Aekyros 0 Posted June 10, 2016 Posted June 10, 2016 Hello, I'm a new user of Emby, i really love it !! it's so easy and powerfull i didn't know why i don't heard about it before. Here is my setup of Emby to explain what i excpected to do with it : Actually i use substitution path for local Kodi and i would know if it's possible to have two path substitution system ? One for local device and one for remote device. I got strong internet connexion and didn't need transcoding to play files on my remote Kodi so it would be really interessant if it's possible to dissociate local acces to files from remoted one. To resume : Local Kodi -> NFS access to NAS with substitution path Remote Kodi -> FTP access to NAS with substitution path Is this possible ? Need a bunch of modifications ? Again thanks for your great works !! PS : Sorry for my poor english, i 'm French i tried to write something understandable.
Angelblue05 4132 Posted June 10, 2016 Posted June 10, 2016 Remote access doesn't necessarily mean transcoding content. In Kodi, unless you decrease the streaming quality bitrate to a low value, should be direct streaming your content meaning Emby streams your content to Kodi via http without change to the original file. Path substitution is only looked at when direct playing your content, meaning accessing your content in Kodi via local/network paths. Sent from my iPhone using Tapatalk
Aekyros 0 Posted June 11, 2016 Author Posted June 11, 2016 (edited) Path substitution is only looked at when direct playing your content, meaning accessing your content in Kodi via local/network paths. It's exactly what i want to do. Give a direct access of my files with both local and network Kodi by using NFS and FTP. In this case Emby doesn't need to send http stream to my remote Kodi. For now we can only do it for either one. Edited June 11, 2016 by Aekyros
ebr 16337 Posted June 11, 2016 Posted June 11, 2016 It's exactly what i want to do. Give a direct access of my files with both local and network Kodi by using NFS and FTP. In this case Emby doen't need to send http stream to my remote Kodi. What we do right now is already functionally equivalent. Kodi can play a file via FTP...?
Aekyros 0 Posted June 11, 2016 Author Posted June 11, 2016 Yes without any trouble ! i use this kind of setup for two years now and I never had any problems.
ebr 16337 Posted June 11, 2016 Posted June 11, 2016 Okay, then it must be just downloading it on the fly. Like I said, this should be functionally equivalent to what we are doing via http.
Aekyros 0 Posted June 11, 2016 Author Posted June 11, 2016 Yes ! The only difference in the case of access via FTP, files are directly accessible from the NAS. Which is not the case for http stream where Emby send files. In the cases of an Rpi or light server this will be great to give direct access to the files stored in the NAS locally and also from the web. In a resource savings in mind this feature would be interesting.
Angelblue05 4132 Posted June 11, 2016 Posted June 11, 2016 (edited) I really doubt it makes much of a difference in terms of resource saving. Sent from my iPhone using Tapatalk Edited June 11, 2016 by Angelblue05
bluemonkey07 590 Posted June 11, 2016 Posted June 11, 2016 (edited) In fact for streaming video http vs FTP I believe the opposite is probably true Edited June 11, 2016 by Vidman
