Vicpa 612 Posted October 29, 2016 Posted October 29, 2016 Hi I don't use sync often. Is there any specific you would us to test? I ran a sync job today, original quality. It started right away so I didn't have to force it. Completed and is in my library.
Vicpa 612 Posted November 1, 2016 Posted November 1, 2016 Hi .140 is working great for me. Nice job 7 as usual !!!. Anyone else try direct play?
7illusions 1249 Posted November 2, 2016 Author Posted November 2, 2016 I'm currently working on improving the Offline mode, almost done, and will put 141 up on xb1 4
Vicpa 612 Posted November 3, 2016 Posted November 3, 2016 (edited) Hi, Small bug, has been around for a long time. Keep forgetting about it. Music Artists with an "&" are truncated to the first artist in the track details and the Now Playing screen. For example Bob Dylan & The Band. Shows correctly under album artists. But when you get to now playing only Bob is shown. Now Playing Screen Album Artist. Album Detail. The track detail, I assume is the Album Artist in this case it should be "Bob Dylan & The Band" if you wanted to use "artists" which wouldn't be a bad idea it would be "Bob Dylan; The Band" Thanks -vicpa edit: BTW the media transport control when you bring it up via the remote shows "Bob Dylan & The Band" Edited November 3, 2016 by Vicpa
Vicpa 612 Posted November 4, 2016 Posted November 4, 2016 Hi All, I have taken a quick look at 145 and nothing has juimped out. Will check in more detail a little later. Awesome 7, Thanks -vicpa 1
Vicpa 612 Posted November 5, 2016 Posted November 5, 2016 Hi 7 New glitch . A server thing maybe you can trap an error around. Schedules Direct is/was down so the guide data is in some weird state that the app doesn't like. It displays the first two lines and then crashes. It worked fine yesterday before the last schedule refresh. So it is not specifically an app thing. This is the error. that shows in the server log. 2016-11-05 08:25:09.1830 Info HttpClient: HttpClientManager POST: https://json.schedulesdirect.org/20141201/token2016-11-05 08:25:09.2666 Error App: Error getting programs *** Error Report *** Version: 3.0.8500.0 Command line: C:\Users\XXXXXX\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.2.9200.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\XXXXXX\AppData\Roaming\Emby-Server Application Path: C:\Users\XXXXXX\AppData\Roaming\Emby-Server\System\MediaBrowser.ServerApplication.exe Could not authenticate with Schedules Direct Error: Server offline for maintenance. System.ApplicationException at MediaBrowser.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetTokenInternal>d__30.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetToken>d__27.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.Listings.SchedulesDirect.<GetProgramsAsync>d__11.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsyncInternal>d__68.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at MediaBrowser.Server.Implementations.LiveTv.EmbyTV.EmbyTV.<GetProgramsAsync>d__66.MoveNext() The server better fix the data when Schedules Direct is back doing it thing. So it should go away. But one never knows. Maybe you can trap what ever error is causing the crash? You can test with my server. Any help would be appreciated. -vicpa
7illusions 1249 Posted November 5, 2016 Author Posted November 5, 2016 The problem is that one program is reported with a enddate that is 30 minutes before the startdate. Since the guide controls width are calculated on the duration of the program, calculated by Endtime-Starttime, a negative width was acheived, which crashes the app. I've added a fix for it, will be in next beta. 2
Vicpa 612 Posted November 6, 2016 Posted November 6, 2016 Hi All, The bad data has rolled off the guide, so it is working fine now. Thanks for adding the fix in case it happens again. !! 1
Vicpa 612 Posted November 7, 2016 Posted November 7, 2016 Hi 7 Is 145 Officially released? It is kinda worthy of an announcement don't you think
Vicpa 612 Posted November 7, 2016 Posted November 7, 2016 k, didn't know if was beta or release that came through the store. Really need a direct play announcement. Curious to see how others make out.
FrostByte 5453 Posted November 7, 2016 Posted November 7, 2016 Would be nice to see if this corrected Crestj's issue, hopefully
Vicpa 612 Posted November 7, 2016 Posted November 7, 2016 Would be nice to see if this corrected Crestj's issue, hopefully Hope so, I don't use sync so is tough to test all use cases. But 7 is on it so will be better I am sure . The presentation looks much better.
Vicpa 612 Posted November 8, 2016 Posted November 8, 2016 Hi 7 Nice Mention of the app on The Digital Lifestyle http://thedigitallifestyle.com/w/index.php/2016/11/07/ember-the-emby-media-player-app-for-windows-10-updated/
FrostByte 5453 Posted November 8, 2016 Posted November 8, 2016 Hi 7 Nice Mention of the app on The Digital Lifestyle http://thedigitallifestyle.com/w/index.php/2016/11/07/ember-the-emby-media-player-app-for-windows-10-updated/ He didn't mention XB1
Vicpa 612 Posted November 11, 2016 Posted November 11, 2016 Hi @MrWebsmith Have you tried Direct Play of TV?
MrWebsmith 598 Posted November 11, 2016 Posted November 11, 2016 (edited) ill test tonight on my sp4 and then i guess i could also try on xb1... ill report back edit: should i test on .145 or whatever the latest is from hockeyapp? Edited November 11, 2016 by MrWebsmith
FrostByte 5453 Posted November 11, 2016 Posted November 11, 2016 145 is the latest on hockeyapp and all stores right now
Vicpa 612 Posted November 11, 2016 Posted November 11, 2016 Definately should work on the XBone, may on the sp4 Switch in the playback setting
Vicpa 612 Posted November 13, 2016 Posted November 13, 2016 (edited) Hi 7 , All Looks like MS realized it needed to keep up with you 7 With 14965 and 145 playback is awesome, Now with direct play of Live TV, 14965 fixed DTS,DTS-HD so that it is now bitstreaming again. I saw they announced TrueHD support for the Xbone, hopefully that will come to the PC as well. In 14965 that pesky bug with actor images seems to have disappeared as well at least so far. Must be something funky with the control. I still have a few things on my list (LOL ) shuffle, playlists and such,........but maybe time for the screensaver ??? Media info (icons) on the detail screens ? I am also still waiting for the link on the "About" screen to "Rate this app in the Store" and a "Contribution link"(really need one of these) thanks -vicpa Edited November 13, 2016 by Vicpa 1
