wered 0 Posted June 14, 2016 Posted June 14, 2016 I decided to try and install my SSL certificate to my emby install earlier, and when i created my pfx and set it to use that it worked, however when browsing to it in chrome or firefox is said it was insecure because it did not have the bundle in the .pfx file, So i generated a .pfx with both the certificate and the bundle in the certificate field, however after doing so i now get an error_connection_closed whenever i access over wan or lan, So i switched back to the original pfx without the bundle and i get the same thing, i have restarted it a few times and tried a few different ports, any idea on how to get this to work? OS Server2012R2 DC Mobo Supermicro X8DTN+ CPU X5650x2 Memory 192GB DDR3 Registered, SSL Provider Startcom
Luke 42186 Posted June 14, 2016 Posted June 14, 2016 hi, can you please provide the emby server log? http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ thanks.
