Blueeyiz702 223 Posted July 7, 2016 Posted July 7, 2016 @ - are you in front of your TV ?? If so, can you change HV2 to something other than NONE and see if it responds better ?? I can do it later when I'm home if not. Thanks. yes ill give it try and see what happens. Ill report back shortly. 1
Blueeyiz702 223 Posted July 7, 2016 Posted July 7, 2016 @@CBers,i changed hv2 to media folders and hv1 to lastest movies,and it got alot more responsive. 2
CBers 7554 Posted July 7, 2016 Posted July 7, 2016 That would tend to confirm what @@cmcg was saying earlier. I'll change mine tonight and see what happens. Thanks. 1
Blueeyiz702 223 Posted July 7, 2016 Posted July 7, 2016 That would tend to confirm what @@cmcg was saying earlier. I'll change mine tonight and see what happens. Thanks. Let me kno what happens,and thanks.
CBers 7554 Posted July 7, 2016 Posted July 7, 2016 Let me kno what happens,and thanks. I uninstalled and reinstalled the app and using all of the HVs set to something, seems to make the app work better.
cmcg 876 Posted July 7, 2016 Author Posted July 7, 2016 And if you set HV2 back to none, does it get worse again?
Blueeyiz702 223 Posted July 8, 2016 Posted July 8, 2016 (edited) And if you set HV2 back to none, does it get worse again? @@cmcg take a look at video in link. it shows exactly what happens when i load up emby. https://drive.google.com/file/d/0B7aQ-XX04M1bRTV2WUVfTk5wX0U/view?usp=sharing Edited July 8, 2016 by blueeyiz7021 1
Blueeyiz702 223 Posted July 8, 2016 Posted July 8, 2016 (edited) how strange,right after i posted video. i tried to load up emby and it work the a charm? What the hay. changed hv1 to media folders and hv2 to none and everything is working fine like never had a problem. Did expierience laggyness when i tried to load up a episode to watch. But it eventually started playing fine?? i'm lost.minute it won't work right,the next minute it works like perfect. Edited July 8, 2016 by blueeyiz7021 1
yudicuba 1 Posted July 8, 2016 Posted July 8, 2016 If the 7.1 audio is DTS-HD then you should be okay. My TV doesn't support 7.1 audio either, but the DTS decoder in my TV is smart enough to use the core DTS track which is only 5.1 channels and plays it without transcoding. However, with TrueHD the app will transcode automatically or you could use a program like MKVToolNix to pull out the 5.1 core ACS track and then remux both audio tracks in if you want to keep both and avoid any transcoding Edit: The app is designed to deal with most files though, if your hardware isn't capable of direct streaming a file because of something like the number of channels, or codec, etc then it should transcode the file and play fine...hopefully hi, everything its working fine only the new dolby atmos has been transcoded thanks 1
CBers 7554 Posted July 8, 2016 Posted July 8, 2016 @@cmcg take a look at video in link. it shows exactly what happens when i load up emby. https://drive.google.com/file/d/0B7aQ-XX04M1bRTV2WUVfTk5wX0U/view?usp=sharing That took a long time to get to the splash-screen. I started the app on my TV when I started your video and the home screen loaded well before the video ended.
CBers 7554 Posted July 8, 2016 Posted July 8, 2016 And if you set HV2 back to none, does it get worse again? From starting the app to having the home screen loaded is about 10s with HV2 set to something other than None. With it set to None, it was still the same. I'll need to play more, but at least I have a fix. Uninstall and reinstall. 1
Blueeyiz702 223 Posted July 9, 2016 Posted July 9, 2016 From starting the app to having the home screen loaded is about 10s with HV2 set to something other than None. With it set to None, it was still the same. I'll need to play more, but at least I have a fix. Uninstall and reinstall. CBers,i tried the fix. And guess what? Still doing same thing
SamES 1084 Posted July 9, 2016 Posted July 9, 2016 So I've tried HEVC on E-Series and I get a render error. If I try through DLNA it fails with a video codec error. Therefore, I expect we need to disable HEVC for E-series to force transcoding. This was the title in question. Thanks.
