CBers 7554 Posted August 8, 2016 Posted August 8, 2016 @@cmcg @@SamES Just found this in the server log, following a other non-load. 2016-08-08 19:44:23.1645 Error ServiceStackHost: ServiceBase<TRequest>::Service Exception *** Error Report *** Version: 3.1.6063.27456 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe User not found MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Api.UserService.Get(GetOfflineUser request) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) 2016-08-08 19:44:23.1645 Error HttpServer: Error processing request for /emby/Users/fe8e98c1df54d9b502474bab46ee8982/Offline?format=json *** Error Report *** Version: 3.1.6063.27456 Command line: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server Application Path: C:\Users\Media\AppData\Roaming\MediaBrowser-Server\System\MediaBrowser.ServerApplication.exe User not found ServiceStack.HttpError No Stack Trace Available InnerException: MediaBrowser.Common.Extensions.ResourceNotFoundException User not found at MediaBrowser.Api.UserService.Get(GetOfflineUser request) at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto) Any use?
CBers 7554 Posted August 9, 2016 Posted August 9, 2016 Still having issues accessing the app. Just had to uninstall and reinstall again. I've left default settings, apart from DD playback and screensaver. No auto-login either. No errors this time in server log, but there were slow messages.
FrostByte 5453 Posted August 9, 2016 Posted August 9, 2016 I've had an issue with my HTS for a long time where I can't use auto-login at all. If I set it to auto logon then the HS never comes up. I would have to delete the app and reinstall just to get back in. I probably made a bug report awhile back, but just ignore the issue now since my TV doesn't have the issue and no one else reported anything similar. 1
CBers 7554 Posted August 13, 2016 Posted August 13, 2016 I've had an issue with my HTS for a long time where I can't use auto-login at all. If I set it to auto logon then the HS never comes up. I would have to delete the app and reinstall just to get back in. I probably made a bug report awhile back, but just ignore the issue now since my TV doesn't have the issue and no one else reported anything similar. I tried the app several times over the last few days and no problems at all with AUTO-LOGIN disabled. @@cmcg - can you review the AUTO-LOGIN module please, as this seems to break things. It's always been fine for me, apart from this last version. See @@FrostByte's post above. Thanks.
cmcg 876 Posted August 14, 2016 Author Posted August 14, 2016 Give this a go @@CBers and let me know if it's better. I'm struggling with inconsistences between emulator and TV with HTTP requests. This build work for me, although I'm not sure I replicated you exact situation. 2.2.0gFixed: Freeze on splashscreen at startup.Fixed: Primary series image not used on Homescreen with Server version 6000 and later.Fixed: Log entries flowing off screen.Fixed: Logout was broken in the previous beta.Fixed: Items not selected on Users page. 4
FrostByte 5453 Posted August 15, 2016 Posted August 15, 2016 Not sure about CBers, but my HTS can auto logon now without freezing Thanks @cmcg 3
CBers 7554 Posted August 15, 2016 Posted August 15, 2016 OK, finally managed to find time to update and so far, so good. 2
above1 45 Posted August 16, 2016 Posted August 16, 2016 I'm running 2.2.0g. Anyone experiencing issues with LATEST. Both TV and MOVIES I just get the background. It does not come up with my latest tv series or my latest movies. Logs on the TV report nothing. It does work on my Nexus and my Roku 3. Any assistance would be greatly appreciated. Oh.. I've also refreshed my movie and tv listing within emby. That fixed an issue they had previously. Server version 3.1.105 Thanks!
FrostByte 5453 Posted August 16, 2016 Posted August 16, 2016 v2.2.0g On the About screen there looks like at least one line of names is cut off I can't seem to duplicate the missing Latest posters, even after a refresh 1
CBers 7554 Posted August 16, 2016 Posted August 16, 2016 OK, finally managed to find time to update and so far, so good. Spoke too soon. First use today and I don't get the home screen, just the Exit and time displayed. This is from the server log: 2016-08-16 19:38:22.1734 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/System/Info/Public?format=json. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.1964 Debug NetworkManager: Querying interface: Local Area Connection 2. Type: Ethernet. Status: Up 2016-08-16 19:38:22.1964 Debug NetworkManager: Querying interface: Loopback Pseudo-Interface 1. Type: Loopback. Status: Up 2016-08-16 19:38:22.1964 Debug NetworkManager: Querying interface: isatap.{85A9EEDD-B7CC-4CFA-8D97-416690946C86}. Type: Tunnel. Status: Down 2016-08-16 19:38:22.1964 Debug NetworkManager: Querying interface: Local Area Connection* 11. Type: Tunnel. Status: Down 2016-08-16 19:38:22.2224 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 49ms. http://192.168.1.140:8096/emby/System/Info/Public?format=json 2016-08-16 19:38:22.2224 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/System/Info/Public?format=json. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.2564 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 26ms. http://192.168.1.140:8096/emby/System/Info/Public?format=json 2016-08-16 19:38:22.2744 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/Public?format=json. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.2744 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 2ms. http://192.168.1.140:8096/emby/Users/Public?format=json 2016-08-16 19:38:22.3074 Info HttpServer: HTTP POST http://192.168.1.140:8096/emby/Users/AuthenticateByName?format=json. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.5644 Info UserManager: Authentication request for Master has succeeded. 2016-08-16 19:38:22.5844 Info SessionManager: Reissuing access token: ea6740f818754498825eb567eba79e47 2016-08-16 19:38:22.6004 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 293ms. http://192.168.1.140:8096/emby/Users/AuthenticateByName?format=json Can post full log if needed.
CBers 7554 Posted August 16, 2016 Posted August 16, 2016 Large "(slow)" messages in the log: 192.168.1.140:8096/emby/Users/AuthenticateByName?format=json 2016-08-16 19:38:22.6384 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Views?format=json&SortBy=SortName&SortOrder=Ascending. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.6384 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 11ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Views?format=json&SortBy=SortName&SortOrder=Ascending 2016-08-16 19:38:22.6554 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&Limit=0. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.6554 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 10ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&Limit=0 2016-08-16 19:38:22.6704 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&fields=SortName&recursive=true. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:41:39.3257 Info TaskManager: IntervalTrigger fired for task: Check for plugin updates 2016-08-16 19:41:39.3257 Info TaskManager: Queueing task PluginUpdateTask 2016-08-16 19:41:39.3257 Info TaskManager: Executing Check for plugin updates 2016-08-16 19:41:39.3257 Info InstallationManager: Opening C:\Users\Media\AppData\Roaming\MediaBrowser-Server\cache\serverpackages.json 2016-08-16 19:41:39.3547 Info HttpClient: HttpClientManager.GetTempFileResponse url: https://www.mb3admin.com/admin/service/MB3Packages.json 2016-08-16 19:41:39.3547 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2016-08-16 19:41:39.3997 Info ServerManager: Sending web socket message ScheduledTaskEnded 2016-08-16 19:41:39.3997 Info TaskManager: ExecuteQueuedTasks 2016-08-16 19:41:39.6987 Info TaskManager: IntervalTrigger fired for task: Organize new media files 2016-08-16 19:41:39.6987 Info TaskManager: Queueing task OrganizerScheduledTask 2016-08-16 19:41:39.6987 Info TaskManager: Executing Organize new media files 2016-08-16 19:41:39.7157 Info TaskManager: Organize new media files Completed after 0 minute(s) and 0 seconds 2016-08-16 19:41:39.7157 Info ServerManager: Sending web socket message ScheduledTaskEnded 2016-08-16 19:41:39.7157 Info TaskManager: ExecuteQueuedTasks 2016-08-16 19:41:54.1705 Debug SqliteItemRepository: GetItemList query time (slow): 211489ms. Query: select type,data,StartDate,EndDate,IsOffline,ChannelId,IsMovie,IsSports,IsKids,IsSeries,IsLive,IsNews,IsPremiere,EpisodeTitle,IsRepeat,CommunityRating,CustomRating,IndexNumber,IsLocked,PreferredMetadataLanguage,PreferredMetadataCountryCode,IsHD,ExternalEtag,DateLastRefreshed,Name,Path,PremiereDate,Overview,ParentIndexNumber,ProductionYear,OfficialRating,OfficialRatingDescription,HomePageUrl,DisplayMediaType,ForcedSortName,RunTimeTicks,VoteCount,DateCreated,DateModified,guid,Genres,ParentId,Audio,ExternalServiceId,IsInMixedFolder,DateLastSaved,LockedFields,Studios,Tags,SourceType,TrailerTypes,OriginalTitle,PrimaryVersionId,DateLastMediaAdded,Album,CriticRating,CriticRatingSummary,IsVirtualItem,SeriesName,SeasonName,SeasonId,SeriesId,SeriesSortName,PresentationUniqueKey,UserDataDb.UserData.UserId,UserDataDb.UserData.lastPlayedDate,UserDataDb.UserData.playbackPositionTicks,UserDataDb.UserData.playcount,UserDataDb.UserData.isFavorite,UserDataDb.UserData.played,UserDataDb.UserData.rating from TypedBaseItems A left join UserDataDb.UserData on UserDataKey=UserDataDb.UserData.Key And (UserId=@UserId) where IsFavorite=@IsFavorite AND (TopParentId in ('c891775f27f2699625c1478e5d1ed5a0','932ec0f91338f7744989e01d529103d1','0d7184d3fe01c3c3d9a49420ac872c4f','58b12d7806076d3d792965d6cf2f7b7e','af998fd77d226c0983ed6b347d65035e','384fe71bd5db8c0c97c6b356a93be6d8','1efabbcdf6d961bcf2288cd66955a39c','864d2f621a8fb67cf025af5b0a4fbef4','b5bfb6ae35078377cfcec4e6d6c15a69','aad8f038e15d789a9b6cf4af6b2254f0')) Group by PresentationUniqueKey ORDER BY SortName ASC 2016-08-16 19:41:54.1705 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 211501ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&fields=SortName&recursive=true 192.168.1.199 is my Samsung TV.
