cw-kid 192 Posted June 20, 2016 Posted June 20, 2016 The library still appears to be there as well. So what is the best way to backup the library database in case of issues ? I have a backup running on the WHS console that backs up the C: drive etc. Thanks
Sorahl 7 Posted June 20, 2016 Posted June 20, 2016 I do not appear to have a back up copy of the database file.. i'll try deleting it, but it seems folks just get the same error when they do that. John
Happy2Play 9817 Posted June 20, 2016 Posted June 20, 2016 The library still appears to be there as well. So what is the best way to backup the library database in case of issues ? I have a backup running on the WHS console that backs up the C: drive etc. Thanks I have the mine backup the same and that covers everything there so you can restore Emby stuff as far back as your backups go. So everything is good again on .33 for you?
Happy2Play 9817 Posted June 20, 2016 Posted June 20, 2016 I would try installing the stable release and see if that resolves the issue and wait for another beta release later.
Sorahl 7 Posted June 20, 2016 Posted June 20, 2016 I will.. i'm only on the beta because I was getting the identical error with the stable. i'll uninstall and try the stable again
cw-kid 192 Posted June 20, 2016 Posted June 20, 2016 Seems to be OK the web GUI is all loading up OK, not tested too much though watching England play football..
LurchZA 4 Posted June 21, 2016 Posted June 21, 2016 Upgrading to 3.1.33 fixed my problem. The service did not want to start initially, but I was able to run via the exe. After it started, I shut it down and tried the service again, and it was fine.
