BJS2 0 Posted June 15, 2016 Posted June 15, 2016 (edited) I'm trying to steam an .mkv video file though the Emby android Tv app. It is running on a sony bravia kdl-50w800c. I can use dlna and it will play fine, just not through the app. I have attached the logs, it might just be a wrong setting. server-63601610683.txt transcode-0a2ca02d-9772-41f1-a531-6dfb31e38439.txt transcode-cd55ab88-18b1-4280-b553-2f150b43715f.txt transcode-e787199d-6c08-4345-9564-ccad0600ed89.txt Edited June 15, 2016 by BJS2
ebr 16337 Posted June 15, 2016 Posted June 15, 2016 Its because it is x265 which your TV doesn't support. The app should realize that though. What version of Android is running on it?
ebr 16337 Posted June 15, 2016 Posted June 15, 2016 No, wait, it is transcoding to x264... If you have quicksync enabled, try turning that off.
BJS2 0 Posted June 15, 2016 Author Posted June 15, 2016 Thanks for the fast reply it is BRAVIA 2015 Build/LMY48E.S223. Lollipop-5.1.1 yes quick sync is disabled.
BJS2 0 Posted June 16, 2016 Author Posted June 16, 2016 (edited) Got it to play by setting the max streaming bitrate to 720kb. So it transcodes the video instead of directplay. Doesn't look the best though.. Is there another way to force transcoding? Edited June 16, 2016 by BJS2
ebr 16337 Posted June 17, 2016 Posted June 17, 2016 According to your initial report, it has been transcoding all along...
darthweder 3 Posted June 27, 2016 Posted June 27, 2016 I'm encountering this same issue on my Android Nexus TV Player. Once I set the android app so it will transcode due to a too high bitrate, then I get video again. I've tried rebooting my server, and reinstalling the android app. What can I provide to you to help solve this?
BJS2 0 Posted June 27, 2016 Author Posted June 27, 2016 I think it is an issue with the embedded vlc the video will play when transcoded. But not on direct/v. I can play the video through MX player with HW+ enabled.
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 I'm encountering this same issue on my Android Nexus TV Player. Once I set the android app so it will transcode due to a too high bitrate, then I get video again. I've tried rebooting my server, and reinstalling the android app. What can I provide to you to help solve this? What is the media info from the web client for the item in question? Is it possible for you to re-mux that item removing any unnecessary streams of information (like tags)? 1
darthweder 3 Posted June 27, 2016 Posted June 27, 2016 What is the media info from the web client for the item in question? Is it possible for you to re-mux that item removing any unnecessary streams of information (like tags)? Here is the media info from two different series that are having the same problem. They have the exact same info except for the bitrate. I remuxed an episode to .mp4 and it still would not show video. One of my friends also reported that they were having the same problem on their amazon firestick when trying to watch the episode. He was using the android app version 1.2.11a. I am using version 1.2.11g
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 Okay, both of those are HEVC. Can you tell me what the last gray box on the OSD says during playback? I would imagine it is "Direct/I"...? 1
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 Okay, both of those are HEVC. Can you tell me what the last gray box on the OSD says during playback? I would imagine it is "Direct/I"...? Assuming I was correct about that, if you join the open beta you can test this out later today. Android Open Beta Testing 1
darthweder 3 Posted June 27, 2016 Posted June 27, 2016 Okay, both of those are HEVC. Can you tell me what the last gray box on the OSD says during playback? I would imagine it is "Direct/I"...? It says "Direct/V".
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 It says "Direct/V". Well, then that is the problem. Thanks. 1
CBers 7554 Posted June 27, 2016 Posted June 27, 2016 Well, then that is the problem. Thanks. Does VLC (libvlc) not support HEVC?
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 Does VLC (libvlc) not support HEVC? Doesn't appear that way. At least not the 10-bit color version.
CBers 7554 Posted June 27, 2016 Posted June 27, 2016 I have HEVC content and it plays OK my Shield(s). Would you be able to add the CODEC information to the details page in the ATV app? Might be useful to see it there rather than having to look it up in the web client.
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 I have HEVC content and it plays OK my Shield(s). In which player? The Shield should support it but the NP probably not.
CBers 7554 Posted June 27, 2016 Posted June 27, 2016 Direct/V in the OSD. I can't grab the Media Info, as for some reason, the Season isn't being displayed in the Web Clinet, whereas it is in the ATV app !!
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 Okay, then I'll continue to allow it in VLC on the Shield. Thx.
CBers 7554 Posted June 27, 2016 Posted June 27, 2016 Okay, then I'll continue to allow it in VLC on the Shield. Thx. Media Info (eventually) for one of the HEVC items: 1
darthweder 3 Posted June 27, 2016 Posted June 27, 2016 Media Info (eventually) for one of the HEVC items: I notice that is the non-10 bit profile. I'll try watching a video with that profile...
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 Okay, CBers, please test to be sure that still direct plays in VLC on your Shield with .15 when you get it. darthweder - on your NP it should transcode and play properly. 1
darthweder 3 Posted June 27, 2016 Posted June 27, 2016 Media Info (eventually) for one of the HEVC items: I just watched a video with the attached media info, and it played "Direct/V", and it played properly with no problems. So I guess it's a problem with the main10 profile? 1
ebr 16337 Posted June 27, 2016 Posted June 27, 2016 Okay. .15 is going to transcode that as well on your NP but I'll make it allow that before we release. 1