Luke 42239 Posted August 16, 2016 Posted August 16, 2016 Large "(slow)" messages in the log: 192.168.1.140:8096/emby/Users/AuthenticateByName?format=json 2016-08-16 19:38:22.6384 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Views?format=json&SortBy=SortName&SortOrder=Ascending. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.6384 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 11ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Views?format=json&SortBy=SortName&SortOrder=Ascending 2016-08-16 19:38:22.6554 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&Limit=0. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:38:22.6554 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 10ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&Limit=0 2016-08-16 19:38:22.6704 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&fields=SortName&recursive=true. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-08-16 19:41:39.3257 Info TaskManager: IntervalTrigger fired for task: Check for plugin updates 2016-08-16 19:41:39.3257 Info TaskManager: Queueing task PluginUpdateTask 2016-08-16 19:41:39.3257 Info TaskManager: Executing Check for plugin updates 2016-08-16 19:41:39.3257 Info InstallationManager: Opening C:\Users\Media\AppData\Roaming\MediaBrowser-Server\cache\serverpackages.json 2016-08-16 19:41:39.3547 Info HttpClient: HttpClientManager.GetTempFileResponse url: https://www.mb3admin.com/admin/service/MB3Packages.json 2016-08-16 19:41:39.3547 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2016-08-16 19:41:39.3997 Info ServerManager: Sending web socket message ScheduledTaskEnded 2016-08-16 19:41:39.3997 Info TaskManager: ExecuteQueuedTasks 2016-08-16 19:41:39.6987 Info TaskManager: IntervalTrigger fired for task: Organize new media files 2016-08-16 19:41:39.6987 Info TaskManager: Queueing task OrganizerScheduledTask 2016-08-16 19:41:39.6987 Info TaskManager: Executing Organize new media files 2016-08-16 19:41:39.7157 Info TaskManager: Organize new media files Completed after 0 minute(s) and 0 seconds 2016-08-16 19:41:39.7157 Info ServerManager: Sending web socket message ScheduledTaskEnded 2016-08-16 19:41:39.7157 Info TaskManager: ExecuteQueuedTasks 2016-08-16 19:41:54.1705 Debug SqliteItemRepository: GetItemList query time (slow): 211489ms. Query: select type,data,StartDate,EndDate,IsOffline,ChannelId,IsMovie,IsSports,IsKids,IsSeries,IsLive,IsNews,IsPremiere,EpisodeTitle,IsRepeat,CommunityRating,CustomRating,IndexNumber,IsLocked,PreferredMetadataLanguage,PreferredMetadataCountryCode,IsHD,ExternalEtag,DateLastRefreshed,Name,Path,PremiereDate,Overview,ParentIndexNumber,ProductionYear,OfficialRating,OfficialRatingDescription,HomePageUrl,DisplayMediaType,ForcedSortName,RunTimeTicks,VoteCount,DateCreated,DateModified,guid,Genres,ParentId,Audio,ExternalServiceId,IsInMixedFolder,DateLastSaved,LockedFields,Studios,Tags,SourceType,TrailerTypes,OriginalTitle,PrimaryVersionId,DateLastMediaAdded,Album,CriticRating,CriticRatingSummary,IsVirtualItem,SeriesName,SeasonName,SeasonId,SeriesId,SeriesSortName,PresentationUniqueKey,UserDataDb.UserData.UserId,UserDataDb.UserData.lastPlayedDate,UserDataDb.UserData.playbackPositionTicks,UserDataDb.UserData.playcount,UserDataDb.UserData.isFavorite,UserDataDb.UserData.played,UserDataDb.UserData.rating from TypedBaseItems A left join UserDataDb.UserData on UserDataKey=UserDataDb.UserData.Key And (UserId=@UserId) where IsFavorite=@IsFavorite AND (TopParentId in ('c891775f27f2699625c1478e5d1ed5a0','932ec0f91338f7744989e01d529103d1','0d7184d3fe01c3c3d9a49420ac872c4f','58b12d7806076d3d792965d6cf2f7b7e','af998fd77d226c0983ed6b347d65035e','384fe71bd5db8c0c97c6b356a93be6d8','1efabbcdf6d961bcf2288cd66955a39c','864d2f621a8fb67cf025af5b0a4fbef4','b5bfb6ae35078377cfcec4e6d6c15a69','aad8f038e15d789a9b6cf4af6b2254f0')) Group by PresentationUniqueKey ORDER BY SortName ASC 2016-08-16 19:41:54.1705 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 211501ms. http://192.168.1.140:8096/emby/Users/9eac53d92edd448196cd69a41d3cb18f/Items?format=json&SortBy=SortName&SortOrder=Ascending&Filters=IsFavorite&fields=SortName&recursive=true 192.168.1.199 is my Samsung TV. How does the app display favorites?
