Browse movies and TV in same list?
electric_sponge
Hello, instead of looking at movies or tv, I'd like to see them all co-mingled in the same list when I browse. My first attempt was just calling them all 'movies' which gives me the single list as I'd like, but it wasn't pulling in TV metadata correctly (solved by moving them all to a TV folder type, but I now have two lists).
Is there a way to combine all my home screen categories into one list sorted by date?
Thanks
I think you might be able to do what you want by setting it as generic media, but I'm not sure.  The other option maybe using shortcuts to your movies in your tv folder and then having two media collections (Like you have now that gave you the two lists) one for movie and one for tv.  Then you would go into your tv folder which would have your tv and your movies.  But this is just a guess as this is non-standard.
I would have thought having a general media folder mapped into the library as a collection type 'mixed' would do the trick, that may be worth trying...
electric_sponge
Yep, that was it. I completely missed that there was a 'mixed' category and thought I had to choose.
Thanks
