without even shutting it down. I will never use it again, and this MicroSD card will be wiped clean soon.What is so bad about it? I wont list all the problems.. and many config changes I had to do manually to a brand new system.. but here are the most glaring flaws:- no swap file created or defined- ssh would only start AFTER a successful login at the console... AND a graphical dialog box showed up (even though I used sudo at the prompt) asking me for a password- vnc not installed by default.. and even after installed.. I had to manually configure X (tried 2 different vnc servers)- and the crown jewel: -> first thing you do after getting a new distro: update the OS. "sorry, you dont have enough disk space in /boot to perform your updates". I had to do a NEW install, resizing the 64Meg boot partition to a larger size BEFORE installing the OS. (oh.. and because I resized partitions BEFORE the install, the INstaller did not extend the actual / partition to the rest of the SD card.. so the install failed again)Not that I could not deal with these problems.. but seriously.. needing to log in at the console before ssh worked.. WTF Was the Canonical guy on shrooms? I had not used ubuntu in a long time.. and I completely turned off. What an AWFUL experience.TTFN gents.. on to the next project. (ok.. I stil have work with Emby.. but the server will run like a champ now)
cachaca 6 Posted April 26, 2017 Posted April 26, 2017 just a fork of ffmpeg.. the omx extensions are the new baby.. and the same source I suspect will be used to compile both. I wont waste any more time on this... I cant play a few movies without pre-re-encoding them into something more palatable In 6 months I can look at it again. Cheers mate.
cachaca 6 Posted April 28, 2017 Posted April 28, 2017 (edited) SOLVED! I was right! It was a permissions issue.. related to root. I was playing with Kodi and the OMXPlayer... and in the OMXPlayer instructions I found this: http://omxplayer.sconde.net/ " Insufficient permissions to access /dev/vchiqThis can happen running omxplayer as user. To allow using omxplayer as user you need to do this:# echo 'SUBSYSTEM=="vchiq",GROUP="video",MODE="0660"' > /etc/udev/rules.d/10-vchiq-permissions.rules# usermod -aG video USERNAME-WHO-WILL-RUN-OMXPLAYER# reboot " BOOM The key here is granting the user emby access to the subsystem vchiq ! Take a look at this log output and WEEP: http://192.168.50.60:8096/emby/videos/7ddceb88d6758be9ba09e290b420aa17/hls1/main/0.ts?DeviceId=4b23de016b5225894d6e76c8edb8536321d8b37b&MediaSourceId=7ddceb88d6758be9ba09e290b420aa17&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3808002&AudioBitrate=192000&Level=51&Profile=high&PlaySessionId=049a5f459ad14c929e0ed8acdd16845a&api_key=0cd2a63298314854b714144b2291d7b0&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=bc219fa96243711adcfe308d4b24992f&RequireAvc=true&RequireNonAnamorphic=false&DeInterlace=false&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=False{"Protocol":"File","Id":"7ddceb88d6758be9ba09e290b420aa17","Path":"/media/usb0/Videos/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO.avi","Type":"Default","Container":"avi","Name":"480P/MPEG4/AC3","IsRemote":false,"ETag":"bc219fa96243711adcfe308d4b24992f","RunTimeTicks":44291301376,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"mpeg4","CodecTag":"XVID","TimeBase":"417083/10000000","CodecTimeBase":"417083/10000000","IsInterlaced":false,"BitRate":2385784,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":400,"Width":720,"AverageFrameRate":23.97604,"RealFrameRate":23.97602,"Profile":"Advanced Simple Profile","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":5,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/24000","CodecTimeBase":"1/48000","DisplayTitle":"Dolby Digital stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"srt","Language":"eng","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/media/usb0/Videos/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO.eng.srt","IsAnamorphic":true}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":2579661,"RequiredHttpHeaders":{}}ffmpeg -i file:"/media/usb0/Videos/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO.avi" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_omx -b:v 2385784 -maxrate 2385784 -bufsize 4771568 -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 0 -segment_list "/home/pi/transcoding-temp/7636a63775c8b9045d939fc8c5926192.m3u8" -y "/home/pi/transcoding-temp/7636a63775c8b9045d939fc8c5926192%d.ts"ffmpeg version N-85641-gdd49eff Copyright © 2000-2017 the FFmpeg developers built with gcc 4.9.2 (Raspbian 4.9.2-10) configuration: --enable-gpl --enable-nonfree --enable-mmal --enable-omx --enable-omx-rpi --enable-libmp3lame --enable-libx264 --enable-libvorbis libavutil 55. 61.100 / 55. 61.100 libavcodec 57. 93.100 / 57. 93.100 libavformat 57. 72.101 / 57. 72.101 libavdevice 57. 7.100 / 57. 7.100 libavfilter 6. 86.100 / 6. 86.100 libswscale 4. 7.101 / 4. 7.101 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100[avi @ 0x1e965e0] non-interleaved AVIInput #0, avi, from 'file:/media/usb0/Videos/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO/Ice.Age.The.Great.Egg-Scapade.2016.HDRip.XviD.AC3-EVO.avi': Metadata: encoder : AVI-Mux GUI 1.17.8.3, Feb 16 201019:42:50� JUNK : Duration: 01:13:49.13, start: 0.000000, bitrate: 2579 kb/s Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x400 [sAR 1:1 DAR 9:5], 2385 kb/s, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 192 kb/sStream mapping: Stream #0:0 -> #0:0 (mpeg4 (native) -> h264 (h264_omx)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native))Press [q] to stop, [?] for help[mpeg4 @ 0x1ec90f0] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using the mpeg4_unpack_bframes bitstream filter without encoding but stream copy to fix it.[h264_omx @ 0x1ec5b70] Using OMX.broadcom.video_encodeOutput #0, segment, to '/home/pi/transcoding-temp/7636a63775c8b9045d939fc8c5926192%d.ts': Metadata: encoder : Lavf57.72.101 Stream #0:0: Video: h264 (h264_omx), yuv420p, 720x400 [sAR 1:1 DAR 9:5], q=2-31, 2385 kb/s, 23.98 fps, 90k tbn, 23.98 tbc Metadata: encoder : Lavc57.93.100 h264_omx Stream #0:1: Audio: aac (LC), 48000 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc57.93.100 aacframe= 12 fps=0.0 q=-0.0 size=N/A time=00:00:00.72 bitrate=N/A speed=1.44x frame= 28 fps= 28 q=-0.0 size=N/A time=00:00:01.32 bitrate=N/A speed= 1.3x frame= 47 fps= 31 q=-0.0 size=N/A time=00:00:02.13 bitrate=N/A speed=1.39x frame= 75 fps= 37 q=-0.0 size=N/A time=00:00:03.28 bitrate=N/A speed=1.61x frame= 92 fps= 36 q=-0.0 size=N/A time=00:00:04.01 bitrate=N/A speed=1.57x frame= 115 fps= 38 q=-0.0 size=N/A time=00:00:04.97 bitrate=N/A speed=1.63x frame= 144 fps= 40 q=-0.0 size=N/A time=00:00:06.16 bitrate=N/A speed=1.73x frame= 170 fps= 42 q=-0.0 size=N/A time=00:00:07.25 bitrate=N/A speed=1.79x frame= 198 fps= 43 q=-0.0 size=N/A time=00:00:08.40 bitrate=N/A speed=1.84x frame= 224 fps= 44 q=-0.0 size=N/A time=00:00:09.51 bitrate=N/A speed=1.88x frame= 252 fps= 45 q=-0.0 size=N/A time=00:00:10.64 bitrate=N/A speed=1.91x frame= 283 fps= 47 q=-0.0 size=N/A time=00:00:11.98 bitrate=N/A speed=1.97x 47FPS!! All the while the CPU looks like this: (using the excellent cpustatus.sh script from https://gist.github.com/ecampidoglio/5009512 ) pi@avcenter:~ $ ./cpustatus.shTemperature: 54.8 CVoltage: 1.39 V (+0.19 overvolt)Min speed: 600 MHzMax speed: 1300 MHzCurrent speed: 1300 MHzGovernor: ondemand Overclocked slightly... and not even 60C! Not even sure I need the overclocking. I am having goosebumps One thing I may investigate is the GPU/CPU ram sharing agreement. Would it make a difference changing it? I have 128MB allocated for the GPU... and it is slightly overclocked. And this is the top half of my TOP window.. just for reference. top - 22:05:08 up 8:02, 3 users, load average: 1.25, 1.43, 1.46Tasks: 151 total, 2 running, 147 sleeping, 0 stopped, 2 zombie%Cpu(s): 26.6 us, 2.2 sy, 0.0 ni, 71.0 id, 0.0 wa, 0.0 hi, 0.1 si, 0.0 stKiB Mem: 899012 total, 872224 used, 26788 free, 106992 buffersKiB Swap: 1816572 total, 8924 used, 1807648 free. 497168 cached Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND17681 pi 20 0 225320 20372 3476 R 106.8 2.3 20:25.46 ffmpeg11914 pi 20 0 258168 194668 32512 S 3.3 21.7 20:30.02 mono-sgen 69 root 1 -19 0 0 0 S 1.0 0.0 0:15.86 VCHIQ-017268 pi 20 0 5248 2568 2108 S 0.7 0.3 0:10.28 top18619 pi 20 0 5116 2520 2108 R 0.7 0.3 0:00.13 top 32 root 20 0 0 0 0 S 0.3 0.0 0:03.05 kswapd0 85 root 20 0 0 0 0 S 0.3 0.0 0:01.67 jbd2/mmcblk0p2- 283 root 20 0 0 0 0 S 0.3 0.0 0:03.82 usb-storage 290 root 20 0 5432 2436 1264 S 0.3 0.3 0:55.72 mount.ntfs 737 debian-+ 20 0 29064 2836 2056 S 0.3 0.3 0:18.01 transmission-da Gents.. this WORKS! It plays Transcoded files better than high def directplay.. IO becomes the bottleneck rather than transcoding capabilities. I had given up on it. and found the answer by accident. Have a good one! Edited April 28, 2017 by cachaca 1
awiouy 0 Posted September 15, 2017 Author Posted September 15, 2017 Team LibreELEC has resumed work on transcoding (see here). Currently, Emby uses a command similar to this, which does not hardware decode: ffmpeg -i file:"input.mkv" -codec:v:0 h264_omx "output.ts" Using a command similar to this uses hardware decode: ffmpeg -codec:v:0 h264_mmal -i file:"input.mkv" -codec:v:0 h264_omx "output.ts" Is there a way to experiment with the command Emby uses without having to recompile it? Luke, how do you suggest to test this?
Luke 42246 Posted September 15, 2017 Posted September 15, 2017 We can add this for the next release, thanks. 1
tdiguy 99 Posted September 15, 2017 Posted September 15, 2017 Dude this is awesome! this will enable hardware acceleration on the puny pi if i am understanding this correctly anyway. This is awesomesauce! Lol now how do i fully utilize my license for mpeg2 hardware acceleration?
awiouy 0 Posted September 16, 2017 Author Posted September 16, 2017 Luke, I had a look at commit a1f27c2 and I am not sure it implements all the required flags. Both the h264_mmal and the h264_omx flags are required for hardware acceleration: ffmpeg -codec:v:0 h264_mmal -i file:"input.mkv" -codec:v:0 h264_omx "output.ts" I can't find the h264_mmal flag in the code. Looking forward to testing (not before Monday, though).
CvH 14 Posted September 17, 2017 Posted September 17, 2017 (edited) If I understand the code correctly (pls ignore me if I misunderstood it) this commit Commit creates that command line ffmpeg -i file:"input.mkv" -codec:v:0 h264_omx "output.ts" this commit Commit change that command line to ffmpeg -i file:"input.mkv" -codec:v:0 h264_mmal "output.ts" but actually we need ffmpeg -codec:v:0 h264_mmal -i file:"input.mkv" -codec:v:0 h264_omx "output.ts" h264_mmal is the hw decoder for the videoh264_omx is the hw encoder for the video If just one of both is used the RPi is basically not usable for transcoding. Edited September 17, 2017 by CvH
Luke 42246 Posted September 17, 2017 Posted September 17, 2017 Try the next beta release. You can choose in the server dashboard whether to enable decoding, encoding, or both.
CvH 14 Posted September 17, 2017 Posted September 17, 2017 ok, tx (so I might completely misunderstood the last commit)
mellon85 1 Posted August 26, 2018 Posted August 26, 2018 @@Luke Sorry for necroposting, but I am testing now emby on a RPI and checking the transcode command is with h264 instead of h264_omx/mmal
Luke 42246 Posted August 27, 2018 Posted August 27, 2018 Yes that's correct. Although the server understands omx, our ffmpeg builds do not include it, so that means you'd have to bring your own ffmpeg.
Luke 42246 Posted July 7, 2019 Posted July 7, 2019 The upcoming Emby Server 4.2 will have h264_omx built-in for Raspberry Pi hardware encoding. Thanks guys.
