FrostByte 5453 Posted January 13, 2017 Posted January 13, 2017 v196 Home Screen Settings - "Automatically group content" boxes are not working On the XB1 you can not place a check in boxes. On Windows PC they can be checked, but don't seem to change anything on the HS after saving 1. Navigate to Home Screen Settings 2. Place check marks under "Automatically group content" 3. Click "Save" 4. Navigate to HS
FrostByte 5453 Posted January 13, 2017 Posted January 13, 2017 I haven't seen any new regressive bugs in RC4 2
Vicpa 612 Posted January 14, 2017 Posted January 14, 2017 I haven't seen any new regressive bugs in RC4 I can say the same
Vicpa 612 Posted January 14, 2017 Posted January 14, 2017 Hi 7 One small UI thing, not a showstopper (xbox theme) 1) If you use the Return Button (I think same as Back Arrow key) from the Full Screen View, You go to the album detail view. (all good) 2) The play button has the highlight box around it (all good) 3) If you stay there, the screen saver kicks in, but the highlight box stays and remains visible while the screen saver is running. ( not so good). A tap on a directional button, kills the highlight but as it should and takes you out of screen saver. Like I said little thing not a showstopper. -vicpa
FrostByte 5453 Posted January 15, 2017 Posted January 15, 2017 (edited) v196 Home Screen Settings - "Automatically group content" boxes are not working On the XB1 you can not place a check in boxes. On Windows PC they can be checked, but don't seem to change anything on the HS after saving 1. Navigate to Home Screen Settings 2. Place check marks under "Automatically group content" 3. Click "Save" 4. Navigate to HS All but 2 of the boxes on the XB1 are gone now (Movie and TV are left), however they still aren't selectable on XB1 and don't do anything that I can tell on wife's SP4 Edited January 15, 2017 by FrostByte
FrostByte 5453 Posted January 18, 2017 Posted January 18, 2017 Anyone notice the missing pic symbol in the dashboard? Is that supposed to be the Ember logo? 3
FrostByte 5453 Posted January 18, 2017 Posted January 18, 2017 Is the new Now Playing only for Windows clients? I noticed the XB1 is still using the old, but my wife's SP4 has the new one.
FrostByte 5453 Posted January 18, 2017 Posted January 18, 2017 Also, it looks like the support option is gone on the XB1 using v201
7illusions 1249 Posted January 19, 2017 Author Posted January 19, 2017 Hmm.. that is strange. It's definetly not intentional.
FrostByte 5453 Posted January 19, 2017 Posted January 19, 2017 202 sends a "Entered Background" system notification every time I minimize it
FrostByte 5453 Posted January 19, 2017 Posted January 19, 2017 In fact they are still popping up even though I closed Ember. How do I make them stop?
7illusions 1249 Posted January 20, 2017 Author Posted January 20, 2017 It's not possible Without a new build I'm afraid. It's a side effect from the Debug configuration . I will make a new build that removes it
CBers 7554 Posted January 20, 2017 Posted January 20, 2017 How do I make them stop? Turn off the XB1 1
FrostByte 5453 Posted January 20, 2017 Posted January 20, 2017 (edited) It's not possible Without a new build I'm afraid. It's a side effect from the Debug configuration . I will make a new build that removes it Okay, well I may be able to live with it for a bit if you need it there to test. They did finally stop after awhile of being closed Edited January 20, 2017 by FrostByte
FrostByte 5453 Posted January 20, 2017 Posted January 20, 2017 I was wrong, just saw another one pop up and it' been closed at least 6 hours. I can just live with it for now
Vicpa 612 Posted January 20, 2017 Posted January 20, 2017 I was wrong, just saw another one pop up and it' been closed at least 6 hours. I can just live with it for now You can keep the app open JK they are a little annoying , 7 they at least all look good here. Looks like they are memory usage checks and all the messages I got were well below the targets -vicpa
FrostByte 5453 Posted January 20, 2017 Posted January 20, 2017 Sounds good, I'll just leave it on and go back to bed
Vicpa 612 Posted January 21, 2017 Posted January 21, 2017 Hi All, Yikes!! for an alpha release this is great. Everything seems to be working, no crashs on the beta theme and the memory checks have all been low. Let us know when you are ready for comments. 1
7illusions 1249 Posted January 22, 2017 Author Posted January 22, 2017 Hi All, Yikes!! for an alpha release this is great. Everything seems to be working, no crashs on the beta theme and the memory checks have all been low. Let us know when you are ready for comments. I'd say now. 1
Vicpa 612 Posted January 22, 2017 Posted January 22, 2017 Hi, OK, The genre view looks great !! It would be my preference. The buttons still need to be hooked up. Another opinion/preference to consider, is the mouse over button and ellipse might look better to the left of the track time or slightly off center to the right (Play button aligned under the ellipse at the top) I like the "Resume at" I really like the way this is shaping up. Thanks 7 !!!!!! -vicpa
FrostByte 5453 Posted January 22, 2017 Posted January 22, 2017 BUG: Now Playing stops highlighting the currently playing song after minimizing. Steps: 1. Open playlist/album 2. Click Play button 3. Click the Song title/Artist in lower left corner to bring up Now Playing 4. Minimize app to tray 5. Maximize app. 6. App no longer jumps/highlights the currently playing song in the queue. The song which was playing when app was minimized remains highlight when next song starts
Vicpa 612 Posted January 22, 2017 Posted January 22, 2017 (edited) Hi, Go to Album or Artist from the flyout doesn't show Album Art or Artist thumb Here is the artist example. Standard Artist view Go to Artist from the flyout Edited January 22, 2017 by Vicpa
Vicpa 612 Posted January 23, 2017 Posted January 23, 2017 Hi 7 Missing art in a few more places, Artists is fixed. Playlists. Album art from view album flyout on queue view (same as) artist. Random Crashes seem a little more frequent, changing themes will trigger a series of them and it almost seems like the first time you go to some views it will crash, reopen the app and then you are good to go, Will look for some consistent pattern but haven't found one yet. The logs don't seem to capture a error they just end. Let me know if you need them.
