mrees 6 Posted June 18, 2016 Posted June 18, 2016 Hi all, Im experiencing some issues with Emby for WMC Quite often I am losing content in the emby interface When I try and go into any of the libraries, it will show that there are no Items If I exit out of the application a few times, sometimes the content re-appears Other times I just need to let the system sit there for a while before something eventually shows up My server and main WMC are both wired to gigabit switches and this is a new WMC build (dedicated) with the 64 bit version of Windows 7 running and minimal software loaded My server OS is WHS 2011 The only real difference that I can think of is that I had to hard code the IP of the server into the WMC config as it wouldn't pick up the server automatically on installation Any help would be greatly appreciated (log attached) Emby.txt
mrees 6 Posted June 20, 2016 Author Posted June 20, 2016 (edited) Hi All Heres a 2nd log file This was taken just now after a fresh reboot of the server Emby for WMC again shows no content Trying to connect using a IOS client simply sits at the spinning circle with no content displayed Any help on this would be great, because when it hits, the system is totally unusable --------- After the log file was taken-------------- I shut the IOS client down a few times and re-opened it Once it connected, I forced the WMC to play a episode from the phone client (remote controlled) Once I did this, the content started populating on the WMC emby.txt Edited June 20, 2016 by mrees
Ian-Highlander 147 Posted June 20, 2016 Posted June 20, 2016 Is the server doing a media scan when this happens? Only ask because I get this problem when a media scan is running. If you'd just started the server then an initial startup scan probably was running.
Luke 42238 Posted June 20, 2016 Posted June 20, 2016 You could try downloading the beta server from the website and see if that performs better. Please note, it will run a database upgrade task so allow that to finish. 1
mrees 6 Posted June 21, 2016 Author Posted June 21, 2016 Is the server doing a media scan when this happens? Only ask because I get this problem when a media scan is running. If you'd just started the server then an initial startup scan probably was running. No its not. The resources are sitting close to idle and no active tasks are present
mrees 6 Posted June 21, 2016 Author Posted June 21, 2016 Your server is simply responding too slowly. Any way to determine why? Its gigabit hard wired Resources are sitting close to idle (plenty of CPU and RAM left) and file access and other applications are quick and snappy, its simply just Emby thats causing me grief
mrees 6 Posted June 21, 2016 Author Posted June 21, 2016 You could try downloading the beta server from the website and see if that performs better. Please note, it will run a database upgrade task so allow that to finish. Im on the beta currently. I did that after you recommended to another user to jump on board due to his current performance issues
Boredcat 34 Posted June 21, 2016 Posted June 21, 2016 Hmm, it seems that i am having the same issue (posted in dev forum). What beta version of the server are you running. Mine is .33 (beta build). The Ios app and website correctly displayed all items.
mrees 6 Posted June 22, 2016 Author Posted June 22, 2016 Hmm, it seems that i am having the same issue (posted in dev forum). What beta version of the server are you running. Mine is .33 (beta build). The Ios app and website correctly displayed all items. Version 3.1.27.0
Boredcat 34 Posted June 22, 2016 Posted June 22, 2016 I didn't check it in that version. I just upgraded to 0.35 (same issue). I also found that Emby is starting slower then before (1 1/2 week back). Also I having gigabit between server and HTPC so that should not be the issue. I will now update WMC to the latest beta (see if that helps). Next step if this doesn't work, I will rollback to from a beta version to the stable version. @@mrees : What kind of hardware do you use as server.
mrees 6 Posted June 23, 2016 Author Posted June 23, 2016 (edited) @@mrees : What kind of hardware do you use as server. @@Boredcat Windows Home Server 2011 Asus P55-UD4P Motherboard w/ Intel i7 12GB RAM Onboard Intel SATA RAID 5 running: 6 x 6TB WD NAS Pro HDD's (Approx 30TB usable space) 1 x Areca 1261 16 Channel Raid PCIe SAS running: 16 x 3TB WD NAS Pro HDD;s (2 x RAID 6 Arrays Approx 33TB usable space) Edited June 23, 2016 by mrees
Boredcat 34 Posted June 24, 2016 Posted June 24, 2016 I am using the pearl skin. Switched to classic (still no luck). But when I switch the view for movie to genres, movies where displayed again. Switch back to the normal view made the movies disappear again. So I think that the issue is somehow related to the view setting in WMC.. Also I check the load on my server (I don't have a system powerfull as yours ;-) and the CPU is almost idle .. Also I check the disk queue length on the disk (especially in on the disk where the Emby server is located) this was no more then 0.1. So the disk and CPU should not be the bottleneck. @@mrees : did you tried anything yet ?
