DaN 49 Posted January 4, 2014 Posted January 4, 2014 I found that MB Photo doesn't show photos under personal library, only default media library photo collections are counted. DaN
DaN 49 Posted January 5, 2014 Author Posted January 5, 2014 Is the collection type set properly? Yes, set as Photos; I tested that by adding collection under the default and the personal, only the one under default show counts and display images.
ebr 16342 Posted January 6, 2014 Posted January 6, 2014 Did you give it some time for the server to discover them? I just tested it out and photos are showing fine for a user-specific library. What client?
DaN 49 Posted January 6, 2014 Author Posted January 6, 2014 I set that collection long time ago, and just noticed it doesn't show photos, I tried with many clients: MB Classic Android MB Theater Web Client Is there any specific structure for the folder to show? BTW, the same structure showed properly in default library DaN
ebr 16342 Posted January 6, 2014 Posted January 6, 2014 Try creating a new photo collection for that user and see what happens.
DaN 49 Posted January 6, 2014 Author Posted January 6, 2014 I just tested now, and it seems working fine, I just used it with one folder and the images shows under personal library as expected, I'll check if a particular structure caused that problem and will let you know; Thanks DaN
