Oxide 139 Posted June 18, 2016 Posted June 18, 2016 (edited) I've now tried with a vanilla Kodi 16.1 install (No other plugins besides what comes with Kodi and the Emby stuff) on my Windows 10 workstation. I installed the Emby Beta 1.5 repository and from there installed the Emby 2.2.10 plugin which immediately crashed. I then uninstalled that plugin and installed the 2.2.10-alpha plugin which started to sync, but crashed during the sync. Looks like same error as above, before the crash it always mentions skipping an empty show, but the shows definitely not empty. 15:59:17 T:3308 NOTICE: EMBY TVShows -> Skipping empty show: Fresh Meat 15:59:29 T:3308 ERROR: Exception in thread Thread-10: Traceback (most recent call last): File "C:\Program Files (x86)\Kodi\system\python\Lib\threading.py", line 810, in __bootstrap_inner self.run() File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\librarysync.py", line 912, in run self.run_internal() File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\librarysync.py", line 985, in run_internal librarySync = self.startSync() File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\librarysync.py", line 100, in startSync completed = self.fullSync() File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\librarysync.py", line 272, in fullSync completed = process[itemtype](embycursor, kodicursor, pDialog) File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\librarysync.py", line 738, in tvshows tvshows.add_updateEpisode(episode) File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\itemtypes.py", line 1317, in add_updateEpisode self.add_update(show) File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\itemtypes.py", line 1043, in add_update viewtag, viewid, mediatype = emby.getView_embyId(itemid) File "C:\Users\Jason\AppData\Roaming\Kodi\addons\plugin.video.emby\resources\lib\read_embyserver.py", line 112, in getView_embyId cursor_emby.execute(query, (viewId,)) OperationalError: database is locked kodi.zip Edited June 18, 2016 by Oxide 1
Angelblue05 4132 Posted June 18, 2016 Posted June 18, 2016 (edited) @@Oxide @@AgileHumor Thanks for the info, I'll check it out and let you know if I find something... Edited June 18, 2016 by Angelblue05 1
Angelblue05 4132 Posted June 19, 2016 Posted June 19, 2016 @@Oxide @@AgileHumor - Can you enable sync empty shows in the add-on settings > sync option? It should temporarily help with the issue. Can you please confirm? 2
Oxide 139 Posted June 19, 2016 Posted June 19, 2016 Brilliant @@Angelblue05, enabling sync empty shows did the trick 1
AgileHumor 123 Posted June 19, 2016 Posted June 19, 2016 @@Oxide @@AgileHumor - Can you enable sync empty shows in the add-on settings > sync option? It should temporarily help with the issue. Can you please confirm?You sir, are a genius. All fixed. Sent from my SAMSUNG-SM-G890A using Tapatalk 1
bluemonkey07 590 Posted June 19, 2016 Posted June 19, 2016 (edited) You sir, are a genius. All fixed. Sent from my SAMSUNG-SM-G890A using Tapatalk You need the full log sir? I was pasting it in as you posted.Ma'am actually Edited June 19, 2016 by Vidman 2
Angelblue05 4132 Posted June 19, 2016 Posted June 19, 2016 Ma'am, sir, doesn't matter to me I'm not a "female coder", I'm a coder. Thanks for reporting that it started working once more. Luke is aware of the situation. It seems with the latest server release, it stopped returning the number of episodes per show. This should be resolved next server release and everything should be back to normal add-on side, then. Sent from my iPhone using Tapatalk 2