CBers 7554 Posted July 9, 2016 Posted July 9, 2016 CBers,i tried the fix. And guess what? Still doing same thing Did you leave HV2 set to something other than None?
SamES 1084 Posted July 9, 2016 Posted July 9, 2016 From starting the app to having the home screen loaded is about 10s with HV2 set to something other than None. With it set to None, it was still the same. I'll need to play more, but at least I have a fix. Uninstall and reinstall. @@cmcg, it might be worth dumping the HV queries to the log so that we can confirm if their sane when it hangs on the splash screen. 3
CBers 7554 Posted July 9, 2016 Posted July 9, 2016 Not sure if its just me, but starting a video from a resume point takes forever for playback to start, On my Shield TV, it's instant. Log entries around the time of resume: 2016-07-09 15:53:09.9105 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 521ms. http://192.168.1.140:8096/emby/Items/4f8b0fefb9fe4de261bb83b3dd55cb5f/Images/Backdrop/2?maxwidth=1920&maxheight=1080&Quality=90 2016-07-09 15:54:07.1488 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items?format=json&SortBy=Random&MediaTypes=Photo&Recursive=true&CollapseBoxSetItems=false&Limit=500. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:54:10.8570 Debug SqliteItemRepository: GetItems query time (slow): 3620ms. Query: select type,data,StartDate,EndDate,IsOffline,ChannelId,IsMovie,IsSports,IsKids,IsSeries,IsLive,IsNews,IsPremiere,EpisodeTitle,IsRepeat,CommunityRating,CustomRating,IndexNumber,IsLocked,PreferredMetadataLanguage,PreferredMetadataCountryCode,IsHD,ExternalEtag,DateLastRefreshed,Name,Path,PremiereDate,Overview,ParentIndexNumber,ProductionYear,OfficialRating,OfficialRatingDescription,HomePageUrl,DisplayMediaType,ForcedSortName,RunTimeTicks,VoteCount,DateCreated,DateModified,guid,Genres,ParentId,Audio,ExternalServiceId,IsInMixedFolder,DateLastSaved,LockedFields,Studios,Tags,SourceType,TrailerTypes,DateModifiedDuringLastRefresh,OriginalTitle,PrimaryVersionId,DateLastMediaAdded,Album,CriticRating,CriticRatingSummary,IsVirtualItem,SeriesName,SeasonName,SeasonId,SeriesId from TypedBaseItems A where MediaType=@MediaTypes AND (TopParentId in ('c891775f27f2699625c1478e5d1ed5a0','aad8f038e15d789a9b6cf4af6b2254f0','932ec0f91338f7744989e01d529103d1','0a8a4621210a0bfc60d739ce579abc65','07416228c945b3e4e552610f712a96ff','58b12d7806076d3d792965d6cf2f7b7e','0d7184d3fe01c3c3d9a49420ac872c4f','e96c3ce9ca067ec319bce77ccf35ff81','af998fd77d226c0983ed6b347d65035e','aad8f038e15d789a9b6cf4af6b2254f0','384fe71bd5db8c0c97c6b356a93be6d8','864d2f621a8fb67cf025af5b0a4fbef4','65ea79b7088bfc7fdbd9fa6e2b002ec8','1efabbcdf6d961bcf2288cd66955a39c')) Group by PresentationUniqueKey ORDER BY RANDOM() ASC LIMIT 500; select count (distinct PresentationUniqueKey) from TypedBaseItems A where MediaType=@MediaTypes AND (TopParentId in ('c891775f27f2699625c1478e5d1ed5a0','aad8f038e15d789a9b6cf4af6b2254f0','932ec0f91338f7744989e01d529103d1','0a8a4621210a0bfc60d739ce579abc65','07416228c945b3e4e552610f712a96ff','58b12d7806076d3d792965d6cf2f7b7e','0d7184d3fe01c3c3d9a49420ac872c4f','e96c3ce9ca067ec319bce77ccf35ff81','af998fd77d226c0983ed6b347d65035e','aad8f038e15d789a9b6cf4af6b2254f0','384fe71bd5db8c0c97c6b356a93be6d8','864d2f621a8fb67cf025af5b0a4fbef4','65ea79b7088bfc7fdbd9fa6e2b002ec8','1efabbcdf6d961bcf2288cd66955a39c')) 2016-07-09 15:54:11.4340 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 4285ms (slow). http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items?format=json&SortBy=Random&MediaTypes=Photo&Recursive=true&CollapseBoxSetItems=false&Limit=500 2016-07-09 15:54:11.8041 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/dbca856d1a4250d0a96075795d641d9a/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:54:14.7552 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 2951ms (slow). http://192.168.1.140:8096/emby/Items/dbca856d1a4250d0a96075795d641d9a/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:54:20.1585 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/95f3cc9813232a65897462cce14d144d/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:54:21.1606 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1002ms (slow). http://192.168.1.140:8096/emby/Items/95f3cc9813232a65897462cce14d144d/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:54:29.5221 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/8f535c8ce825c578d3838dbe14ce55a2/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:54:30.7822 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1260ms (slow). http://192.168.1.140:8096/emby/Items/8f535c8ce825c578d3838dbe14ce55a2/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:54:38.6876 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/087c4766069691405a65b6bb2b2392b9/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:54:39.5127 