mentasm 43 Posted June 15, 2016 Posted June 15, 2016 Hi, I've been fighting with this issue for a little while now. At times when I come back to ET after a while and the screensaver is active and displaying backdrops, I cannot get it to return to the ET main screen. clicking back on the remote seems to just skip the backdrop to the next one. Similarly if I hit the Esc key on the keyboard it will also skip to the next backdrop. The only way I have been able to recover from this is to alt-tab out and kill the ET process. No other remote or keyboard command seems to wake it up. As my media centre is an always on setup, having to kill the app and relaunch before use is obviously hurting the WAF greatly ET 2.4.3 Emby server 3.0.5972.0 windows 7 x64 SP1 Suggestions?
Luke 42242 Posted June 16, 2016 Posted June 16, 2016 Thanks, its' hard to reproduce. I've posted some fixes, we'll monitor it over the coming days.
mentasm 43 Posted June 16, 2016 Author Posted June 16, 2016 Thanks for having a look. Are you happy with me posting issues like this in seperate topics? Felt kinda bad posting a heap of seperate topics. I have some other issues as well that I'd like to explore?
Disorganise 15 Posted June 17, 2016 Posted June 17, 2016 Have had this too.....my workaround has been to switch off the screensaver. Sent from my LG-H815 using Tapatalk
NWGiles 10 Posted June 17, 2016 Posted June 17, 2016 Have had this too.....my workaround has been to switch off the screensaver. Sent from my LG-H815 using Tapatalk how do you turn off your emby screen saver?
Disorganise 15 Posted June 17, 2016 Posted June 17, 2016 Away from home at the moment but something like settings/general/screensaver set value to none. I'll check for sure when I get home in a couple of days Sent from my LG-H815 using Tapatalk
James 31 Posted June 18, 2016 Posted June 18, 2016 Also experiencing the issue on v2.4.4. Pressing left/right on remote cycles through titles (ex artist names) but can never break ouf.
mentasm 43 Posted June 25, 2016 Author Posted June 25, 2016 This seems to be partially fixed for me. Pressing the back button on the remote usually seems to bring it back now. It does continue to ignore any other remote commands, I assumne the intention is to have almosy any remote command drop it back to the main ET screen?
Luke 42242 Posted June 25, 2016 Posted June 25, 2016 Yea that's the intention. I'll review that again. Thanks.
