FrostByte 5453 Posted June 23, 2016 Posted June 23, 2016 Hi @@FrostByte Are you have any issues with the loading of the home screen. when you go back from other content? For me it takes a long time and I just get tv and music. I don't know if regression or .37 issue. I don't seem to be having that issue that I can tell
techywarrior 689 Posted June 23, 2016 Posted June 23, 2016 My collections don't show up in the app at all (.48 was the latest I checked). Shows fine in the web client. I nonly have 70 collections so I wouldn't even expect them to take a long time loading. 1
7illusions 1249 Posted June 24, 2016 Author Posted June 24, 2016 My collections don't show up in the app at all (.48 was the latest I checked). Shows fine in the web client. I nonly have 70 collections so I wouldn't even expect them to take a long time loading. How are you accessing your collections, from mainview or movies view?
techywarrior 689 Posted June 24, 2016 Posted June 24, 2016 (edited) How are you accessing your collections, from mainview or movies view? I don't have my movies set to be shown as collections in the settings. I assumed that Collections is the actual collections list like in the web client (in case you are using the setting for some reason). Anyway, to answer your question, I simply click on my Movie collection on the left side and then Collections at the top. (Suggested, latest, etc.) Nothing ever shows up no matter how long I seem to wait. Edit: One other thing that may be different (because obviously other people can see their collections) is that I have two libraries set for movie type. Remember I have my shorts in a library called Shorts (which is set as Movies too but not included in the main Movies library) Edited June 24, 2016 by techywarrior
Xzener 729 Posted June 24, 2016 Posted June 24, 2016 Looking great so far. Responsive, and quick/smooth animations. One thing I noticed right away, not sure if its been reported yet...
FrostByte 5453 Posted June 25, 2016 Posted June 25, 2016 New Photo viewer always starts with the first photo. Expected behavior: when clicking a photo in a folder would expect the viewer to start with the photo selected, not the first photo Version .52
FrostByte 5453 Posted June 25, 2016 Posted June 25, 2016 (edited) I don't have my movies set to be shown as collections in the settings. I assumed that Collections is the actual collections list like in the web client (in case you are using the setting for some reason). Anyway, to answer your question, I simply click on my Movie collection on the left side and then Collections at the top. (Suggested, latest, etc.) Nothing ever shows up no matter how long I seem to wait. Edit: One other thing that may be different (because obviously other people can see their collections) is that I have two libraries set for movie type. Remember I have my shorts in a library called Shorts (which is set as Movies too but not included in the main Movies library) I think this error has been there for awhile, should already be tracked You should see collections from main hopefully http://emby.media/community/index.php?/topic/35799-uwp-testers/page-7&do=findComment&comment=340404 Edited June 25, 2016 by FrostByte
FrostByte 5453 Posted June 25, 2016 Posted June 25, 2016 (edited) New Playlist doesn't auto start. Expected playlist to autostart like with old version of app Steps 1. Click playlists 2. select audio playlist 3. Click (...) 4. Click Shuffle Now playing screen pops up at the bottom, but then you have to click the Play button to start Edit: NM I forgot you were waiting for the new SDK Edited June 25, 2016 by FrostByte
Vicpa 612 Posted June 25, 2016 Posted June 25, 2016 (edited) Hi 7 Play of TV should work. Transcoding nonsense. Can you let it direct play. I added mpeg2video and mpeg2 to the streaming profile for the ts stream as well as ac3, which is what most tv in the states is....no luck The transcode ts with aac decode, just shows one frame and stops, seen this on other clients. Transcode with ac3, is a mess. no audio copy Was told months ago that was unreliable with hls. well this ain't that. (by the way I ran an audio copy for months with no problems. Stream #0:2 -> #0:0 (mpeg2video (mpeg2_qsv) -> h264 (h264_qsv)) Stream #0:0 -> #0:1 (ac3 (native) -> ac3 (native)) Please put me out of my misery and let me direct play . Here is the transcode log. transcode-430a194d-c727-4bd5-99d8-e59470c5fe22.txt Edit Hi @@7illusions, maybe I didn't make the above changes. It looks like the profile is being overwritten with the defaults each time it is opened. Edited June 25, 2016 by Vicpa
Vicpa 612 Posted June 25, 2016 Posted June 25, 2016 New Playlist doesn't auto start. Expected playlist to autostart like with old version of app Steps 1. Click playlists 2. select audio playlist 3. Click (...) 4. Click Shuffle Now playing screen pops up at the bottom, but then you have to click the Play button to start Edit: NM I forgot you were waiting for the new SDK Hi Frostbyte 7 the above works for me. (I am on 14372 though) 1
FrostByte 5453 Posted June 25, 2016 Posted June 25, 2016 Hi Frostbyte 7 the above works for me. (I am on 14372 though) Ahh, thanks for testing. I tried a few times and got the same result so maybe that's it.