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 825ms. http://192.168.1.140:8096/emby/Items/087c4766069691405a65b6bb2b2392b9/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:54:44.5059 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: d1003d47308743b9aa8283cdf77afe5d 2016-07-09 15:54:47.4361 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/a05372cb0f138b86a1d4c46664ef6b60/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:54:48.7852 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1349ms (slow). http://192.168.1.140:8096/emby/Items/a05372cb0f138b86a1d4c46664ef6b60/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:54:56.5336 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/32a434a4b83185dc72dc9715c0ae5368/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:54:57.9127 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1379ms (slow). http://192.168.1.140:8096/emby/Items/32a434a4b83185dc72dc9715c0ae5368/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:55:05.8452 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/2951f79e3e06694cdfacb278b96e6732/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:55:07.0752 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1230ms (slow). http://192.168.1.140:8096/emby/Items/2951f79e3e06694cdfacb278b96e6732/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:55:14.9687 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/cd1f0ea7dfe45c5ec00e9aa2e126740e/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:55:15.8227 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 854ms. http://192.168.1.140:8096/emby/Items/cd1f0ea7dfe45c5ec00e9aa2e126740e/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:55:23.6962 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b95a19c0b205605ccaf68dab439c3c90/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:55:24.7932 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1096ms (slow). http://192.168.1.140:8096/emby/Items/b95a19c0b205605ccaf68dab439c3c90/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:55:32.6857 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/9e812b83cf8e9e742f57ec7d547627f0/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:55:33.7508 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1065ms (slow). http://192.168.1.140:8096/emby/Items/9e812b83cf8e9e742f57ec7d547627f0/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:55:36.9079 Info HttpClient: HttpClientManager GET: http://bot.whatismyipaddress.com 2016-07-09 15:55:37.6270 Info HttpClient: HttpClientManager POST: https://connect.emby.media/service/Servers?id=57ce5d1b0fdca8bc18cee9f1a492a210 2016-07-09 15:55:37.9330 Info HttpClient: HttpClientManager GET: https://connect.emby.media/service/ServerAuthorizations?serverId=57ce5d1b0fdca8bc18cee9f1a492a210 2016-07-09 15:55:41.6972 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/1a99a231b5a884aeef918a92193bfc82/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:55:42.6843 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 988ms. http://192.168.1.140:8096/emby/Items/1a99a231b5a884aeef918a92193bfc82/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:55:50.5727 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/1c6a0e0f27e1431d38d365ec67680812/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:55:52.1358 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1563ms (slow). http://192.168.1.140:8096/emby/Items/1c6a0e0f27e1431d38d365ec67680812/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:56:00.0233 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/516f438b92e845d9b23ae3325a2c9859/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:56:02.4274 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 2404ms (slow). http://192.168.1.140:8096/emby/Items/516f438b92e845d9b23ae3325a2c9859/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:56:10.3068 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/102496c2c2c649371f731da2380ec1b8/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:56:11.4279 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1121ms (slow). http://192.168.1.140:8096/emby/Items/102496c2c2c649371f731da2380ec1b8/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:56:19.3064 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/063d560af628a963a9f1f2b0b5e5cf1f/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:56:20.3134 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1007ms (slow). http://192.168.1.140:8096/emby/Items/063d560af628a963a9f1f2b0b5e5cf1f/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:56:28.2319 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/3f3f2f04b4fd0ff9d3958e7bf548b5ae/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:56:29.5910 