Nutellaeis
Hello,
I found another problem. Some of my files simply will not play when I use the app to send them to chromecast. They do play fine in the app and the webview though. I suspect it happens if the files have special characters like ?  or : .
Some examples of filenames that will not play:
 Re: Life in a different world from zero - s01e01.mkv
Haven't You Heard? I'm Sakamoto - s01e01.mkv
There are no errors in the normal logfiles. However if I force transcoding I DO get errors. Adding an example log here.
transcode-00db808c-d507-4f1f-8759-f33bd77f243b.txt
Yup we're still chasing that one down, thanks
  • Like 1
Nutellaeis
Can you notify my here when it is found? Or is there a bugtracker (or changelog) somewhere ?
Edited by Nutellaeis