Vicpa 612 Posted June 25, 2016 Posted June 25, 2016 (edited) Ahh, thanks for testing. I tried a few times and got the same result so maybe that's it. No your right. I hit play it started, then remembered you said shuffle, so I hit that it paused shuffled and started right up. if you just hit shuffle first you do have to click play. I do like you can shuffle in progress though. Edited June 25, 2016 by Vicpa 1
Vicpa 612 Posted June 26, 2016 Posted June 26, 2016 Hi I figured out how to get back to HLS for Live TV and as expected the transcode is much better. The thing to look at is the playback works nicely but it is in chunks plays for about a minute. thinks and plays again. maybe a buffering thing?
Vicpa 612 Posted June 26, 2016 Posted June 26, 2016 Hi 7 Some more info for you on live tv. If I turn off hardware acceleration on the server, it plays just fine in the app. Looks pretty nice . Definitely some server challenges.
7illusions 1249 Posted June 26, 2016 Author Posted June 26, 2016 Hi 7 Some more info for you on live tv. If I turn off hardware acceleration on the server, it plays just fine in the app. Looks pretty nice . Definitely some server challenges. Awesome. Did you have to do any profile tweaks, or did it just work?
Vicpa 612 Posted June 26, 2016 Posted June 26, 2016 Hi, Yes I nuked the ts stream to have it use hls. StreamingProfile.json.txt and shut off quicksync (not a really viable long term solution, but not your issue.) transcode-62183ee4-66eb-47df-a95e-fdcb936cadaf.txt
7illusions 1249 Posted June 30, 2016 Author Posted June 30, 2016 Sorry for the delay in updates, I haven't taken a break or anything, It's just some big changes for the time being. Here's what's going on: I've updated to the preview SDK, this means that you will have to run a windows preview build higher than .366 to run next build (slow ring should be ok for desktop if I'm not mistaken) Redesigning the menu Redesigning DetailsViews and HomeView Adding some graphical candy(real time blur etc) Hopefully I'll have a new build during the weekend. 1
Vicpa 612 Posted June 30, 2016 Posted June 30, 2016 Hi Sounds great can't wait to see I know there are folks anxious to try on the Xbox, is that platform getting closer for testing? -Vicpa
FrostByte 5453 Posted June 30, 2016 Posted June 30, 2016 I've updated to the preview SDK, this means that you will have to run a windows preview build higher than .366 to run next build (slow ring should be ok for desktop if I'm not mistaken) I haven't been keeping up with the preview builds lately. Guess I will look into getting 14376 which was just released I know there are folks anxious to try on the Xbox, is that platform getting closer for testing? So want to upgrade my XB1 to the new XB1S with UHD BD player and UHD streaming, etc
Vicpa 612 Posted June 30, 2016 Posted June 30, 2016 I haven't been keeping up with the preview builds lately. Guess I will look into getting 14376 which was just released So want to upgrade my XB1 to the new XB1S with UHD BD player and UHD streaming, etc 14379 just came out this pm. 1
7illusions 1249 Posted July 1, 2016 Author Posted July 1, 2016 Hi Sounds great can't wait to see I know there are folks anxious to try on the Xbox, is that platform getting closer for testing? -Vicpa Since MS hasn't sorted out app deployment to the xb1 and the latest build is 352 it's not possible. However, if you want to find out how navigation behaves with a controller, just connect your xb1 controller to the machine running the app with a USB cable and you should be able to try it out.
Vicpa 612 Posted July 1, 2016 Posted July 1, 2016 Hi Wow looks pretty nice . Like the detail screens. I have one problem for the life of me I can't seem to scroll down on the main hub. The mouse and remote just take me left of right. Will continue to check but the other thing is the playto context screen just flashes can't select anything. nice work 7!!
7illusions 1249 Posted July 1, 2016 Author Posted July 1, 2016 Hi Wow looks pretty nice . Like the detail screens. I have one problem for the life of me I can't seem to scroll down on the main hub. The mouse and remote just take me left of right. Will continue to check but the other thing is the playto context screen just flashes can't select anything. nice work 7!! The PlayTo functionality will be moved to upper right corner of the screen, the same way as wmthe webcloent does it. That's why i haven't put any effort on fixing that.
Xzener 729 Posted July 1, 2016 Posted July 1, 2016 Mine fails to install via PowerShell. Here is a screenshot of the failure. Any ideas on how to fix? I uninstalled the previous version.
SikSlayer 254 Posted July 1, 2016 Posted July 1, 2016 (edited) Mine fails to install via PowerShell. Here is a screenshot of the failure. Any ideas on how to fix? I uninstalled the previous version. Are you using Windows Preview builds of Windows 10? I just saw that mentioned in the changelog, so I guess I can't use it until August. Still can't install it on my Lumia 640 with the latest Fast build... Edited July 1, 2016 by SikSlayer