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1359ms (slow). http://192.168.1.140:8096/emby/Items/3f3f2f04b4fd0ff9d3958e7bf548b5ae/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:56:37.5204 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/fa356bcd92a5433d2579a1683cfd7f8f/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:56:38.9495 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1429ms (slow). http://192.168.1.140:8096/emby/Items/fa356bcd92a5433d2579a1683cfd7f8f/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:56:46.8619 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/a2286f9970a83aa54b311a7abfb07149/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:56:47.9190 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1057ms (slow). http://192.168.1.140:8096/emby/Items/a2286f9970a83aa54b311a7abfb07149/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:56:55.8575 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/0b98390926cecdeedf234bbc40823335/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:56:56.8665 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 1009ms (slow). http://192.168.1.140:8096/emby/Items/0b98390926cecdeedf234bbc40823335/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:57:05.0310 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/9bfd70bd3ba7043ef3f00458667024a9/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:57:05.9920 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 961ms. http://192.168.1.140:8096/emby/Items/9bfd70bd3ba7043ef3f00458667024a9/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:57:13.8015 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/c757c1887b5aa2af23d3fa4a293180ae/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:57:14.6555 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 854ms. http://192.168.1.140:8096/emby/Items/c757c1887b5aa2af23d3fa4a293180ae/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:57:22.5110 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/0a81839c902b22b31beb95573699015a/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:57:23.1360 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 625ms. http://192.168.1.140:8096/emby/Items/0a81839c902b22b31beb95573699015a/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:57:31.0145 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/1c017bf05c1d757b12bb65b2d75604d8/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:57:31.8225 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 808ms. http://192.168.1.140:8096/emby/Items/1c017bf05c1d757b12bb65b2d75604d8/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:57:39.7350 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/3ad08b080796d9cecbe2382476eb9aaf/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080. UserAgent: Lavf52.104.0 2016-07-09 15:57:40.4760 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 741ms. http://192.168.1.140:8096/emby/Items/3ad08b080796d9cecbe2382476eb9aaf/Images/Primary/0?quality=90&maxwidth=1920&maxheight=1080 2016-07-09 15:57:45.4733 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items/b67705812db86839972e4bae7ce994ad?format=json. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:45.6863 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 213ms. http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items/b67705812db86839972e4bae7ce994ad?format=json 2016-07-09 15:57:45.7153 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Movies/b67705812db86839972e4bae7ce994ad/Similar?format=json&IncludeTrailers=false&Limit=5&UserId=fe8e98c1df54d9b502474bab46ee8982. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:49.3725 Debug SqliteItemRepository: GetItemList query time (slow): 3613ms. Query: select type,data,StartDate,EndDate,IsOffline,ChannelId,IsMovie,IsSports,IsKids,IsSeries,IsLive,IsNews,IsPremiere,EpisodeTitle,IsRepeat,CommunityRating,CustomRating,IndexNumber,IsLocked,PreferredMetadataLanguage,PreferredMetadataCountryCode,IsHD,ExternalEtag,DateLastRefreshed,Name,Path,PremiereDate,Overview,ParentIndexNumber,ProductionYear,OfficialRating,OfficialRatingDescription,HomePageUrl,DisplayMediaType,ForcedSortName,RunTimeTicks,VoteCount,DateCreated,DateModified,guid,Genres,ParentId,Audio,ExternalServiceId,IsInMixedFolder,DateLastSaved,LockedFields,Studios,Tags,SourceType,TrailerTypes,DateModifiedDuringLastRefresh,OriginalTitle,PrimaryVersionId,DateLastMediaAdded,Album,CriticRating,CriticRatingSummary,IsVirtualItem,SeriesName,SeasonName,SeasonId,SeriesId,UserDataDb.UserData.UserId,UserDataDb.UserData.lastPlayedDate,UserDataDb.UserData.playbackPositionTicks,UserDataDb.UserData.playcount,UserDataDb.UserData.isFavorite,UserDataDb.UserData.played,UserDataDb.UserData.rating,(((OfficialRating=@ItemOfficialRating) * 10)+(Select Case When Abs(COALESCE(ProductionYear, 