iBoss 31 Posted June 24, 2016 Author Posted June 24, 2016 iBoss - if you re-start the Apple TV app it should now handle that error properly and allow you to log in and test what we were originally trying to (the subtitles). Thanks. Unfortunately, still I can not log in I restart the app (force restart) and restart the Apple TV as well, but still give me the same error server-63602379893.txt
ebr 16335 Posted June 24, 2016 Posted June 24, 2016 That's not the error I thought you were getting. I thought you were getting stuck on the "Welcome" screen (which is what happened to me). I am able to log in to your server on my Apple TV using the ID you gave me. Can you try that one?
Luke 42242 Posted June 24, 2016 Posted June 24, 2016 I really would like to see a complete log file and i've mentioned this several times now. Every log file that you post appears to have been manually cut. For reference, this is what a complete log file looks like: http://emby.media/community/index.php?/topic/36190-folder-sync-failing-when-directory-not-found/?p=340844 Notice how it begins with all of the server startup and initialization. Please provide a log that includes all of that as well as the apple tv activity. thanks.
iBoss 31 Posted June 25, 2016 Author Posted June 25, 2016 That's not the error I thought you were getting. I thought you were getting stuck on the "Welcome" screen (which is what happened to me). I am able to log in to your server on my Apple TV using the ID you gave me. Can you try that one? the error is shown after trying to log in using username & pass you can log in? I still can not log in even with the username that I provided to you (I remove the app and install it again but still same error). I really would like to see a complete log file and i've mentioned this several times now. Every log file that you post appears to have been manually cut. For reference, this is what a complete log file looks like: http://emby.media/community/index.php?/topic/36190-folder-sync-failing-when-directory-not-found/?p=340844 Notice how it begins with all of the server startup and initialization. Please provide a log that includes all of that as well as the apple tv activity. thanks. I'm really sorry I did not understand what complete log, I cleared the log folder after restart the Emby server, that's why. Ok now it should complete log thanks server-63602417867.txt
iBoss 31 Posted June 25, 2016 Author Posted June 25, 2016 (edited) ebr, it log in now ... it is very strange. you know what it is the problem? when I use remote app on iPhone to type username and password it give me that error. But if I use Apple TV remote it log in successfully. anyway it give me the massage before going to user home screen (attached screenshot) but after press menus button it goes to the user home screen Ok now, about the subtitle .. still exactly the same issue thanks server-63602417867.txt remux-09b4819c-632a-450b-8fcf-787dcacad1f4.txt remux-c6e5405a-4e6e-45ef-baa3-b035f1d75536.txt remux-8b27b944-d7d3-43ed-8328-0da0a1a808fa.txt Edited June 25, 2016 by iBoss
Luke 42242 Posted June 25, 2016 Posted June 25, 2016 Ok, thanks for your patience. I'll have a new server beta up tomorrow morning. Please test on that once you have it. Thanks.
iBoss 31 Posted June 25, 2016 Author Posted June 25, 2016 Ok, thanks for your patience. I'll have a new server beta up tomorrow morning. Please test on that once you have it. Thanks. My patience? come on guys, I'm the one who should thank you for your patience with me. You are a fast response and amazing support I really like it. I know a lot of projects, their team don't care about it. I'm not only talking about open source and free projects, there are some paid project/service with really bad support. I like you guys and great job I'm planning very soon to support you with $100, not for the bonus, but because you deserve it Thank you ebr, thanks Luke and I know you can fix these issues soon.
ebr 16335 Posted June 25, 2016 Posted June 25, 2016 Thanks for the kind words. That new error screen you got is related to the error Luke hopes to fix in the next beta. Previously, the app wasn't handling it properly and just hung up. Now it gives you the message and then allows you to get to your home screen (without the Continue Watching row). As for the subtitle issue, I do believe that will get solved by a combination of an app update via the store (currently in review) and the new server. Thanks.
