n00b42 41 Posted June 22, 2016 Posted June 22, 2016 When I want to manually identify a movie that was not identified automatically 1. I go to the Movie Page 2. Click on Menu - Identify 3. Most of the time I enter the IMDB id directly 4. Select correct movie, select "Replace Images" and click "Confirm" Issues: 1.) Neither "Title" nor "Original Title" get replaced. 2.) If using "Identify" from Movie Page, the page is not refreshed, so it looks like nothing happened. Reloading the page shows the changes (Images, etc.). Using "Identify" from the "Edit Movie" dialogue does not update the input fields (or at least not title/etc?), therefore I fear clicking "Save" may then set all the values back to the blank ones. 3.) The Server Log gets spammed with TheMovieDb errors. (see appended log Note: One of the issues seems to be that the TMDB API is called even if the query/title/... fields are empty resulting in "{"errors":["query must be provided"]}" 4.) Identify is very slow, assuming due to issues 3 Regards Max emby.log
Luke 42186 Posted June 23, 2016 Posted June 23, 2016 Hi, can you please give an example? then please provide the complete log file that contains the example. thanks!
Solution Luke 42186 Posted June 23, 2016 Solution Posted June 23, 2016 Nevermind, the issue you're referencing is a refresh issue. That's easily solved, thanks. 1
n00b42 41 Posted June 23, 2016 Author Posted June 23, 2016 Restartet my server today (and Emby Server with it). Resulting in no Error messages in the log anymore while using Identify.
Luke 42186 Posted June 23, 2016 Posted June 23, 2016 Hi, I don't really know what that is intended to mean but it is better to just report your issues that you encounter during use rather than go looking for them in the log. thanks.
