Vicpa 612 Posted August 10, 2016 Posted August 10, 2016 Hi All Pause, play, stop a thing of beauty from the remote. even art in the OSD. Awesome!!! Thanks One minor ui thing with the remote. If you use it to start video playback from the details screen in movies. You get this square box in upper right. Mouse and Keyboard no. Pause and Play etc once on playback screen no box. See Below Thanks 7 !!! Will continue to check -vicpa 1
7illusions 1249 Posted August 10, 2016 Author Posted August 10, 2016 Hi All Pause, play, stop a thing of beauty from the remote. even art in the OSD. Awesome!!! Thanks One minor ui thing with the remote. If you use it to start video playback from the details screen in movies. You get this square box in upper right. Mouse and Keyboard no. Pause and Play etc once on playback screen no box. See Below Thanks 7 !!! Will continue to check -vicpa Updated build available. 1
FrostByte 5453 Posted August 10, 2016 Posted August 10, 2016 (edited) Just loaded .87 and playing with subtitles a little more. Not sure if this is a bug or a request, but shouldn't subtitles marked as "forced" play automatically? They do in other clients. I have to manually select the subtitle wether it's forced or not. Only when there isn't a forced subtitle would I think I have to manually select a subtitle Edit: my subtitles are all "movie name.eng.forced.srt" or just "movie title.eng.srt" external Edited August 10, 2016 by FrostByte
7illusions 1249 Posted August 10, 2016 Author Posted August 10, 2016 Yes, that part I actually had forgotten about. Will add it to the backlog. 2
7illusions 1249 Posted August 11, 2016 Author Posted August 11, 2016 Just loaded .87 and playing with subtitles a little more. Not sure if this is a bug or a request, but shouldn't subtitles marked as "forced" play automatically? They do in other clients. I have to manually select the subtitle wether it's forced or not. Only when there isn't a forced subtitle would I think I have to manually select a subtitle Edit: my subtitles are all "movie name.eng.forced.srt" or just "movie title.eng.srt" external @@FrostByte can you try latest beta. Also, can you test with .ass and .ssa subs to see if they work?
FrostByte 5453 Posted August 11, 2016 Posted August 11, 2016 @@FrostByte can you try latest beta. Also, can you test with .ass and .ssa subs to see if they work? I don't have any other formats other than SRT, but I'll search for some. Would like to figure out why that other guy is having problems with subtitles
FrostByte 5453 Posted August 11, 2016 Posted August 11, 2016 Nm, I have the program SubEdit and it looks like it can save as other formats. Will try something after loading new beta
FrostByte 5453 Posted August 11, 2016 Posted August 11, 2016 (edited) v89 It appears it's burning in the subtitle and displaying the text subtitle at the same time. It did it automatically though, when I click "cc" it was already on. http://pastebin.com/Dy0ikVvy Cinema Paradiso (1988).mkv Cinema Paradiso (1988).eng.forced.srt Edit: it was very, very choppy as well. Played a short bit, then transcoded/buffered some more every 20 - 30 seconds. Oh, and it crashed once also Edited August 11, 2016 by FrostByte
7illusions 1249 Posted August 11, 2016 Author Posted August 11, 2016 Thanks. I'll get a new version up tomorrow. 3
Vicpa 612 Posted August 12, 2016 Posted August 12, 2016 Hi, I be going back another thing of beauty!! Small but big regression. the header of the playback screen doesn't disappear when playback starts.
7illusions 1249 Posted August 12, 2016 Author Posted August 12, 2016 Hi, I be going back another thing of beauty!! Small but big regression. the header of the playback screen doesn't disappear when playback starts. DAMN!! How could I forget that part.. It will be fixed asap.
FrostByte 5453 Posted August 12, 2016 Posted August 12, 2016 v91 Subtitles seem work as designed. Tried with external SRT, will try other formats in a bit. Double subtitles is gone. Still stutters, but not as bad as v89 when it burned in the subtitles too. I think someone may have mentioned this already, but wanted to add a picture 1
7illusions 1249 Posted August 12, 2016 Author Posted August 12, 2016 When it stutters, any special bitrate/format etc? Or is it random?
FrostByte 5453 Posted August 12, 2016 Posted August 12, 2016 The only thing I can figure out is that all my AC3 files stutter at the beginning. DTS files play fine. Not sure if that's because DTS files are always remuxed, or what. Bitrate doesn't seem to be the issue for me, I have a lot of high bitrate DTS files
Vicpa 612 Posted August 12, 2016 Posted August 12, 2016 Hi, I sent some notes, this was in the forum "My other problem is one I know your looking into but for more info for you. Video playback stuttering (Not on live TV) On the same PC as the server with loopback set. Running the latest Windows 10 (1607?) I did noticed it seemed better using Emby Connect rather than just selecting the server." Frostbyte if you sync one and play it that way does it still stutter?
FrostByte 5453 Posted August 12, 2016 Posted August 12, 2016 I haven't tried syncing yet. Will try that. Most of my testing is on my server with loopback. When my wife gets home I'll try it on her laptop with and without sync
7illusions 1249 Posted August 12, 2016 Author Posted August 12, 2016 You can still sync, even if it's on the same machine.. 1
Vicpa 612 Posted August 12, 2016 Posted August 12, 2016 Hi 7 Even on loopback you are still getting a direct stream right.
7illusions 1249 Posted August 12, 2016 Author Posted August 12, 2016 Yes. UWP apps don't have access to the filesystem programatically, only by showing a filepicker dialog.
FrostByte 5453 Posted August 12, 2016 Posted August 12, 2016 Heh, I'm going to have to figure this out. I got some shows synced, but I keep making it crash. I'll try something different
FrostByte 5453 Posted August 12, 2016 Posted August 12, 2016 I've tried 2 movies synced so far and both played much better synced than not. I was using original quality too. Also, can make it crash doing these steps every time Click "Offline" circle Click Server to connect to This is from my Emby server using loopback
7illusions 1249 Posted August 12, 2016 Author Posted August 12, 2016 Thanks, will get on the bug asap. Playback, wonder what's causing it...
FrostByte 5453 Posted August 12, 2016 Posted August 12, 2016 I'll keep trying to figure it out. So far I've seen 1. ACS is worse than DTS for stuttering (maybe because DTS remuxes and ACS doesn't) 2. Seems to be get better after first 20 seconds of video Maybe it is a buffering thing, but hitting pause doesn't seem to help
FrostByte 5453 Posted August 12, 2016 Posted August 12, 2016 I tried ASS/SAA subtitles externally and they both worked fine. That other guy still hasn't replied to say what his files were
SikSlayer 254 Posted August 12, 2016 Posted August 12, 2016 I tried ASS/SAA subtitles externally and they both worked fine. That other guy still hasn't replied to say what his files were Was it me? I think I remember mentioning them.
