RedBaron164 18 Posted June 7, 2016 Posted June 7, 2016 I have Cinema mode enabled for my primary theater machine. I have disabled it for when I log into the web interface. However I'm not seeing an option to disable it from the Roku app. Am I missing the option or Is that option coming later? If not is there a way for me to work around it for the time being?
Luke 42242 Posted June 7, 2016 Posted June 7, 2016 we just haven't added the option yet, which means for now you'd have to disable it globally for all apps on the server.
RedBaron164 18 Posted June 7, 2016 Author Posted June 7, 2016 Ok, that's what I figured, I was thinking that if I could disable per user I could just create a dedicated Roku user account.
speechles 2062 Posted June 7, 2016 Posted June 7, 2016 (edited) You can use "Play from scene" and choose "0:00" then it will only play the feature film. You can use this as a work-around for the time being. That is a good idea though. An option "disable cinema mode" in preferences. I will add it to the next release of the blue neon roku app. Sent from my Nexus 7 using Tapatalk Edited June 7, 2016 by speechles