Luke 42242 Posted June 25, 2016 Posted June 25, 2016 If you try the latest beta server I think those subtitles should burn in now. Thanks.
iBoss 31 Posted June 25, 2016 Author Posted June 25, 2016 (edited) Great, now it burn in video both Arabic and English subtitles work perfectly. So, four more issues left: 1- On Apple TV App, the main issue of this topic: there is a yellow subtitle appears too (two subtitles). (screenshot attached) 2- The server on Chrome still give me loading indicator (infinity loading). 3- On Apple TV App if I select subtitle from the beginning I can not change it to another language. (screenshot attached) 4- On Apple TV App, the error message about Continue Watching. -other issue I found: using Remote app on iPhone to type username and password it give the error "Error signing in" Thanks Edited June 25, 2016 by iBoss
Luke 42242 Posted June 25, 2016 Posted June 25, 2016 Thanks. Chrome is separate so please file a separate topic for that in the web client section. I believe #1 and #3 are resolved in an update that is currently going through Apple approval.
ebr 16335 Posted June 25, 2016 Posted June 25, 2016 4- On Apple TV App, the error message about Continue Watching. So this still happens even with today's beta server?
iBoss 31 Posted June 25, 2016 Author Posted June 25, 2016 So this still happens even with today's beta server? Yes. with ver. 3.1.40.0 and Apple TV App is updated as well
ebr 16335 Posted June 26, 2016 Posted June 26, 2016 Okay, but they are properly synced up now, correct? Would you be interested in joining the Apple TV beta program to see if the upcoming version fixes this for you (and also help with other issues/features)?
iBoss 31 Posted June 26, 2016 Author Posted June 26, 2016 Okay, but they are properly synced up now, correct? The subtitle which burn in is synced perfectly. Would you be interested in joining the Apple TV beta program to see if the upcoming version fixes this for you (and also help with other issues/features)? Yes why not
iBoss 31 Posted June 26, 2016 Author Posted June 26, 2016 (edited) Thanks. Chrome is separate so please file a separate topic for that in the web client section. I believe #1 and #3 are resolved in an update that is currently going through Apple approval. Luke, should I create a new topic on the web client section? I think this issue related to the server or HTML5 because it is on all browsers and iOS App too thanks Edited June 26, 2016 by iBoss
ebr 16335 Posted June 26, 2016 Posted June 26, 2016 Yes you should create a new topic for those other issues. The new version of the Apple TV app is on its way out via the store now so we can see if that solves your double subs problem once it is completely out. If you still would be interested in joining the beta program though, please PM me the email address associated with the Apple ID on the device. Thx.
iBoss 31 Posted June 28, 2016 Author Posted June 28, 2016 1- On Apple TV App, the main issue of this topic: there is a yellow subtitle appears too (two subtitles). (screenshot attached) 3- On Apple TV App if I select subtitle from the beginning I can not change it to another language. (screenshot attached) Still these issues there. Server Ver. 3.1.42.0 Apple Tv App ver .1.0.2 ffmpeg-sub-extract-62141aef-ed92-4954-93e5-ff5f145a2bc6.txt remux-868daa18-7f39-4f68-b945-a25cc1fb6aab.txt remux-2140bd35-c581-4d2a-b068-ecb432d1285d.txt remux-20988157-9599-4670-9da6-3425fc9d5ff4.txt remux-b297ade4-a86e-49ab-8554-5236c5b8c1cc.txt remux-e40a539a-80d0-4700-8c39-b9730a8f8fc1.txt server-63602732190.txt transcode-6d932fd5-fc93-47ee-b6dc-3144213a7505.txt
ebr 16335 Posted June 28, 2016 Posted June 28, 2016 Yes, the update hasn't been fully delivered yet. There are two components - the app from the store and then the part that is delivered in real time. I needed to wait until the store app gets completely out there until putting up the updated live app. I will probably be doing that later today or tomorrow.
