traeuble 0 Posted June 9, 2016 Posted June 9, 2016 Hello,I hope it this is the right place to put this because my problem is about to the legacy version of Emby Theater.I want to use MPC-HC as an external player out of MBT but the file always starts from the beginning. At the dashboard it shows me which file is playing (until I close the player) but not the position of the play progress.As I understood, I have to activate the web interface by using the "listen to port" checkmark in MPC-HC.My command line arguments in the external player settings in MBT are: {PATH} /start {ms} /fullscreen /play /close any help would be greatly appreciated
ebr 16335 Posted June 9, 2016 Posted June 9, 2016 I didn't think progress tracking was ever implemented with external players in MBT (either version)... 1
Luke 42242 Posted June 9, 2016 Posted June 9, 2016 Yea that's correct, this was never supported, sorry. 1
traeuble 0 Posted June 9, 2016 Author Posted June 9, 2016 ok thank youI will then stick with MPC Remote
AdrianW 1058 Posted June 9, 2016 Posted June 9, 2016 If EMC can send the appropriate commands to MPC-HC to cause resume then surely it shouldn't be that hard for ET to do the same?
Xavmorn 2 Posted November 25, 2016 Posted November 25, 2016 Any progress of this being added? Sent from my ONEPLUS A3000 using Tapatalk
Luke 42242 Posted November 25, 2016 Posted November 25, 2016 The apps's external player mechanism is generic. I think a plugin to build an MPC-specific player would be a great community addition, and all it would take is a little skill with JavaScript. 1