0) - @ItemProductionYear) < 10 Then 2 Else 0 End )+(Select Case When Abs(COALESCE(ProductionYear, 0) - @ItemProductionYear) < 5 Then 2 Else 0 End )+ ((Select count(CleanValue) from ItemValues where ItemId=Guid and Type=2 and CleanValue in (select CleanValue from itemvalues where ItemId=@SimilarItemId and type=2)) * 10)+ ((Select count(CleanValue) from ItemValues where ItemId=Guid and Type=4 and CleanValue in (select CleanValue from itemvalues where ItemId=@SimilarItemId and type=4)) * 10)+ ((Select count(CleanValue) from ItemValues where ItemId=Guid and Type=5 and CleanValue in (select CleanValue from itemvalues where ItemId=@SimilarItemId and type=5)) * 10)+ ((Select count(CleanValue) from ItemValues where ItemId=Guid and Type=3 and CleanValue in (select CleanValue from itemvalues where ItemId=@SimilarItemId and type=3)) * 3)) as SimilarityScore from TypedBaseItems A left join UserDataDb.UserData on UserDataKey=UserDataDb.UserData.Key And (UserId=@UserId) where (IsMovie is null OR IsMovie=@IsMovie) AND type in ('MediaBrowser.Controller.Entities.Movies.Movie','MediaBrowser.Controller.Entities.Trailer','MediaBrowser.Controller.LiveTv.LiveTvProgram') AND Guid <> @ExcludeId0 AND (COALESCE((select value from ProviderIds where ItemId=Guid and Name = 'Tmdb'), '') <> @ExcludeProviderId0) AND (COALESCE((select value from ProviderIds where ItemId=Guid and Name = 'Imdb'), '') <> @ExcludeProviderId1) AND (TopParentId in ('c891775f27f2699625c1478e5d1ed5a0','aad8f038e15d789a9b6cf4af6b2254f0','932ec0f91338f7744989e01d529103d1','0a8a4621210a0bfc60d739ce579abc65','07416228c945b3e4e552610f712a96ff','58b12d7806076d3d792965d6cf2f7b7e','0d7184d3fe01c3c3d9a49420ac872c4f','e96c3ce9ca067ec319bce77ccf35ff81','af998fd77d226c0983ed6b347d65035e','aad8f038e15d789a9b6cf4af6b2254f0','384fe71bd5db8c0c97c6b356a93be6d8','864d2f621a8fb67cf025af5b0a4fbef4','65ea79b7088bfc7fdbd9fa6e2b002ec8','1efabbcdf6d961bcf2288cd66955a39c')) Group by PresentationUniqueKey ORDER BY SimilarityScore DESC,played ASC,RANDOM() DESC LIMIT 9 2016-07-09 15:57:49.3945 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 3679ms (slow). http://192.168.1.140:8096/emby/Movies/b67705812db86839972e4bae7ce994ad/Similar?format=json&IncludeTrailers=false&Limit=5&UserId=fe8e98c1df54d9b502474bab46ee8982 2016-07-09 15:57:49.6135 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=270&maxheight=400&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:49.6135 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Disc/0?maxwidth=250&maxheight=250&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:49.6135 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=1000&maxheight=200&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:49.6385 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/4f8b0fefb9fe4de261bb83b3dd55cb5f/Images/Backdrop/2?maxwidth=1920&maxheight=1080&Quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:49.6385 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=1000&maxheight=200&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:49.6385 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=270&maxheight=400&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:49.6555 Info HttpServer: HTTP Response 304 to 192.168.1.199. Time: 17ms. http://192.168.1.140:8096/emby/Items/4f8b0fefb9fe4de261bb83b3dd55cb5f/Images/Backdrop/2?maxwidth=1920&maxheight=1080&Quality=90 2016-07-09 15:57:49.7135 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 99ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=1000&maxheight=200&quality=90 2016-07-09 15:57:49.7135 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 77ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=1000&maxheight=200&quality=90 2016-07-09 15:57:49.7365 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 123ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Disc/0?maxwidth=250&maxheight=250&quality=90 2016-07-09 15:57:49.7805 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 167ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=270&maxheight=400&quality=90 2016-07-09 15:57:50.0356 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 391ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=270&maxheight=400&quality=90 2016-07-09 15:57:50.1796 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Backdrop/18?maxwidth=1920&maxheight=1080&Quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:50.8876 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 708ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Backdrop/18?maxwidth=1920&maxheight=1080&Quality=90 2016-07-09 15:57:50.9896 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Disc/0?maxwidth=250&maxheight=250&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:50.9946 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 5ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Disc/0?maxwidth=250&maxheight=250&quality=90 2016-07-09 15:57:53.3957 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/0?