iBoss 31 Posted July 7, 2016 Author Posted July 7, 2016 Thanks guys, most of the issues is solved. the main issue is fixed about these: 3- On Apple TV App if I select subtitle from the beginning I can not change it to another language. (screenshot attached). -other issue I found: using Remote app on iPhone to type username and password it give the error "Error signing in using the remote to enter password does not work and I cant change the subtitle,I cant switch it off too. anyway how I can change the subtitle font? what is the path of the font on the server? Thanks. emby server ver. 3.1.56.0 Linux Ubuntu 12.04.5 server-63603524645.txt transcode-7bdaa8c4-b564-40dd-8258-f82db99e484b.txt transcode-ab73a117-be41-45f0-a647-f9bdcf7a3354.txt
Luke 42242 Posted July 7, 2016 Posted July 7, 2016 When subtitles have to be burned in via transcoding, there is no apple menu available to turn them off. does that make sense? We'll look into the password entry issue. Thanks.
iBoss 31 Posted July 7, 2016 Author Posted July 7, 2016 When subtitles have to be burned in via transcoding, there is no apple menu available to turn them off. does that make sense? yes, in the burned subtitle (white color) can not be turned it off or changed it to another language. I have two subtitle: english and arabic, the above attached screenshot shows that there are in apple menu three chose (while watching movie): Off Auto CC - Off: dose not turn it off - There is no chose for the second subtile (arabic). I can chose any subtitle language (english or arabic) from the subtitle menu before start playing movies, but I can not change it while watching them. Thanks
Luke 42242 Posted July 8, 2016 Posted July 8, 2016 Those subtitles are .ass which means they have to be burned in. That's why they dont' work with the apple menu, because the apple menu can't control that. Do you have a video with srt subtitles? try that for comparison.
ebr 16335 Posted July 8, 2016 Posted July 8, 2016 Can you please explain whatever password entry issue you are having? I have not had or seen any reported problems with this. Thanks.
iBoss 31 Posted July 8, 2016 Author Posted July 8, 2016 Those subtitles are .ass which means they have to be burned in. That's why they dont' work with the apple menu, because the apple menu can't control that. Do you have a video with srt subtitles? try that for comparison. OK I use SRT subtitle, now I have got a lot of issues. let me explain them: first I have these files: -One Piece ep02.mkv <-- this contain English .ass -One Piece ep02.ara.srt <-- Arabic .srt --------------------------------- *Part One: Select Arabic from "Select Audio or Subtitles" menu: If I go to "Select Audio or Subtitles" and select Arabic .srt from there (Please see the 01 screenshot), the Arabic subtitle it will show within the black box synced perfectly, but at the same time there is another one shows (double subtitle again) its color is white and not synced with the video. (Please see the 02 screenshot) while watching, if I try to change it to English, the menu give me this time the the choice between English and Arabic (Please see the 03 screenshot). If I change it to English, it will change and shows within black box with no issue as .srt subtitle (even the English is .ass), but the duplicate white Arabic subtitle still there (Please see the 04 screenshot). if I chose "Off" the duplicate white Arabic subtitle will be still show --------------------------------- *Part Two: Select English from "Select Audio or Subtitles" menu: If I select English from "Select Audio or Subtitles" which is actually .ass file inside .mkv, the subtitle will be show as white subtitle without black box (burned). while watching, if I try to change it to Arabic or switch it Off, I can not (Please see the 05 screenshot). --------------------------------- I hope every thing is clear If you would like to provide you account to check it, please just tell me. I know I gave you one before, but I change the hosting. Can you please explain whatever password entry issue you are having? I have not had or seen any reported problems with this. Thanks. very simple password with one small latter and six numbers. when try to enter it using Remote App from iOS it give me "sign in error". Please tell me if you want any more explain or account details to try it Many Thanks server-63603579724.txt transcode-5d7b47df-e3d0-418a-ade1-fc6ac56bb23b.txt transcode-1046dd2c-1f83-442a-b7ad-b75277576ba1.txt transcode-e83561ba-0a9d-4f3b-bdb0-ce96ed9f0506.txt transcode-f586a22e-09ec-48b0-be26-e064f439fe39.txt
