i think the emby urls have changed. unless someone updates the skin i dont think it will work
Hi Guys,
Unfortunately, the user data has not been displayed for some time.
Since I am working on a new version (v2) I have not taken the time to find out why this is so. (Maybe somebody wants to take care of it ;) )
Unfortunately, the new version will take a while, because I'm very busy at the moment.
Maybe I can do it a first beta on the weekend to provide.
Until then
Taurec
P.S. wow I'm really surprised that the last version is almost 2 years old.
Edited by Taurec
  • Like 2
iplayforkeepz
Thanks Taurec! Please let me know if you need any beta testing.
Hello iplayforkeepz,
if you want, you can try the following
- Please create an API Key. (e.g. App Name: Rainmeter)
- copy the API key
- Visit the following URLs with your EmbyIP and Port and the your ApiKey
h**p://EmbyIP:Port/Sessions?api_key=yourApiKey&format=xml
h**p://EmbyIP:Port/Sessions?api_key=yourApiKey&format=json
please post the result.
thx Taurec
Edited by Taurec
iplayforkeepz
Will try tomorrow and report back.
Aussiedroid
Great to see you back around @@Taurec!
Look forward to seeing what the new version holds.
iplayforkeepz
What am I supposed to be seeing?
  • 5 months later...
Hi,
The x-s are intentional, just deleted some keys
DBUG (17:33:59.210) TDK_Emby\TDK_Emby.ini - [WP_Emby]: Fetching: http://10.10.10.100:8096/Sessions?api_key=cfed66fff0xxxxxxxxxxxxxxxxx389c5&format=xml.xml
DBUG (17:33:59.218) TDK_Emby\TDK_Emby.ini - [WP_Emby]: Index  0: Type 'MediaBrowser.Controller.Entities.Movies.Movie' with data contract name 'Movie:http://schemas.datacontract.org/2004/07/MediaBrowser.Controller.Entities.Movies'is not expected. Add any types not known statically to the list of known types - for exampl
DBUG (17:33:59.218) TDK_Emby\TDK_Emby.ini - [WP_Emby]: Index  1: Type 'MediaBrowser.Controller.Entities.Movies.Movie' with data contract name 'Movie:http://schemas.datacontract.org/2004/07/MediaBrowser.Controller.Entities.Movies'is not expected. Add any types not known statically to the list of known types - for exampl
Hope this helps, please contact me if you want more logs thanks
Bro Code for Life
Oh and also this shows up in hte log:
ERRO (17:33:59.219) TDK_Emby\TDK_Emby.ini - [ParseSessions00]: RegExp matching error (-1)
Hi,
sorry, the Skin will not working anymore.
This version of the Skin use the xml format of the sessions.
But the xml format is not supported from Emby since version xxx (i can't remember)
Unfortunately, I'm very busy at work right now, so the new skin will take some time.
(A very early alpha version is already running for one user :-)
Unfortunately that will take some time, sorry
cu Taurec
Hey no worries, a one user version is also not so useless, so i’m open for a tester position if possible :-) And who knows maybe if I have my head around it can also tweak it to do more. So if you are open for cooperation I’m all in for this! Peace
Sent from my iPhone using Tapatalk
Hello all,
i have update the first post for new information.
cu Taurec
  • Like 1