CBers 7554 Posted August 16, 2016 Posted August 16, 2016 How does the app display favorites? I don't have any favourites.
FrostByte 5453 Posted August 16, 2016 Posted August 16, 2016 (edited) There is a menu item where all media types for favorites are displayed together if you have any I think the menu is in this one https://github.com/MediaBrowser/SamsungSmartTV/blob/master/app/javascript/Support.js Edited August 16, 2016 by FrostByte
edwin7979 0 Posted August 17, 2016 Posted August 17, 2016 Could you please provide the download link for the current zip install files for 2.2.0g? Having trouble downloading from ip address under develop account. I would like to see if I can download it directly. Thanks
FrostByte 5453 Posted August 17, 2016 Posted August 17, 2016 https://github.com/MediaBrowser/SamsungSmartTV/tree/2.2_dev
sh0rty 727 Posted August 17, 2016 Posted August 17, 2016 Could you please provide the download link for the current zip install files for 2.2.0g? Having trouble downloading from ip address under develop account. I would like to see if I can download it directly. Thanks http://82.27.106.58/Emby_2.2.0g_Europe_20160814.zip Gesendet von meinem HTC One M8 mit Tapatalk 1
CBers 7554 Posted August 17, 2016 Posted August 17, 2016 Spoke too soon. First use today and I don't get the home screen, just the Exit and time displayed. I noticed that when I don't get a HomeScreen displayed, the version number isn't on the splash-screen either. Not sure if something has gone awry by then, but thought I'd mention it. I'm also seeing the issue with the About page that @@FrostByte reported. Anyway, I've uninstalled and reinstalled the app and it is working again, minus the auto-login.
cmcg 876 Posted August 17, 2016 Author Posted August 17, 2016 Thanks. I had noticed the text on the About page. It's due to the new font. Not seeing the version number when the splashscreen is frozen interesting information since it happens incredibly near the start of the very first function (Main.onload). https://github.com/MediaBrowser/SamsungSmartTV/blob/2.2_dev/app/javascript/Main.js#L98 In fact, the only thing that happens before that is Chess' image caching. Are you able to make a small text change to the code, rezip it and install? If so, go to line 31 of Main.js and set enableImageCache to false. https://github.com/MediaBrowser/SamsungSmartTV/blob/2.2_dev/app/javascript/Main.js#L31
CBers 7554 Posted August 17, 2016 Posted August 17, 2016 @@cmcg - the splash-screen doesn't freeze, but I get like a ribbon image on the screen. Is that a Samsung image? I'm not able to amend the code, sorry.
cmcg 876 Posted August 17, 2016 Author Posted August 17, 2016 Do you have multiple servers configured?
CBers 7554 Posted August 17, 2016 Posted August 17, 2016 Do you have multiple servers configured? I have 2 Emby servers running, but only ever connect to the same one - only 1 server entered into the app on (re)install.
above1 45 Posted August 18, 2016 Posted August 18, 2016 (edited) So is anyone else having issues with the "Latest" posters not showing up for movies and tv shows? Emby server 3.1.10X and 2.2.0g client? I've have the issue ever since I upgraded the server to 3.1. Thanks. Edited August 18, 2016 by above1