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.3957 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/1?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.3957 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/2?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.3957 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/3?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.4707 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/0?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.4727 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/1?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.4727 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/2?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.4958 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 25ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/0?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:53.4958 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 101ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/0?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:53.4958 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 102ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/1?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:53.4958 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 26ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/1?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:53.5038 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 107ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/3?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:53.5038 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/3?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:53.5038 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 115ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/2?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:53.5038 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 39ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/2?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:53.5038 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 3ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/3?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:56.9219 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/4?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:56.9219 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/4?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:56.9649 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 34ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/4?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:56.9649 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 43ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/4?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:57.9120 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/5?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:57.9120 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/5?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:57.9560 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 42ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/5?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:57.9560 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 44ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/5?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:59.2151 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/6?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:59.2151 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/6?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:57:59.2511 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 36ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/6?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:57:59.2511 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 34ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/6?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:58:00.1441 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/7?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:00.1441 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/7?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:00.2021 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 58ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/7?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:58:00.2021 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 56ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/7?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:58:01.8382 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/8?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:01.8382 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/8?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:01.8782 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 40ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/8?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:58:01.8782 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 38ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/8?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:58:03.3633 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/9?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:03.3633 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/9?maxwidth=210&maxheight=116&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:03.4193 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 56ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/9?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:58:03.4193 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 53ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Chapter/9?maxwidth=210&maxheight=116&quality=90 2016-07-09 15:58:04.9184 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items/b67705812db86839972e4bae7ce994ad?format=json&ExcludeLocationTypes=Virtual. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:05.0024 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 84ms. http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items/b67705812db86839972e4bae7ce994ad?format=json&ExcludeLocationTypes=Virtual 2016-07-09 15:58:05.0024 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items/b67705812db86839972e4bae7ce994ad/Intros. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:05.0394 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 27ms. http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982/Items/b67705812db86839972e4bae7ce994ad/Intros 2016-07-09 15:58:05.1564 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982?format=json. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:05.1564 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 9ms. http://192.168.1.140:8096/emby/Users/fe8e98c1df54d9b502474bab46ee8982?format=json 2016-07-09 15:58:06.1165 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=820&maxheight=110&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:06.1165 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 82d3ed3e2fe84866a51c44c839ba1644 2016-07-09 15:58:06.1165 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=200&maxheight=280&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:06.1165 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: d5dd1f9c2e274934a419cb0aaa0e680e 2016-07-09 15:58:06.1165 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: d6e763e7a32744769e06f31da68f5826 2016-07-09 15:58:06.1165 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: 2ad330df97a04014b958097edf72ea5b 2016-07-09 15:58:06.1165 Debug HttpServer: Exiting HttpConnection.OnReadInternal because nread=0. ConnectionId: d6ce130d772f4132a194cca74bd5ac77 2016-07-09 15:58:06.1235 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Videos/b67705812db86839972e4bae7ce994ad/Stream.mkv?static=true&MediaSourceId=b67705812db86839972e4bae7ce994ad&DeviceId=SHCHU5ARL4PQ2&StartTimeTicks=24000000000. UserAgent: Lavf52.104.0 2016-07-09 15:58:06.1505 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 34ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=820&maxheight=110&quality=90 2016-07-09 15:58:06.1795 Info HttpServer: HTTP POST http://192.168.1.140:8096/emby/Sessions/Playing. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:06.1875 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=820&maxheight=110&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:06.1875 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=200&maxheight=280&quality=90. UserAgent: Mozilla/5.0 (SmartHub; SMART-TV; U; Linux/SmartTV+2013; Maple2012) AppleWebKit/535.20+ (KHTML, like Gecko) SmartTV Safari/535.20+ 2016-07-09 15:58:06.1875 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 76ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=200&maxheight=280&quality=90 2016-07-09 15:58:06.1875 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 8ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Logo/0?maxwidth=820&maxheight=110&quality=90 2016-07-09 15:58:06.1875 Info HttpServer: HTTP Response 200 to 192.168.1.199. Time: 11ms. http://192.168.1.140:8096/emby/Items/b67705812db86839972e4bae7ce994ad/Images/Primary/0?maxwidth=200&maxheight=280&quality=90 2016-07-09 15:58:06.4575 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Videos/b67705812db86839972e4bae7ce994ad/Stream.mkv?static=true&MediaSourceId=b67705812db86839972e4bae7ce994ad&DeviceId=SHCHU5ARL4PQ2&StartTimeTicks=24000000000. UserAgent: