FordGT90Concept 103 Posted June 9, 2016 Posted June 9, 2016 (edited) AMD VCE back in 2014 so I was hoping to see this added to Emby for those with GCN-based graphics cards. Most of you know what it is but for those unfamiliar, see here. I'm very tempted to put a Polaris 11 card in my server when they become available so really looking forward to VCE support. Edited June 9, 2016 by FordGT90Concept
Luke 42245 Posted June 10, 2016 Posted June 10, 2016 The man question is whether ffmpeg supports it or not. if it does then that makes it realistic.
FordGT90Concept 103 Posted June 10, 2016 Author Posted June 10, 2016 (edited) I searched for the last hour and I'm reaching the conclusion of "no." It's looking like Handbrake hasn't yet released their version including VCE (it was announced back in January--Intel QSV took a year between announcement and it being made publicly available). Apparently it is likely to show up in ffmpeg after Handbrake goes live. Here's an AMD promotional video of it: https://www.youtube.com/watch?v=rI4fzMDDxYg Edited June 10, 2016 by FordGT90Concept
Luke 42245 Posted June 10, 2016 Posted June 10, 2016 Thanks for the info. Strange though because i thought handbrake just used ffmpeg like we do.
FordGT90Concept 103 Posted June 10, 2016 Author Posted June 10, 2016 (edited) This post appears to be the most current: https://forum.handbrake.fr/viewtopic.php?f=26&t=34362&p=160687&hilit=VCE#p160687 HandBrake already has QuickSync support. Some QuickSync hardware supports h.265 encoding (I don't know which CPUs offhand have this). There is a patch being worked on for AMD VCE support (no eta, it's done when it's done). AFAIK, nobody has started work on NVENC yet, but the VCE work should create a foundation for NVENC since HandBrake would use the libav abstraction of these hardware encoders for both. I thought I posted this already but apparently not. Parts of NVENC can't be distributed because they're proprietary. Anyone wanting to use it has to install the NVIDIA SDK as well (big red box at bottom of page): https://wiki.libav.org/Encoding/h264 That said, libav appears to support NVENC and, by extension, so does ffmpeg: https://trac.ffmpeg.org/wiki/HWAccelIntro •Locally installed nvEncodeAPI.h header files from the NVENC SDK If Handbrake devs are working directly on libav to add VCE support, I'm not finding it (might be private). Edited June 10, 2016 by FordGT90Concept
