FrostByte 5453 Posted September 10, 2016 Posted September 10, 2016 DTS-ES is a weird one because it's 6.1
FrostByte 5453 Posted September 10, 2016 Posted September 10, 2016 (edited) I've also got some of DTS-HD and DTS-HD/MA (they must be different) Edited September 10, 2016 by FrostByte
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 So far I'm not getting any sound at all on my XB1 playing movies with DTS. It says it's Direct Streaming though. Will play around with it some more tomorrow. AC3/DD works fine
7illusions 1249 Posted September 12, 2016 Author Posted September 12, 2016 Have you enabled bitstreaming on the Xbox, in system settings?
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 Yes, that is enabled. It says it's bitstreaming both ACS and DTs in the top right, but I get no sound for DTS for some reason. I'm up now, so I'll play with settings, cabling, etc and see if it's my setup
7illusions 1249 Posted September 12, 2016 Author Posted September 12, 2016 Ok. Could be that MS hasn't gotten around supporting Bitstreaming from apps yet.
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 Not sure how up-to-date this is, but according to the link DTS is not supported in mkv format on the XB1. I wonder if it will work remuxed into .ts like you had the app doing before http://support.xbox.com/en-US/xbox-one/apps/mkv-support
MrWebsmith 598 Posted September 12, 2016 Posted September 12, 2016 i cant believe this happened this weekend and i missed it.. ill get this onto my xb1 tonight guys.. sorry .. ( 7.. pm me if you need my gamertag thing again) 1
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 I think he needs your MS email account you use on your XB1 to get the betas. Currently at 118 1
CBers 7554 Posted September 12, 2016 Posted September 12, 2016 I'm only seeing v4.0.111 in the Xbox One Store. Is Beta not available yet?
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 I've got the beta. I think the description still says 111 in the store, but I had an "Update" button which gave me 118
CBers 7554 Posted September 12, 2016 Posted September 12, 2016 Are you a beta tester though? Not sure 7 has sorted me out yet. Did you originally purchase it?
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 I believe he added me to the XB1 beta list the other day when he added you. Yes, I've purchased the app before
CBers 7554 Posted September 12, 2016 Posted September 12, 2016 I believe he added me to the XB1 beta list the other day when he added you. Yes, I've purchased the app before I don't have an issue buying it, just wanted to confirm the correct process Thanks.
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 I don't know if it's a requirement, I thought you were getting the betas
CBers 7554 Posted September 12, 2016 Posted September 12, 2016 I don't know if it's a requirement, I thought you were getting the betas No, because I've been waiting for the Xbox One release.
FrostByte 5453 Posted September 12, 2016 Posted September 12, 2016 v120 Can the navigation on the XB1 Home page be changed so that when you arrow down it goes to the latest movies first. Basically in the order you see it on the page. Right now if you scroll down once it brings you to "Next Up Episodes" and the you can jump up to the latest movies.
7illusions 1249 Posted September 13, 2016 Author Posted September 13, 2016 Isn't Latest Movies already focused when navigating to Home?
7illusions 1249 Posted September 13, 2016 Author Posted September 13, 2016 @@CBers you should see 4.0.120.. I don't know if you need to buy the app or not though. Don't know how store works with that yet. 1
CBers 7554 Posted September 13, 2016 Posted September 13, 2016 @@CBers you should see 4.0.120.. I don't know if you need to buy the app or not though. Don't know how store works with that yet. OK, thanks. I'll try again tonight and see what happens
MrWebsmith 598 Posted September 13, 2016 Posted September 13, 2016 got 120 on the xb1 last night.. spent some time learning the navigation which i think had already had a number of fixes.. great work so far on this.. felt very intuitive even with the gamepad - episode overlay circle needs to be a good 30% bigger to me at least.. larger/clearer font for the "unwatched count as well"... tough to see when on tv (1080p) for categories like "next up" "latest etc" for tv especially.. can we check and use the THUMB image first if there... on the testing last night i was seeing either episode images or backdrops for those areas.. just an initial couple ideas... i have playback testing on the agenda tonight 1
FrostByte 5453 Posted September 13, 2016 Posted September 13, 2016 Isn't Latest Movies already focused when navigating to Home? It doesn't seem to be, at least I can't control anything in latest movies area until I arrow down and then back up.
CBers 7554 Posted September 13, 2016 Posted September 13, 2016 Isn't Latest Movies already focused when navigating to Home? It doesn't seem to be, at least I can't control anything in latest movies area until I arrow down and then back up. Could that be configurable, as I'd prefer Next Up TV as the default view 1
MrWebsmith 598 Posted September 13, 2016 Posted September 13, 2016 Could that be configurable, as I'd prefer Next Up TV as the default view YES YES YES YES lol 2
