e123enitan 276 Posted June 8, 2016 Posted June 8, 2016 (edited) I'm heading south of the border, could anyone draw a dummy steps or guide on how to connecting Kodi/emby server remotely, what are the configurations that are needed on the router side, and kodi assuming server IP is set as static. screen shots will also help, users like me who are not tech inclined. Just to mention I can easily access emby server through emby Android app, becos its preconfigured with emby connect to remote access, hope we can have this feature in future in emby/kodi or if its possible access server through Kodi as preconfigured, hope this is not over burdensome to ask for. Thanks Edited June 8, 2016 by e123enitan
Solution Angelblue05 4132 Posted June 8, 2016 Solution Posted June 8, 2016 (edited) All you need to do, is activate the alternate address in the addon settings. Enter your remote server address and port. Restart Kodi, see if it connects. Let me know. I really don't have time to work on features for the addon. So the implementation is pretty basic. Sent from my iPhone using Tapatalk Edited June 8, 2016 by Angelblue05
e123enitan 276 Posted June 8, 2016 Author Posted June 8, 2016 All you need to do, is activate the alternate address in the addon settings. Enter your remote server address and port. Restart Kodi, see if it connects. Let me know. I really don't have time to work on features for the addon. So the implementation is pretty basic. Sent from my iPhone using Tapatalk OK I will give it a Go and get back to you, Thanks 1
Angelblue05 4132 Posted June 8, 2016 Posted June 8, 2016 I forgot, don't forget to enable play from http in the addon settings > playback Sent from my iPhone using Tapatalk
e123enitan 276 Posted June 9, 2016 Author Posted June 9, 2016 OK I will give it a Go and get back to you, Thanks As you said, it was a simple set up, it works fine, however, my concern is, if I share my server with friends and my ISP IP address is open to risk, what is the alternative to prevent my IP address being exposed, any suggestions? Thanks
Angelblue05 4132 Posted June 9, 2016 Posted June 9, 2016 Or use a ddns service like no-ip.org Sent from my iPhone using Tapatalk
e123enitan 276 Posted June 10, 2016 Author Posted June 10, 2016 (edited) Thanks both for your inputs, I will have have a free ddns setup and configure through my router. Edited June 13, 2016 by e123enitan