Lavf52.104.0 2016-07-09 15:58:06.5375 Info HttpServer: HTTP Response 500 to 192.168.1.199. Time: 414ms. http://192.168.1.140:8096/emby/Videos/b67705812db86839972e4bae7ce994ad/Stream.mkv?static=true&MediaSourceId=b67705812db86839972e4bae7ce994ad&DeviceId=SHCHU5ARL4PQ2&StartTimeTicks=24000000000 2016-07-09 15:58:06.7865 Info HttpServer: HTTP Response 204 to 192.168.1.199. Time: 607ms. http://192.168.1.140:8096/emby/Sessions/Playing 2016-07-09 15:58:06.8345 Debug XmlSerializer: Deserializing file C:\Users\Media\AppData\Roaming\MediaBrowser-Server\config\notifications.xml 2016-07-09 16:00:07.5154 Info HttpServer: HTTP Response 206 to 192.168.1.199. Time: 121058ms. http://192.168.1.140:8096/emby/Videos/b67705812db86839972e4bae7ce994ad/Stream.mkv?static=true&MediaSourceId=b67705812db86839972e4bae7ce994ad&DeviceId=SHCHU5ARL4PQ2&StartTimeTicks=24000000000 2016-07-09 16:00:10.7416 Debug XmlSerializer: Deserializing file C:\Users\Media\AppData\Roaming\MediaBrowser-Server\config\branding.xml 2016-07-09 16:00:10.7796 Info HttpServer: HTTP GET http://192.168.1.140:8096/web/strings/en-GB.json?v=1468076411730. UserAgent: Mozilla/5.0 (Linux; Android 6.0.1; Nexus 6 Build/MOB30M) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.81 Mobile Safari/537.36 2016-07-09 16:00:10.7856 Info HttpServer: HTTP GET http://192.168.1.140:8096/web/bower_components/emby-webcomponents/strings/en-US.json?v=1468076411730. UserAgent: Mozilla/5.0 (Linux; Android 6.0.1; Nexus 6 Build/MOB30M) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.81 Mobile Safari/537.36 2016-07-09 16:00:11.4636 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Linux; Android 6.0.1; Nexus 6 Build/MOB30M) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.81 Mobile Safari/537.36 2016-07-09 16:00:11.6767 Info HttpServer: HTTP GET http://192.168.1.140:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Linux; Android 6.0.1; Nexus 6 Build/MOB30M) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.81 Mobile Safari/537.36 My TV is 192.168.1.199. No large slow response times, but lots of small ones.
Blueeyiz702 223 Posted July 9, 2016 Posted July 9, 2016 Did you leave HV2 set to something other than None? No i left it set none.
CBers 7554 Posted July 10, 2016 Posted July 10, 2016 No i left it set none. That's why. Changed it to something other than None and it should be better, at least until @@cmcg can get a fix out. 1
Blueeyiz702 223 Posted July 10, 2016 Posted July 10, 2016 That's why. Changed it to something other than None and it should be better, at least until @@cmcg can get a fix out. Ill do that and hopefully it will work out till its fixed.
FrostByte 5453 Posted July 10, 2016 Posted July 10, 2016 Might not be too hard. Can you give me your full model code? If we work out which column the 8 is in we should be ok. @cmcg I don't think gbone saw your question so I will answer. I found that even some 6 models support UHD and there are some 7/8s which do not. Instead of looking at the number you will need to look for "HU" in columns 5-6 These models support UHD: UN55HU6950 UN65HU7250 UN50HU8550 UN55HU9000 These models do NOT support UHD: UN55H6350 UN55H7150 UN55H8000 1
cmcg 876 Posted July 11, 2016 Author Posted July 11, 2016 @cmcg I don't think gbone saw your question so I will answer. I found that even some 6 models support UHD and there are some 7/8s which do not. Instead of looking at the number you will need to look for "HU" in columns 5-6 These models support UHD: UN55HU6950 UN65HU7250 UN50HU8550 UN55HU9000 These models do NOT support UHD: UN55H6350 UN55H7150 UN55H8000 Thanks for this @@FrostByte. It's in the next beta. 1
rbeier1221 2 Posted July 11, 2016 Posted July 11, 2016 New to Emby so maybe I am just missing something, but a few things I noticed when testing the Beta: Guide time is off, doesn't even match the time for the app. Guide can be slow to load, especially if you have set images for the channels. Also, I don't see the Live TV tab on the top menu, only on the side along with the settings. I looked and didn't see where I would change this. Where would I go to add that tab? Really good job on the app, though. Has some real potential as I get closer to cutting the cord! 1
cmcg 876 Posted July 11, 2016 Author Posted July 11, 2016 Hi @@rbeier1221 Can you provide a screenshot of your guide time issue? The menus are not as I would like and can't be customised right now. That's something I'd like to improve. Other Emby clients handle this better.
rbeier1221 2 Posted July 12, 2016 Posted July 12, 2016 (edited) Here is the pic. The time in the right hand corner is correct, but the guide time seems to default to 11 p.m.. (That is the same time I saw last night, even though I installed the app later in the evening) Edited July 12, 2016 by rbeier1221
