Sparrowlogins 18 Posted June 12, 2016 Posted June 12, 2016 Hi all, having an issue with these 2 film collections. Have other multi part movies that work but for some reason these 2 collections dont. The hobbit is 3d, so is named: movie -part1.3d.fsbs.mk3d The lord of the rings is just: movie -part1.mkv My discworld films like Colour of magic and The Hogfather from sky1 are also named movie -part1.mkv and work perfectly. Does anyone have any idea if I need to name the films in a specific way or as extended or with The Hobbit: etc?
Luke 42186 Posted June 12, 2016 Posted June 12, 2016 Hi there. Can you explain what your actual issue is? thanks.
Guest plexman Posted June 12, 2016 Posted June 12, 2016 Hi all, having an issue with these 2 film collections. Have other multi part movies that work but for some reason these 2 collections dont. The hobbit is 3d, so is named: movie -part1.3d.fsbs.mk3d The lord of the rings is just: movie -part1.mkv My discworld films like Colour of magic and The Hogfather from sky1 are also named movie -part1.mkv and work perfectly. Does anyone have any idea if I need to name the films in a specific way or as extended or with The Hobbit: etc? Try renaming it with "nameofthemovie - cdX.mk3d" where X is the part. It works for me perfectly.
Deathsquirrel 745 Posted June 12, 2016 Posted June 12, 2016 Where possible, use mkvmerge to combine your multipart movies into a single MKV file. Whatever your issue is, that will avoid it. For what's left be sure you're following the naming wiki rules for multiple parts. If you still have an issue describe what it actually is . 1
Luke 42186 Posted June 12, 2016 Posted June 12, 2016 You can find the supported naming conventions for file stacking in our movie naming wiki: https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming
