Guest asrequested Posted August 17, 2016 Posted August 17, 2016 Oh so this is ready to use? I didn't even check.
babgvant 143 Posted August 17, 2016 Posted August 17, 2016 Oh so this is ready to use? I didn't even check. Doubtful. I don't think Luke has even accepted the changes yet .
puithove 209 Posted August 17, 2016 Posted August 17, 2016 The settings will be added automatically after they are saved through the UI (navigate to the audio/video settings, then back out). Close ET, open the XML to edit. Audio processor is either the GUID or name of the filter to load. SW DI defaults to 0, replace with the number of the scheme you want. None = 0 YADIF = 1 W3FDIF_Simple = 2 W3FDIF_Complex = 3 That'll work. Thanks again!
Guest asrequested Posted August 17, 2016 Posted August 17, 2016 I'm all aboard the good ship Emby, and awaiting a course heading from Captain Luke
Guest asrequested Posted August 18, 2016 Posted August 18, 2016 @@Luke I would beta test the beshiznitz out of this, if that would help
Sammy 791 Posted August 18, 2016 Posted August 18, 2016 (edited) So.. Did @[member=mata7] ever get 3D MKV MVC playback working? I'm interested in that because I have a few 3D rips, still in ISO for playback using Arcsoft Total Media 5.x but I want to move on to ET for my playback solution in its entirety. Edited August 18, 2016 by Sammy
Guest asrequested Posted August 19, 2016 Posted August 19, 2016 (edited) Yeah I hope he figured it out. Sorry again for hijacking this thread Edited August 19, 2016 by Doofus
Guest asrequested Posted August 25, 2016 Posted August 25, 2016 @@Luke does 2.5.11 have @@babgvant's audio filter? If it does, how do I utilize it?
Luke 42243 Posted August 25, 2016 Posted August 25, 2016 It's in the release. You'll have to find the xml config, and locate the BitstreamCodecs value. And it looks like these are the possible options: https://github.com/MediaBrowser/Emby.Theater.Windows/pull/366/files#diff-5edcee217727e10a9751387bb0114533R345
Guest asrequested Posted August 25, 2016 Posted August 25, 2016 It's in the release. I don't know how to use it. It's going to be hidden config only. I'm looking at the directshow file. Does this value need to change? <Ac3EncodingMode>0</Ac3EncodingMode>
Guest asrequested Posted August 25, 2016 Posted August 25, 2016 @@babgvant I'm pretty sure I need to put the filter I want to use in here, <AudioProcessor /> but nothing I've tried makes any difference.
babgvant 143 Posted August 25, 2016 Posted August 25, 2016 @@babgvant I'm pretty sure I need to put the filter I want to use in here, <AudioProcessor /> but nothing I've tried makes any difference. <AudioProcessor>ffdshow Audio Decoder</AudioProcessor> should work assuming that ffdshow is installed on the PC. If it doesn't you'll need to enable debug logging and send me a log file.
babgvant 143 Posted August 25, 2016 Posted August 25, 2016 I'm looking at the directshow file. Does this value need to change? <Ac3EncodingMode>0</Ac3EncodingMode> I'd forgotten about this option. If you change it to 1 (Auto) or 2 (Forced) and use the WASAPI AR it might do what you want too.
AdrianW 1058 Posted August 25, 2016 Posted August 25, 2016 I just tried changing the 0 to a 1 in <Ac3EncodingMode>0</Ac3EncodingMode> and my 5.1 AAC is now playing as 5.1 AC3 (instead of 2.0 PCM) - and the server still says it's Direct Playing Well done guys - this is fantastic. 1
puithove 209 Posted August 25, 2016 Posted August 25, 2016 @@babgvant - I turned on the SW deinterlace option - looks good, thanks. 1
AdrianW 1058 Posted August 25, 2016 Posted August 25, 2016 I just tried changing the 0 to a 1 in <Ac3EncodingMode>0</Ac3EncodingMode> and my 5.1 AAC is now playing as 5.1 AC3 (instead of 2.0 PCM) - and the server still says it's Direct Playing Spoke too soon - it works on my SPDIF connected PC, but not on the main HTPC which has audio connected via HDMI.
babgvant 143 Posted August 25, 2016 Posted August 25, 2016 Spoke too soon - it works on my SPDIF connected PC, but not on the main HTPC which has audio connected via HDMI. On your HDMI system you should get 6 channel PCM instead. Why would you want to encode that with a lossy process? (I think that's what 2 [Force] would do).
AdrianW 1058 Posted August 25, 2016 Posted August 25, 2016 On your HDMI system you should get 6 channel PCM instead. Why would you want to encode that with a lossy process? You know what? - you're right. Did something change there? I could have sworn 5.1 AAC was coming through as 2.0 PCM previously.
Guest asrequested Posted August 25, 2016 Posted August 25, 2016 This looks good. I'll test it tonight and report back. I think I will be setting it to 2 and forcing AC3 as I want my receiver to process into Atmos.
Guest asrequested Posted August 25, 2016 Posted August 25, 2016 So here's a question. The AC3 encode setting, does that use Ffmpeg? Am I right in saying I don't need ffdshow if enable that?
babgvant 143 Posted August 25, 2016 Posted August 25, 2016 You don't need ffdshow. It's a feature of the wasapi AR.
Guest asrequested Posted August 25, 2016 Posted August 25, 2016 Perfect! I can't wait to try this later. Thank you again, Babgvant
Guest asrequested Posted August 26, 2016 Posted August 26, 2016 Ok, I finally got to test this out. With the AC3 encoder set to 1, playing a stereo AAC track, it does get changed to AC3. Fabulous! To change a multi track AAC (5.1) to AC3, you do need to set it to 2, and works great. Fabulous! Trying to put ffdshow Audio Decoder in as the processor, just locks and crashes ET. Here's the thing. While using the first option, for those who are trying it. Other stereo tracks, ie. MP3 etc will also get AC3 encoded. So when playing music in ET, it will also be AC3. Not so much of a big deal for me, as I use musicbee to play music. As it affords me the ability to play music in all channel, which ET does not yet do. My hope is that one day, ET will develop to the point that music will be separated from all the AV, as how we listen to music is different to how we listen to AV media. Music needs to have its own settings. @@babgvant If you'd like to do some debugging with the processor option, I will gladly help. Tell me what you require, and I shall provide it. But I understand if you're busy and this is a low priority 1