Boredcat 34 Posted June 26, 2016 Posted June 26, 2016 I was reading an other thread there mention of turning off legacy browsing to increase speed. Gave that a try and everything is working again. In between I also installed Emby Theater, this worked also very good, so I will move from WMC to ET (and upgrade to Win10). 2
DAVe3283 7 Posted July 9, 2016 Posted July 9, 2016 I'm having this same problem now after the server updated automatically. My "Movies" collection is empty. "TV" collection works, but very slow to load initially. I updated to the latest beta server (3.1.6033.23766), no change. Log: server-63603620265.txt, error @ line 331. I updated to the latest beta Emby for WMC client (3.0.307), no change. Log: MBClassic-972016085da4b5ca834132bfa91eef15009d96.log, error @ line 59. Emby Theater and the web UI both work perfect, playback works fine. Just Emby for WMC is missing content. Server is a Windows Server 2012 R2 VM (host and guest); 3 GB RAM (currently using 1.2GB), 4 CPU cores. CPU use sits at 3-5% when I open Emby for WMC, 0% otherwise. Disk queue is < 0.01 (1% Highest Active Time) according to Resource Monitor. If you need more specs on the system I can provide them, but suffice to say it is not CPU or I/O bound.
ebr 16332 Posted July 9, 2016 Posted July 9, 2016 That's a dev server not a beta but try the latest stable release. The requests are timing out as you saw in the EMC log.
DAVe3283 7 Posted July 9, 2016 Posted July 9, 2016 You're right, I think I was on the beta channel and switched to the dev channel to see if that fixed it. I downgraded to the latest stable (3.0.5985.0) and that seems to have fixed the issue. Thanks! Hopefully those logs are still useful to the devs to fix the regression going forward, though.
mpm131 1 Posted July 11, 2016 Posted July 11, 2016 For what it is worth. I was running Emby with out an issue on beta server version. It worked great up until the last few beta versions, and then I ran into the same issue as the rest in this post where my movies would not show up due to timeouts. Nothing changed with my setup except for the beta version. The latest beta I had was .61. I wound up removing it and installing the latest stable version and my system is running much, much better and all my movies are showing up and it seems to be running much faster. I think there is a glitch with the beta version. My opinion of course.
Mustang Dave 5 Posted July 11, 2016 Posted July 11, 2016 (edited) i am having EXACTLY the issue Dave3283 posted and I am only running the newest standard version 3 0 5985 "I'm having this same problem now after the server updated automatically. My "Movies" collection is empty. "TV" collection works, but very slow to load initially." plus i noticed if i go into meta manager and go to movies nothing ever comes up. plus all scans and cleaning and updates of tasks are taking 2 or more hrs. server-63603719106.txt Edited July 11, 2016 by Mustang Dave
Mustang Dave 5 Posted July 11, 2016 Posted July 11, 2016 (edited) for some reason i can only attach one log. the other attachments error out... i have more.... Edited July 11, 2016 by Mustang Dave
ebr 16332 Posted July 11, 2016 Posted July 11, 2016 If you have the option to collapse box set items turned on, try turning it off.
mpm131 1 Posted July 11, 2016 Posted July 11, 2016 Further to my post yesterday. Here are my log files for both the server and WMC. I have attached the beta server logs and the stable version logs as data points. Notes on both. Beta Server Logs: - Created using beta server prior to .61 although .61 provided similar results if not worse. Symptoms: Movies would not show up (close to 700 titles). TV shows showed up but sluggish. Again this only happened recently with introduction of the last couple beta server installs. Stable Server Logs - All issues that I had with the last couple of beta versions disappeared when I installed the lastest stable version from the website. Movies showed up almost instantaneously and not more sluggishness with the TV shows. Hope it helps. MBClassic-87201672e55c0a24bd43d9b91726fc5e6e58d3 - Beta Server.log MBClassic-11720169259c2febb3c4ab48ef784844516aa46-Stable Server.log server-63603587244-Beta Server.txt server-63603791999-Stable Server.txt
